AT45DB041E
4-Mbit, 1.65V Minimum
SPI DataFlash® Memory
DATASHEET (ADDENDUM)
High Temperature Operation (125°C)
This data sheet addendum is to be used in conjunction with the existing AT45DB041E
datasheet specifications. The Adesto AT45DB041E 4Mbit DataFlash devices will
operate @ 125°C with the following datasheet caveats. All other parameters will meet
the existing datasheet specifications.
The ordering code suffix (CAN# Code) 'HT' must be used to ensure correct operation
at this extended temperature range. Adesto will not modify and republish the current
datasheet to reflect the CAN# 'HT' ordering code or the above caveats.The standard
AT45DB041E datasheet is available at http://www.adestotech.com.
1.
Electrical Specifications
1.1
DC and AC Operating Range
AT45DB041E-xxxHT
Operating Temperature
-40C to +125C
Endurance (Maximum)
10,000 Cycles
1.2
DC Characteristics
1.65V to 3.6V
Symbol
Parameter
Condition
IDPD
Deep Power-Down
Current
ISB
ICC3
Min
2.3V to 3.6V
Typ
Max
CS, RESET, WP = VIH
All inputs at CMOS levels
4.5
Standby Current
CS, RESET, WP = VIH
Active Current,
Program Operation
CS=VCC
Min
Typ
Max
Units
µA
25
45
25
45
µA
14
mA
AT45DB041E (Addendum)–024C–8/2017
1.3
AC Characteristics
1.65V to 3.6V
Symbol
Parameter
fCAR1
SCK Frequency for Continuous Read (0x0B)
fCAR2
SCK Frequency for Continuous Read (0x03)
(Low Frequency)
tCS
Minimum CS High Time
tV
Output Valid
1.4
Min
Max
Units
70
70
MHz
33
33
MHz
24
Min
24
ns
8
6
ns
Program and Erase Characteristics
1.65V to 3.6V
2.3V to 3.6V
Symbol
Parameter
Typ
Max
Typ
Max
Units
tBE
Block Erase Time
30
50
30
50
ms
tSE
Sector Erase Time
.7
1.3
.7
1.3
s
Notes: 1.
2.
Values are based on device characterization, not 100% tested in production.
Not 100% tested (value guaranteed by design and characterization).
2.
Ordering Code
2.1
Ordering Code Detail
Ordering Code (1)
AT45DB041E-SHNHT-T
AT45DB041E-SHNHT-B
AT45DB041E-SSHNHT-T
AT45DB041E-SSHNHT-B
1.
Max
2.3V to 3.6V
Package
Operating Voltage
Max. Freq.
(MHz)
1.65V to 3.6V
85MHz
Operation Range
8S2
Extended
(-40°C to +125°C)
8S1
The shipping carrier option code is not marked on the devices.
Package Type
8S1
8-lead, 0.150" Wide, Plastic Gull Wing Small Outline Package (JEDEC SOIC)
8S2
8-lead, 0.208" Wide, Plastic Gull Wing Small Outline Package (EIAJ SOIC)
DS-45DB041E–024C–8/2017
2
1. Revision History
Revision Level – Release Date
History
A – January 2015
Initial release.
B – October 2015
Corrected package type in Ordering Code Detail table.
C – August 2017
Updated corporate address information.
Corporate Office
California | USA
Adesto Headquarters
3600 Peterson Way
Santa Clara, CA 95054
Phone: (+1) 408.400.0578
Email: contact@adestotech.com
© 2017 Adesto Technologies. All rights reserved. / Rev.: DS-45DB041E–024C–8/2017
Disclaimer: Adesto Technologies Corporation makes no warranty for the use of its products, other than those expressly contained in the Company's standard warranty which is detailed in Adesto's Terms
and Conditions located on the Company's web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications
detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Adesto are granted by the
Company in connection with the sale of Adesto products, expressly or by implication. Adesto's products are not authorized for use as critical components in life support devices or systems.
很抱歉,暂时无法提供与“AT45DB041E-SHNHT-B”相匹配的价格&库存,您可以联系我们找货
