AT25SF161
16-Mbit, 2.5V Minimum
SPI Serial Flash Memory with Dual-I/O and Quad-I/O Support
DATASHEET (ADDENDUM)
High Temperature Operation (125°C)
This data sheet addendum is to be used in conjunction with the existing AT25SF161
datasheet specifications. The Adesto AT25SF161 16Mbit Serial Flash devices will
operate @ 125°C with the following datasheet caveats. All other parameters will meet
the existing datasheet specifications.
The ordering code suffix (CAN# Code) 'HR' or ‘HT’ must be used to ensure correct
operation at this extended temperature range. Adesto will not modify and republish the
current datasheet to reflect the CAN# 'HR' ordering code or the above caveats.The
standard AT25SF161 datasheet is available at http://www.adestotech.com.
1.
Electrical Specifications
1.1
DC and AC Operating Range
AT25SF161-xxxHR/HT
Operating Temperature
-40C to +125C
Endurance (Maximum)
10,000 cycles
Retention (1)
1.
10 years
Represents typical value based on equivalent operation derived from Arrhenius calculations under post cycling high temperature conditions; not indicative of
performance at constant device operation life at 125°C.
1.2
DC Characteristics
2.5V to 3.6V
Symbol
Parameter
Condition
IDPD
Deep Power-Down Current
ISB
Standby Current
1.
Industrial temperature limit is 5µA.
2.
Industrial temperature limit is 25µA.
Min
Typ
Max
Units
CS, HOLD, WP = VIH
10 (1)
µA
CS, HOLD, WP = VIH
35 (2)
µA
DS-25SF161–046C–8/2017
1.3
Program and Erase Characteristics
2.5V to 3.6V
Symbol
Parameter
tPP (1)
tCHPE(1) (2)
Min
Typ
Max
Units
Page Program Time (256 Bytes)
1.5
4
ms
Chip Erase Time
12
25
sec
1. Maximum values indicate worst-case performance after 10,000 erase/program cycles.
2. Not 100% tested (value guaranteed by design and characterization).
2.
Ordering Code
2.1
Ordering Code Detail
Ordering Code (1)
AT25SF161-SHDHR-T
AT25SF161-SHDHR-B
AT25SF161-SSHDHR-T
AT25SF161-SSHDHR-B
Package
Operating Voltage
Max. Freq.
(MHz)
2.5V to 3.6V
85MHz
Operation Range
8S2
8S1
1. The shipping carrier option code is not marked on the devices.
Package Type
8S1
8-lead, 0.150" Wide, Plastic Gull Wing Small Outline Package (JEDEC SOIC)
8S2
8-lead, 0.208" Wide, Plastic Gull Wing Small Outline Package (EIAJ SOIC)
3. Revision History
Revision Level – Release Date
History
A – November 2015
Initial release.
B – February 2016
Removed AT25SF161-DWF-HT product option.
C – August 2017
Updated corporate address information.
Extended
(-40°C to +125°C)
Corporate Office
California | USA
Adesto Headquarters
3600 Peterson Way
Santa Clara, CA 95054
Phone: (+1) 408.400.0578
Email: contact@adestotech.com
© 2017 Adesto Technologies. All rights reserved. / Rev.: DS-25SF161–046C–8/2017
Disclaimer: Adesto Technologies Corporation makes no warranty for the use of its products, other than those expressly contained in the Company's standard warranty which is detailed in Adesto's Terms
and Conditions located on the Company's web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications
detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Adesto are granted by the
Company in connection with the sale of Adesto products, expressly or by implication. Adesto's products are not authorized for use as critical components in life support devices or systems.
很抱歉,暂时无法提供与“AT25SF161-SSHDHR-T”相匹配的价格&库存,您可以联系我们找货
