BRE.2V.200.NAV
BRE.2V.200.NAV
    LEMO(雷莫)
    CONN CAP FOR .2V. RCPT
BRE.2V.200.NAV 数据手册
HIGH PRESSURE CONNECTORS V SERIES ® ® Precision modular connectors to suit your application Since its creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and connector solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 subsidiaries and distributors. Over 50’000 connectors The modular design of the LEMO range provides over 50’000 connectors from miniature ø 3 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 114 contacts. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO’s Push-Pull Self-Latching Connection System (not shown in this catalogue) This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. UL Recognition LEMO connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (LEMO connector, cable and your equipment) will be easier because LEMO connectors are approved. CE marking CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. RoHS LEMO connector specifications exceed the requirements of the RoHS directives (2002/95/EC) of the European Parliament and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic equipment marketed in Europe. LEMO guarantees that its connectors are free of mercury, cadmium, lead, hexavalent chromium and polybromide biphenyl (PBB), polybromide diphenyl ether (PBDE), or DecaBDE. www.lemo.com ® ® V Series V series connectors have been developed for utilisation where protection must be guaranteed under high pressures of liquids. The basic elements, insulators, contacts and clamping system are from the S and E series. The push-pull latching system has been replaced by a screw coupling system with watertightness maintained by compression of an O-ring in FPM (Viton®) according to the triangular shaped cavity principle. There are multiple application possibilities, from nuclear physics to the petroleum industry. After cable assembly the rear part must be covered with an adhesive heatshrink boot in order to ensure watertightness on the cable side. V series connectors provide the following main features: – unipole and multipole type – coaxial, triaxial or mixed type available upon request – polarisation by stepped insert (half moon) – 360° screening for full EMC shielding – rugged housing for extreme working conditions. Interconnections Models (page 3) Straight plugs Fixed sockets FVN EVP FVN PSN FVN PSN Free sockets PVP PVP PVP Part Section Showing Internal Components (multipole) Straight plug 1 outer shell Fixed socket 3 1 outer shell 2 earthing crown 3 retaining ring 4 hexagonal nut 5 insulator 6 male contact 7 female contact 8 O-ring 2 4 1 8 5 7 6 9 8 7 6 2 3 5 1 10 12 13 11 4 2 coupling nut 3 circlip 4 collet nut 5 centre-piece 6 o-ring 7 insulator 8 male contact 9 female contact 10 earthing cone 11 collet 12 gasket 13 washer www.lemo.com 1 ® ® Part Number Example Straight plug with cable collet FVN 2V 306 C L A C 60 Model: (page 3) Series: (page 3) Variant: (page 12) 2) Z = nut for fitting a bend relief Insert configuration: (page 6) Cable ø: (page 11) Housing: C = brass chrome-plated S = stainless steel AISI 304 Collet type: C = cable collet K = oversize cable collet = PEEK Insulator: L T = PTFE 1) Contact type: A = male to solder FVN.2V.306.CLAC60 = straight plug with cable collet, 2V series, multipole type with 6 contacts, outer shell in chromeplated brass, PEEK insulator, male solder contacts, C type collet for 6 mm diameter cable. Free socket with cable collet PVP 2V 306 C L C C 60 Model: (page 4) Series: (page 4) Variant: (page 12) 2) Z = nut for fitting a bend relief Insert configuration: (page 6) Cable ø: (page 11) Housing: C = brass chrome-plated S = stainless steel AISI 304 Collet type: C = cable collet K = oversize cable collet = PEEK Insulator: L T = PTFE 1) Contact type: L = female to solder PVP.2V.306.CLLC60 = free socket with cable collet, 2V series, multipole type with 6 contacts, outer shell in chromeplated brass, PEEK insulator, female solder contacts, C type collet for 6 mm diameter cable. Fixed socket EVP 3V 310 S L L Model: (page 4) Series: (page 4) Insert configuration: (page 6) Contact type: L = female to solder Housing: C = brass chrome-plated S = stainless steel AISI 304 = PEEK Insulator: L T = PTFE 1) EVP.3V.310.SLL = fixed socket, nut fixing, 3V series, multipole type with 10 contacts, outer shell in stainless steel, PEEK insulator, female solder contacts. Note: 1) PTFE insulator for unipole type only. 2) The «Variant» position in the reference is used to specify either the presence of a collet nut for fitting the bend relief. For models with collet nut for fitting the bend relief, a «Z» should be indicated and a bend relief can be ordered separately. An order for a connector with bend relief should thus include two part numbers. 2 www.lemo.com ® ® Models Technical Characteristics Mechanical and Climatical Electrical Characteristics Value Standard Endurance Temperature range Salt spray corrosion test Protection index (mated) > 1000 cycles IEC 60512-5 test 9a -20° C, +200° C > 144h IEC 60512-6 test 11f > IP 68 IEC 60529 Resistance to hydrostatic pressure (mated) ~ 30 bars 1) IEC 60512-7 test 14d Climatical category 20/200/21 IEC 60068-1 Characteristics Value at 10 MHz at 1 GHz Shielding efficiency Standard > 95 dB > 80 dB IEC 60169-1-3 IEC 60169-1-3 Note: 1) in order to perform correctly and withstand the pressure, cable assembly shall be made according to instruction we recommand. See page 15. FVN Straight plug with cable collet Reference ~L N øA S2 øB S3 ~M S1 Dimensions (mm) Model Series A B L M N S1 S2 S3 FVN FVN FVN FVN FVN FVN 0V 1V 2V 3V 4V 5V 17.2 19.3 23.5 27.8 34.3 50.0 10 12 16 18 24 38 34 43 52.5 61 71 94 29 35 42 47 57 78 13.5 14.0 15.5 16.5 17.5 21.0 16 18 22 26 32 47 9 10 14 16 22 34 8 9 12 15 19 30 FVN Straight plug with oversize cable collet 1) Reference ~L ~M S3 S2 S1 N øB øA S4 Dimensions (mm) Model Series A FVN FVN FVN FVN 1V 2V 3V 4V 19.3 23.5 27.8 34.3 B L 14.5 55 17.0 65 22.0 80 36.0 105 M N S1 S2 S3 S4 47 55 66 91 14.0 15.5 16.5 17.5 18 22 26 32 10 14 16 22 12 15 19 30 12 15 19 32 Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 11). FVN Straight plug, cable collet and nut for fitting a bend relief 1) Reference Dimensions (mm) Model Series A B L M N S1 S2 S3 FVN FVN FVN FVN FVN 0V 1V 2V 3V 4V 17.2 19.3 23.5 27.8 34.3 10 12 16 18 24 34 43 52 60 71 29 35 42 47 57 13.5 14.0 15.5 16.5 17.5 16 18 22 26 32 9 10 14 16 22 7 9 12 15 19 ~L S2 ~M S1 N øA øB S3 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see pages 141 and 142 of the unipole/multipole catalog). www.lemo.com 3 ® ® EVP Fixed socket, nut fixing Reference L P e S 1 E maxi M S1 øA N e øB S4 Dimensions (mm) Model Series A B e E L M EVP EVP EVP EVP EVP EVP 0V 1V 2V 3V 4V 5V 19 21 26 31 38 55 19.2 21.5 27.0 34.0 40.5 54.0 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 5.5 10.5 11.0 15.0 14.5 15.5 19.0 26.0 29.0 34.5 35.0 44.5 N P 2.0 8.0 8.0 2.0 8.0 13.5 2.5 9.0 15.0 3.0 9.5 20.0 3.5 10.0 21.5 4.5 12.5 24.5 S1 S4 12.5 14.5 18.5 22.5 28.5 42.5 17 19 24 30 36 – Panel cut-out (page 13) Note: the 5V series is delivered with a round nut. PSN Fixed socket, cable collet, nut fixing Reference ~L e S3 E maxi M øA N e øB S1 S4 Dimensions (mm) Model Series A B e E L PSN PSN PSN PSN PSN PSN 0V 1V 2V 3V 4V 5V 19 21 26 31 38 56 19.2 21.5 27.0 34.0 40.5 54.0 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 5.5 10.5 11.0 15.0 14.5 15.5 34.0 46.0 54.0 65.0 75.5 95.0 M N S1 S3 S4 8 9 12 15 19 30 17 19 24 30 36 – S3 S4 12.5 7 14.5 9 18.5 12 22.5 15 28.5 19 17 19 24 30 36 2.0 8.0 12.5 2.0 8.0 14.5 2.5 9.0 18.5 3.0 9.5 22.5 3.5 10.0 28.5 4.5 12.5 42.5 Panel cut-out (page 13) S1 Note: the 5V series is delivered with a round nut. PSN Fixed socket, cable collet, nut fixing and nut for fitting a bend relief 1) Reference ~L øA e N e øB S1 S4 Dimensions (mm) Model Series A B e E L PSN PSN PSN PSN PSN 0V 1V 2V 3V 4V 19 21 26 31 38 19.2 21.5 27.0 34.0 40.5 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 5.5 10.5 11.0 15.0 14.5 34.0 46.0 54.0 64.0 75.5 M N 2.0 8.0 2.0 8.0 2.5 9.0 3.0 9.5 3.5 10.0 S1 Panel cut-out (page 13) S3 E maxi M S1 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see pages 141 and 142 of the unipole/multipole catalog). PVP Free socket with cable collet Reference e øB ~L S2 4 S1 Dimensions (mm) Model Series B e L S1 S2 PVP PVP PVP PVP PVP PVP 0V 1V 2V 3V 4V 5V 10 12 16 19 24 38 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 34.0 45.0 54.0 65.0 75.5 95.0 9 10 14 16 22 34 8 9 12 15 19 30 www.lemo.com ® ® PVP Free socket with oversize cable collet 1) Reference e øB ~L S2 S3 Dimensions (mm) Model Series B PVP PVP PVP PVP 1V 2V 3V 4V 14.5 17.0 22.0 36.0 e L M16x1.0 58 M20x1.0 67 M24x1.0 84 M30x1.0 109 S1 S2 S3 10 14 16 22 12 15 19 30 12 15 19 32 Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 12). S1 PVP Free socket, cable collet and nut for fitting a bend relief 1) Reference e øB ~L S2 www.lemo.com S1 Dimensions (mm) Model Series B e L S1 S2 PVP PVP PVP PVP PVP 0V 1V 2V 3V 4V 10 12 16 19 24 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 34.0 46.0 54.0 64.0 75.5 9 10 14 16 22 7 9 12 15 19 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see pages 141 and 142 of the unipole/multipole catalog). 5 ® ® Insert configuration Unipole ø A (mm) Solder Crimp Test voltage (kV rms)1) Test voltage (kV dc)1) Rated current (A)1) 0V 116 1.6 ●2) – 1.5 2.1 12 1V 120 2.0 ●2) – 1.7 2.4 18 130 3.0 ● – 1.5 2.1 25 130 3.0 ● – 2.1 3.0 30 140 4.0 ● – 1.7 2.4 40 140 4.0 ● – 2.3 3.3 43 160 6.0 ● – 1.7 2.4 65 160 6.0 ● – 2.7 3.9 70 112 12.0 ● – 1.5 2.1 230 øA Reference Contact type Male solder contacts Female solder contacts 2V 3V 4V 5V Note: 1) see calculation method, caution and suggested standard. 2) also available with inversed contacts: plug = female, socket = male. Coaxial, Triaxial, Mixed A wide choice of those types is available, please consult us. 6 www.lemo.com ® ® Multipole Number of contacts ø A (mm) Solder Crimp Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 302 2 0.9 ● ● ● ● 1.5 2.1 103) 303 3 0.7 ● ● ● ● 1.0 1.5 73) 304 4 0.7 ● ● ● ● 1.0 1.5 73) 302 2 1.3 ● ● ● ● 1.2 1.8 153) 303 3 0.9 ● ● ● ● 1.2 1.8 103) 304 4 0.9 ● ● ● ● 1.2 1.8 103) 305 2 3 0.9 0.7 ● ● ● ● 1.5 1.5 2.1 2.1 103) 73) 306 6 0.7 ● ● ● ● 1.5 2.1 73) 302 2 1.6 ● ● ● ● 1.7 2.4 204) 303 3 1.3 ● ● ● ● 1.5 2.1 154) 304 4 1.3 ● ● ● ● 1.7 2.4 154) 305 5 1.3 ● ● ● ● 1.5 2.1 134) 306 6 1.3 ● ● ● ● 1.5 2.1 12 307 3 4 1.3 0.9 ● ● ● ● 0.8 0.8 1.2 1.2 123) 93) 308 8 0.9 ● ● ● ● 0.8 1.2 93) 310 10 0.9 ● ● ● ● 0.8 1.2 73) 302 2 2.0 ● – ● – 3.0 4.2 23 303 3 2.0 ● – ● – 1.5 2.1 20 304 4 2.0 ● – ● – 1.5 2.1 18 305 2 3 2.0 1.3 ● – ● – 1.5 1.5 2.1 2.1 18 14 306 6 1.3 ● – ● – 2.1 3.0 14 307 7 1.3 ● – ● – 1.0 1.5 12 øA øA Reference Contact type Male solder contacts 0V 2 3 1 1 2 2 1 1 2 3 2 3 1V Female solder contacts 1 4 1 4 1 1 2 2 2 2 3 1 1 2 3 3 2 3 1 4 1 4 2 3 2 2 3 3 1 1 4 4 5 5 2 2 3 4 6 6 5 3 1 1 4 2V 2 5 1 1 2 2 1 1 2 3 3 2 3 1 4 1 4 2 2 3 2 3 3 1 1 4 4 5 5 2 2 3 3 1 1 4 4 6 5 3 4 6 3 2 2 5 4 1 1 5 5 7 7 6 3 4 6 3 2 2 4 1 1 5 5 6 3 4 9 5 8 8 7 3 2 2 2 6 7 3V 5 10 8 8 7 1 1 2 2 1 1 6 9 1 1 10 6 7 4 2 3 3 2 1 1 2 3 4 4 3 2 2 3 1 3 1 4 4 5 5 2 2 3 1 3 1 4 3 4 4 5 6 6 2 2 1 3 5 4 1 5 5 6 7 7 6 Note: 1) see calculation method, caution and suggested standard. 2) lowest measured value; contact to contact or contact to shell. 3) rated current = 6A for socket with elbow (90°) contacts for printed circuit. 4) rated current = 12A for socket with elbow (90°) contacts for printed circuit. www.lemo.com ● First choice alternative ● Special order alternative 7 ® ® Multipole Number of contacts ø A (mm) Solder Crimp Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 308 8 1.3 ● ● ● ● 1.0 1.5 10 310 10 1.3 ● ● ● ● 1.0 1.5 9 312 12 0.9 ● ● ● ● 1.5 2.1 8 313 13 0.9 ● ● ● ● 1.5 2.1 8 314 14 0.9 ● ● ● ● 1.5 2.1 7 316 16 0.9 ● ● ● ● 1.0 1.5 7 318 18 0.9 ● ● ● ● 1.0 1.5 6 302 2 4.0 ● – ● – 2.1 3.0 35 303 3 3.0 ● – ● – 2.1 3.0 25 304 4 3.0 ● – ● – 2.1 3.0 22 305 2 3 3.0 2.0 ● – ● – 2.1 2.1 3.0 3.0 22 16 306 6 2.0 ● – ● – 2.1 3.0 16 307 3 4 2.0 1.3 ● – ● – 2.1 2.1 3.0 3.0 16 13 308 8 1.3 ● – ● – 2.7 3.9 13 309 9 1.3 ● – ● – 2.1 3.0 12 310 10 1.3 ● – ● – 2.1 3.0 11 312 12 1.3 ● – ● – 2.1 3.0 9 øA øA Reference Contact type Male solder contacts 3 3 2 2 4 3V Female solder contacts 1 4 1 5 5 7 9 1 4 1 9 10 10 2 1 3 7 6 10 3 1 13 12 7 11 4 8 3 12 13 12 1 5 5 9 6 10 1 3 12 14 8 12 16 13 4 7 11 4 9 13 9 12 4 8 1 12 11 7 11 4 8 14 8 2 1 7 11 4 1 4 8 3 1 3 7 11 12 1 1 10 14 5 5 4 18 15 1 1 2 2 2 1 1 2 3 3 2 1 1 2 3 4 4 3 2 3 9 14 10 15 18 4V 6 7 7 16 5 8 8 6 6 7 3 2 2 4 5 8 8 6 3 2 1 1 4 3 5 5 2 3 4 2 1 1 3 4 6 6 5 3 2 4 4 5 2 3 1 1 4 5 3 7 7 6 2 4 2 5 6 3 1 1 4 5 8 8 6 4 7 5 7 3 2 6 2 5 3 4 1 1 5 6 4 9 9 7 3 2 8 2 5 3 5 6 6 10 8 7 4 1 1 7 6 8 10 9 4 3 9 2 5 2 8 4 5 6 11 12 12 10 7 8 3 1 1 11 6 7 9 10 7 9 8 Note: 1) see calculation method, caution and suggested standard. 2) lowest measured value; contact to contact or contact to shell. 8 ● First choice alternative ● Special order alternative www.lemo.com ® ® Multipole Number of contacts ø A (mm) Solder Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 314 14 1.3 ● ● – 2.1 3.0 9 316 16 0.9 ● ● – 2.1 3.0 7 318 18 0.9 ● ● – 2.1 3.0 7 320 20 0.9 ● ● – 2.1 3.0 7 322 22 0.9 ● ● – 2.1 3.0 7 324 24 0.9 ● ● – 2.1 3.0 7 302 2 6.0 ● – – 3.7 5.2 50 303 1 2 6.0 4.0 ● – – 3.7 3.7 5.2 5.2 50 35 304 4 4.0 ● – – 3.7 5.2 35 305 2 3 4.0 3.0 ● – – 3.0 3.0 4.2 4.2 35 25 306 6 3.0 ● – – 3.0 4.2 25 308 8 3.0 ● – – 2.1 3.0 22 310 10 2.0 ● – – 2.1 3.0 18 øA øA Reference Contact type Male solder contacts 3 3 4 4V Female solder contacts 12 11 13 14 1 1 6 9 8 1 8 1 9 4 3 5 15 1 4 2 1 6 3 1 21 3 4 12 17 18 21 22 22 5V 22 7 13 13 18 20 21 8 8 24 11 17 4 17 6 16 12 17 22 2 7 7 1 21 1 20 3 20 7 17 12 16 18 15 18 11 12 15 10 11 18 14 5 16 16 3 9 3 6 11 20 4 10 6 15 8 1 4 17 24 1 1 2 2 2 6 7 5 10 18 5 16 5 1 10 9 1 9 14 13 12 13 13 14 8 9 16 12 4 5 5 12 11 10 10 7 4 4 2 2 5 1 1 2 3 3 2 1 1 2 3 4 4 3 2 2 3 3 1 1 4 4 5 5 2 2 3 1 3 1 4 4 6 6 5 3 2 2 4 5 3 4 1 1 5 5 8 8 6 7 7 4 6 3 3 2 2 5 1 4 5 1 6 6 10 7 8 10 9 7 9 8 Note: 1) see calculation method, caution and suggested standard. 2) lowest measured value; contact to contact or contact to shell. www.lemo.com 9 ® ® Multipole Number of contacts ø A (mm) Solder Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 312 12 2.0 ● – – 2.1 3.0 18 314 2 12 3.0 2.0 ● – – 1.8 1.8 2.4 2.4 20 15 316 16 2.0 ● – – 1.8 2.4 15 318 2 16 3.0 1.6 ● – – 1.8 1.8 2.4 2.4 18 11 320 20 1.6 ● – – 1.8 2.4 11 322 2 20 3.0 1.6 ● – – 1.8 1.8 2.4 2.4 16 9 324 24 1.6 ● – – 2.7 3.9 9 330 30 1.3 ● – – 1.8 2.4 8 336 36 1.3 ● – – 1.8 2.4 7 340 40 1.3 ● – – 1.2 1.8 7 344 44 1.3 ● – – 1.2 1.8 6 348 48 1.3 ● – – 1.2 1.8 6 øA øA Reference Contact type Male solder contacts 4 4 3 3 5 5V Female solder contacts 2 6 5 2 6 1 1 7 7 12 8 4 5 3 2 2 6 13 7 13 1 1 12 12 8 11 11 9 4 13 1 1 12 12 16 7 8 17 1 1 9 9 16 16 5 4 4 16 13 4 5 3 7 18 18 19 2 2 8 17 1 1 9 20 20 10 21 11 12 16 16 22 13 13 1 3 15 22 23 28 29 29 1 19 6 1 12 7 13 13 20 21 21 28 29 29 40 34 35 35 40 1 1 7 9 3 1 4 32 39 33 45 40 48 46 1 3 10 25 37 38 38 4 17 30 31 31 10 24 22 23 23 44 14 15 15 37 7 8 8 30 16 2 2 14 22 43 31 36 32 7 34 25 26 26 1 28 18 19 32 36 11 12 12 31 5 6 6 25 6 30 1 11 18 12 8 16 23 24 2 9 9 16 5 21 22 22 3 15 17 18 1 22 12 18 24 7 8 8 21 3 4 4 17 20 12 1 7 28 13 1 12 30 11 14 8 21 15 14 3 2 10 22 15 13 12 13 6 3 17 11 14 14 4 19 10 19 15 15 12 9 20 16 19 8 18 1 1 11 7 17 20 10 6 7 2 2 17 9 5 3 18 5 13 12 3 8 8 11 14 6 6 10 15 15 7 9 18 14 13 6 2 2 18 9 10 5 4 3 3 12 8 11 10 17 11 7 16 11 9 10 6 13 15 8 7 14 15 4 8 5 2 2 14 7 4 3 3 5 6 5 9 10 10 6 7 14 14 8 9 10 10 3 4 6 8 11 11 9 5 12 44 43 9 16 17 24 25 32 33 40 39 45 46 48 Note: 1) see calculation method, caution and suggested standard. 2) lowest measured value; contact to contact or contact to shell. 10 www.lemo.com ® ® Collets C and K type collets Reference Type Code 0V 1V 2V 3V Cable ø Reference max. min. C C 40 50 4.2 5.2 > 3.2 > 4.2 C C C C K K K K 40 50 60 65 70 75 80 85 4.2 5.2 6.2 7.2 7.2 8.2 8.2 9.2 > 3.2 > 4.2 > 5.2 > 6.2 > 6.2 > 7.2 > 7.2 > 8.2 C C C K K K K 70 80 85 90 95 10 11 7.2 8.2 9.2 10.2 10.2 10.2 11.2 > 6.2 > 7.2 > 8.2 > 8.7 > 8.7 > 8.7 > 10.2 C C C C K K K K K 70 80 10 11 11 12 13 14 15 7.2 8.7 10.2 11.2 12.0 12.8 13.5 14.0 15.0 > 5.7 > 7.2 > 8.7 > 10.2 10.6 12.1 12.9 13.6 14.1 Note: all dimensions are in millimetres. www.lemo.com Type Code 4V 5V Cable ø max. min. C C C C C C C C C C C C C K K K K K K K K 65 70 75 80 85 90 95 10 11 12 13 14 15 16 17 18 19 20 21 22 23 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.5 12.0 12.8 13.5 14.0 15.0 16.5 17.5 18.5 19.5 20.5 21.5 22.5 23.5 6.1 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.6 12.1 12.9 13.6 14.1 15.6 16.6 17.6 18.6 19.6 20.6 21.6 22.6 C C C C C C C C C C 14 15 16 17 18 19 20 21 22 23 14.5 15.5 16.5 17.5 18.5 19.5 20.5 21.5 22.5 23.5 13.6 14.6 15.6 16.6 17.6 18.6 19.6 20.6 21.6 22.6 11 ® ® Variant Collet Type Code Ref. Ref. Bend relief for models with collet Collet Type Code 0V Z C 40 to 50 3V Z C K 70 to 10 11 to 15 1V Z C K 40 to 65 70 to 85 4V Z C 65 to 15 2V Z C K 70 to 85 90 to 10 Note: The bend relief must be ordered separately (see pages 141 and 142 of the unipole/multipole catalog). All dimensions are in millimetres. Panel cut-outs Panel Cut-outs EVP, PSN Series L ø B +00.1 0V 1V 2V 3V 4V 5V ø A +00.1 Dimensions (mm) A B L 14.1 16.1 20.2 24.2 30.2 45.2 12.6 14.6 18.6 22.6 28.6 42.6 19.0 21.0 25.5 30.0 37.0 53.0 Mounting nuts torque Torque (Nm) Component Collet nut for F●● and P●● Mounting hex nut for sockets Coupling nut 12 0V 1V 2V 3V 4V 5V 0.7 5 5 0.8 7 7 2 9 9 3 12 12 5 17 17 8 22 22 1N = 0.102 kg www.lemo.com ® ® Accessories BFA Plug caps B L S1 N sliding loop øA e Part number Series 0V 1V 2V 3V 4V 5V BFA.0V.100.●AZ BFA.1V.100.●AZ BFA.2V.100.●AZ BFA.3V.100.●AZ BFA.4V.100.●AZ BFA.5V.100.●AZ ● Body material: A 17.2 19.3 23.5 27.8 34.3 50.0 Dimensions (mm) B e L 6 6 6 6 10 10 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 12.5 15.5 17.5 22.0 22.5 27.0 N S1 85 85 85 120 120 120 16 18 22 26 32 47 = N, nickel-plated brass (Ni 3µm) = S, stainless steel ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass ● ● BRE Blanking caps for fixed sockets This cap is only IP68 when installed S1 L Part number Series 0V 1V 2V 3V 4V 5V ø 3.5 øA BRE.0V.200.●AV BRE.1V.200.●AV BRE.2V.200.●AV BRE.3V.200.●AV BRE.4V.200.●AV BRE.5V.200.●AV Dimensions (mm) A L N S1 17.2 19.3 23.5 27.8 34.3 50.0 13.7 13.7 14.7 14.7 14.7 16.2 85 85 85 120 120 120 16 18 22 26 32 47 N ● Body material: = N, nickel-plated brass (Ni 3µm) = S, stainless steel ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass ● O-ring: FPM (Viton®) ● ● BRF Blanking caps for free sockets This cap is only IP68 when installed S1 L Part number Series 0V 1V 2V 3V 4V 5V øA BRF.0V.200.●AV BRF.1V.200.●AV BRF.2V.200.●AV BRF.3V.200.●AV BRF.4V.200.●AV BRF.5V.200.●AV Dimensions (mm) A L N S1 17.2 19.3 23.5 27.8 34.3 50.0 13.7 13.7 14.7 14.7 14.7 16.2 85 85 85 120 120 120 16 18 22 26 32 47 N sliding loop www.lemo.com ● Body material: = N, nickel-plated brass (Ni 3µm) = S, stainless steel ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass ● O-ring: FPM (Viton®) ● ● 13 ® ® GEA Hexagonal nuts Part number 0V 1V 2V 3V 4V GEA.0E.240.LN GEA.1E.240.LN GEA.2E.240.LN GEA.3E.240.LN GEA.4E.240.LN A L B e Series A 17 19 24 30 36 Dimensions (mm) B e L 19.2 21.5 27.0 34.0 40.5 M14 x 1.00 M16 x 1.00 M20 x 1.00 M24 x 1.00 M30 x 1.00 2.5 3.0 4.0 5.0 7.0 Note: to order this part separately, use the above part numbers. The last letters «LN» of the part number refer to the nut material and treatment. If a nut in stainless steel is desired, replace the last letters of the part number by «AZ». ● Material: – Nickel-plated brass (3 µm) – Stainless steel GEB Round nuts øA Part number Series L e 5V GEB.5E.240.LN Dimensions (mm) A e L 54 M45 x 1.5 8.0 Note: to order this part separately, use the above part numbers. The last letters «LN» of the part number refer to the nut material and treatment. If a nut in stainless steel is desired, replace the last letters of the part number by «AZ». ● Material: – Nickel-plated brass (3 µm) – Stainless steel GDA O-ring for plug øA øC Part number Series GDA.99.080.100VK GDA.99.100.100VK GDA.99.130.150VK GDA.99.165.150VK GDA.99.210.200VK GDA.99.330.250VK 0V 1V 2V 3V 4V 5V Dim. (mm) A C 8.0 10.0 13.0 16.5 21.0 33.0 1.0 1.0 1.5 1.5 2.0 2.5 ● Material: FPM (Viton®) 14 www.lemo.com ® ® Cable assembly Assembly instructions In order to ensure the sealing of plugs and sockets on the cable side, it is imperatively necessary to complete their assembly by realizing it with an adapted technique. We recommend the fitting of an heatshrink boot with inner melting coating of type ATUM (manufactured by the RAYCHEM company) or similar. This heatshrink boot is not provided with the connector. For multiconductors cables, the assembly instructions are the followings: Cut the excess C A Dimensions 0V 1V 2V 3V 4V 5V A B 3 7 3 11 4 14 4 19 5 23 6 34 B 1) Preparation and stripping of cable (see above). 2) Slide the heatshrink boot over the cable; types and dimensions to have are: Series Type of heatshrink boot Length of the boot Oversize collet Length of the boot for oversize collet 0V 1V 2V 3V 4V 5V 12/3-0 12/3-0 19/6-0 19/6-0 24/6-0 40/13-0 30 35 40 45 50 65 – 16/4-0 19/6-0 24/8-0 40/13-0 – – – 70 – – – 3) After having soldered the conductors on the contacts of the plug/socket insulator, bring the earthing cone against the centre-piece. Cut the excess of screen. 4) Locate the insulator, the centre-piece, the earthing cone, the gland, the compression ring and the collet in the plug/socket shell. 5) Screw the collet nut at the recommended torque value. 6) Remove all grease left on plug/socket shells with acetone. 7) Place the heatshrink boot of the correct dimensions onto the rear end of the plug/socket against the coupling nut. 8) Heat the heatshrink boot until the melting coating totally melts and adheres perfectly onto the cable jacket. www.lemo.com 15 ® 16 ® www.lemo.com LEMO complete product range B S K E F 00 01 0A 3T 4A 4M 3K. 1D 93C Y 05 5G 2G 2C L H R N 03 V W U F P D K/S 01 DIN Unipole • Multipole Coaxial 50 Ω Coaxial 75 Ω Multi Coaxial Mixed Coax + LV Triaxial 50 Ω Triaxial 75 Ω Mixed Triax + LV Quadrax High Voltage Multi High Voltage Mixed HV + LV Fibre Optic Multi Fibre Optic Mixed FO + LV Thermocouple Fluidic Multi Fluidic Mixed Fluidic + LV Most frequently used in darker colour • included in this catalogue B Series Keyed S Series K Series Keyed E Series F Series Keyed 00 Series 01 Series 0A Series 3T Series 4A Series 4M Series Keyed 3K.93C Series Keyed 1D Series Y Series 05 Series 5G Series Keyed 2G Series Keyed 2C Series L Series Keyed H Series R Series Keyed N Series Keyed 03 Series Keyed V Series W Series Keyed U Series Keyed Cable assembly K/S Series Keyed REDEL F Series REDEL P Series Keyed REDEL D Series 01 Series Keyed VAA Series SAA Series TAA Series No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO SA reserves the right to modify and improve specifications, at all times, without any notification. LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax:(+43 1) 914 23 20 11 sales@lemo.at NETHERLANDS / BELGIUM LEMO Connectors Benelux De Trompet 2108 1967 DC Heemskerk Tel. (+31) 251 25 78 20 Fax (+31) 251 25 78 21 info@lemo.nl CHINA LEMO Trading (Shanghai) Co., Ltd LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com NORWAY / ICELAND LEMO Norway A/S Stanseveien 6B 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com DENMARK LEMO Denmark A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de HONG KONG LEMO Hong Kong Ltd Unit 1207, 12/F, Corporation Square, 8 Lam Lok Street, Kowloon Bay, Kowloon - Hong Kong Tel: (+852) 2174 0468 Fax: (+852) 2174 0492 hk.sales@lemo.com HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 redelemo@lemo.hu ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com JAPAN LEMO Japan Ltd 4-10-3, Takaido Higashi, Suginami-ku, Tokyo, 168-0072 Tel: (+81 3) 53 44 39 33 Fax: (+81 3) 53 44 39 35 lemoinfo@lemo.co.jp LEMO SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO S.A. Brasil, 45, 08402 Granollers Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com Madrid Office Antonio López, 96, 28019 Madrid Tel: (+34 91) 469 99 19 Fax: (+34 91) 469 99 59 SWEDEN / FINLAND LEMO Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax:(+1 707) 578 08 69 info@lemousa.com DISTRIBUTORS AUSTRALIA, BRAZIL, CANADA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TAIWAN, TURKEY, UKRAINE www.lemo.com © CAT.MV.LEN.P1006 - Pdf updated April 2011 LEMO
BRE.2V.200.NAV 价格&库存
很抱歉,暂时无法提供与“BRE.2V.200.NAV”相匹配的价格&库存,您可以联系我们找货
