NCT6779D
NCT6779D
    NUVOTON(新唐)
    LQFP128_14X14MM
    IC INTERFACE SPECIALIZED 128LQFP
NCT6779D 数据手册
Page 1 of 1 LPC Super I/O for Desktop & Server Part No. NCT6779D Datasheet Request The NCT6779D is a member of Nuvoton's Super I/O product line. The NCT6779D monitors several critical parameters in PC hardware, including power supply voltages, fan speeds and temperatures. In terms of temperature monitoring, the NCT6779D adopts the Current Mode (dual current source) and thermistor sensor approach. The NCT6779D also supports the Smart Fan control system, including "SMART FANTM I "and "SMART FANTM IV", which makes the system more stable and user-friendly. The NCT6779D supports Printer Port, KBC, 2 UART and flexible I/O control functions through a set of general purpose I/O (GPIO) ports. Description The NCT6779D supports Intel ® PECI (Platform Environment Control Interface), AMD ® SB-TSI interface, AMD ® CPU power on sequence, and Intel ® Deep Sleep Well glue logic to help customers to reduce the external circuits needed while using Deep Sleep Well function. The NCT6779D supports to decode port 80 diagnostic messages on the LPC bus. It also supports two-color LED control to indicate system power states. The NCT6779D supports Consumer IR function for remote control purpose. It also supports Advanced Power Saving function to further reduce the power consumption while the system is at S5 state. The configuration registers inside the NCT6779D support mode selection, function enable and disable, and powerdown selection. Furthermore, the configurable PnP features are compatible with the plug-and-play feature in Windows, making the allocation of the system resources more efficient than ever. LPC Interface 2 serial port (UART) supporting RS-485 auto flow control PC-compatible printer port (SPP) / Extended Capabilities Port (ECP) / Enhanced Parallel Port (EPP) 8042 keyboard controller with PS/2 mouse General purpose I/O ports CIR receiver, transmitter, learning and wake-up functions PECI 3.0 host, SB-TSI, SMBus Master Intel Deep Sleep Well (DSW) glue logic function Advanced Power Saving function (ErP) AMD CPU power on sequence Port80 decode for debug purpose Two-color LED to indicate different power status H/W Monitor functions, up to 10 external voltage detection inputs, up to 6 temperature detection inputs, 5 fan speed detection and 5 fan speed control Features Diagram N/A Package 128-pin LQFP Other Files N/A Development Tools N/A Others N/A Contact us: ComputerIC@nuvoton.com http://www.nuvoton.com/hq/enu/ProductAndSales/ProductLines/CloudAndComputingIC/SuperIO/SuperIOforDe... 8/26/2013
NCT6779D 价格&库存
很抱歉,暂时无法提供与“NCT6779D”相匹配的价格&库存,您可以联系我们找货
