HI-1575PQI
HI-1575PQI
    HOLT
    TQFP32
    ICCMOSTRANSCEIVER32QFP
HI-1575PQI 数据手册
HI-1575 MIL-STD-1553 3.3V Dual Transceivers with Integrated Encoder / Decoders DESCRIPTION 11 12 13 14 15 16 17 18 19 20 1575PCI 1575PCT 26 - D3 25 - D4 28 - D1 27 - D2 30 - CLK 40 Pin Plastic 6mm x 6mm Chip-scale package 29 - D0 Activity on both MIL-STD-1553 data buses is continuously monitored. When the HI-1575 detects a properly encoded word, a hardware interrupt is generated and the information is decoded and stored in one of two internal registers, which may then be read by the host processor. Bits in the internal Status & Mode Register indicate on which bus the word was received and whether the word had a Data or Command Sync. 30 29 D5 28 D6 27 D7 26 GND 25 D8 24 D9 23 D10 22 D11 21 - R/W STRB MR SYNC D15 D14 D13 D12 - A single write cycle is used to transfer a word to the HI-1575, which encodes the data, adds the selected Sync and Parity bits, and transmits the word on the chosen MIL-STD-1553 data bus. Complete MIL-STD-1553 messages may be transmitted by executing multiple write cycles to the device. - 1 RCVA 2 BUSA 3 BUSA 4 VDD 5 BUSB 6 BUSB 7 RCVB 8 REG 9 - 10 32 - ERROR The HI-1575 is a low power CMOS dual transceiver with on-chip Manchester II Encoder and dual Decoder designed to meet the requirements of the MIL-STD-1553 specification. The part acts as a "Smart Transceiver", allowing users to transmit and receive properly encoded MIL-STD-1553 Command and Data words between a 16-bit host processor and dual MIL-STD-1553 data buses. 40 39 ERROR 38 CHA/CHB 37 CLK 36 D0 35 D1 34 D2 33 D3 32 D4 31 - PIN CONFIGURATIONS 31 - CHA/CHB April 2011 FEATURES RCVA - 1 24 - D5 BUSA - 2 23 - D6 BUSA - 3 BUSB - 5 BUSB - 6 21 - GND 20 - D8 19 - D9 D12 - 16 D14 - 14 D13 - 15 D15 - 13 MR - 11 17 - D11 SYNC - 12 18 - D10 REG - 8 STRB - 10 RCVB - 7 TQFP package ! Less than 0.5W maximum power dissipation ! 6 mm x 6 mm 40-pin plastic chip-scale 22 - D7 HI-1575PQI & HI-1575PQT VDD - 4 R/W - 9 ! Compliant to MIL-STD-1553A & B ! 3.3V single supply operation ! On-chip Encoder and Dual Decoder ! Small footprint available in 32-pin plastic 32 Pin TQFP package package option (DS1575 Rev. D) HOLT INTEGRATED CIRCUITS www.holtic.com 04/011 HI-1575 PIN DESCRIPTIONS PIN (TQFP) PULL-UP SYMBOL FUNCTION PULL-DOWN DESCRIPTION 1 RCVA Digital output - Goes high when MIL-STD-1553 word received on Bus A 2 BUSA Analog I/O - MIL-STD-1533 bus driver A, negative signal 3 BUSA Analog I/O - MIL-STD-1553 bus driver A, positive signal 4 VDD Power supply - +3.3 VDC 5, BUSB Analog I/O - MIL-STD-1533 bus driver B, negative signal MIL-STD-1553 bus driver B, positive signal 6 BUSB Analog I/O - 7 RCVB Digital output - 8 REG Digital input 12K pull-down 9 R/W Digital input 12K pull-up 10 STRB Digital input 12K pull-up 11 MR Digital input 12K pull-down Goes high when MIL-STD-1553 word received on Bus B Selects Status & Mode Register when high, or Data registers when low Controls data and sync direction during read or write operations Strobe. Timing input to control register read and write operations Pulse high to reset the HI-1575 12 SYNC Digital I/O 12K pull-down Selects transmit sync type on write, indicates received sync type on read. 13-20, 22-29 D15:D0 Digital I/O 12K pull-down Data bus. D15 (MSB) corresponds to MIL-STD-1553 bit 4 21 GND Power supply - 30 CLK Digital input - 31 CHA/CHB Digital Input 12K pull-down 32 ERROR Digital output - Ground 12 MHz clock Selects MIL-STD-1553 Bus A or Bus B Goes high when a received MIL-STD-1553 word has an encoding error FUNCTIONAL DESCRIPTION Figure 1 shows a simplified block diagram of the HI-1575. The MR (Master Reset) input should be pulsed high to initialize the Manchester II Encoder and Decoders. MR also clears the Receive Data registers, RXA and RXB, and sets the Status & Mode register to its default state as described in figure 2. The CLK input requires a 12.0 MHz clock signal. CLK is used to derive the 1.0 us bit period for MIL-STD-1553 data transmission, as well to provide the master clock for the Manchester II encoder and the decoder's receiver sampling logic. STATUS & MODE REGISTER The HI-1575 is configured by writing bits 0 - 5 of the Status & Mode (SAM) register. Refer to figure 2 for a complete description. SAM bits 0 - 5 are read/write allowing the user to verify the chip's configuration at any time by reading the SAM. SAM is accessed by performing a read or write cycle with the REG input high. SAM bits 6 - 15 are read-only and are used to provide status information. To minimize the number of hardware control inputs, SAM bit 5 (Channel A/B select) is logically 'OR'ed with the CHA/CHB input pin. To select between MIL-STD-1553 bus A or B, the user may either tie the CHA/CHB pin low and select buses using SAM bit 5 (software control), or program SAM bit 5 to a zero and use the CHA/CHB pin to select the active bus (hardware control). Similarly, the SYNC I/O pin may be left open-circuit allowing the transmitter sync to be programmed into SAM bit 4, or SAM bit 4 can be set to zero and the SYNC pin used to set the transmitted SYNC type. Note that SYNC is an I/O pin. It is an input when writing data to the HI-1575 transmit data register (TX), and an output when reading data from the HI-1575 receivers (RXA and RXB). The SYNC pin must not be shorted directly to VDD or GND. An internal pull-down resistor allow the SYNC pin to be left open-circuit if the user opts for purely software control. TRANSMITTER Data words to be transmitted on the MIL-STD-1553 data bus are written to the TX register by pulsing STRB low while R/W is low and REG is low. The logical OR of the CHA/CHB input pin and SAM bit 5 (CHAN) during the write cycle determines whether the word is output on MIL-STD-1553 bus A or B. Setting CHA/CHB OR CHAN to a zero selects bus A, and a one selects bus B. The logical OR of the SYNC pin and SAM bit 4 (TXSYNC) during the write cycle defines whether the transmitted word is a MIL-STD-1553 Command or Data word. Setting SYNC to a one causes a Command (or Status) sync to be generated. Setting SYNC to zero selects a Data sync. Note that the SYNC pin is bidirectional. It should be treated as an extension to the 16-bit bidirectional databus (D15:D0) in terms of I/O switching and timing. The HI-1575 automatically calculates and appends the correct parity bit to the transmitted word. Each word is assigned odd parity as required by MIL-STD-1553. HOLT INTEGRATED CIRCUITS 2 HI-1575 4 VDD 30 REG 2 8 CHA/CHB 11 5 6 RXA DATABUS 12 BUSA BUSB BUSB Decoder A 1 RXB RCVA 3 31 13-20, 22-29 SYNC BUSA Encoder TX MR 9 SHIFT R/W 10 SHIFT STRB SHIFT CLK Decoder B 7 6 10 ERROR 32 STATUS & MODE RCVB 21 GND Note: Pin numbers reflect QFP package FIGURE 1. HI-1575 BLOCK DIAGRAM To transmit contiguous words, a second write to the TX register must occur no earlier than 3.5 us and no later than 18.5 us after the first TX write. SAM bit 15 (SENDDATA) is high during this period and may be used as a flag to indicate when the HI-1575 is ready to accept the next data write for contiguous transmission. When transmitting a message of three or more words, the third and subsequent write operations should occur every 20.0 us so as to avoid over-writing the previous data before it is transferred to the transmitter's shift register. Figure 3 shows a timing diagram for transmit operations. The transmitter outputs are either direct or transformer coupled to the MIL-STD-1553 data bus. Both coupling methods produce a nominal voltage on the main MIL-STD-1553 bus of 7.5 volts peak-to-peak, line-to-line. Figure 6 shows bus coupling examples. One or both transmitters may be disabled by writing a '1' into SAM register bits 0 or 1 (TXDISA, TXDISB). When disabled, the host interface works as normal, but there is no output from the BUSA and BUSA (BUSB and BUSB) pins. RECEIVER The HI-1575's two receivers continuously monitor both MIL-STD-1553 data busses. Bi-phase differential data words are accepted from the MIL-STD-1553 bus through the same direct or transformer coupled interface as the transmitter. Each receiver’s differential input stage drives a filter and threshold comparator that presents data to the decoders. The decoder logic checks the incoming word for correct encoding, bit count and parity. If a valid MIL-STD-1553 word is received, the RCVA or RCVB output goes high and the 16-bit received word is transferred to the RXA or RXB register. The HI-1575 ERROR output goes high whenever an encoding error is detected on either bus. If a received word has an encoding error, then SAM bits 10 or 14 (ERRORA, ERRORB) are set high, and the corresponding RCVA or RCVB pin is not asserted. To minimize the number of pins necessary to interface the HI-1575, the state of RCVA and RCVB can also be read from SAM bits 7 and 11. HOLT INTEGRATED CIRCUITS 3 SE N ER DD R AT G OR A AP B R B SY R NC C B V ER B R G OR AP A R A SY R NC C A V N A ot u C se H d AN TX S R YN EN C R B EN TX A D TX ISB D IS A HI-1575 STATUS & MODE REGISTER (SAM) 0 15 14 13 12 11 10 9 MSB 8 7 6 5 4 3 2 1 0 LSB Bit Name R/W 0 TXDISA R/W 0 Writing TXDISA to a '1' disables the transmitter for MIL-STD-1553 bus A 1 TXDISB R/W 0 Writing TXDISB to a '1' disables the transmitter for MIL-STD-1553 bus B 2 RENA R/W 1 Setting RENA to a '1' enables the receiver for MIL-STD-1553 bus A. A '0' disables the receiver causing the HI-1575 to ignore all activity on bus A. 3 RENB R/W 1 Setting RENB to a '1' enables the receiver for MIL-STD-1553 bus B. A '0' disables the receiver causing the HI-1575 to ignore all activity on bus B. 4 TXSYNC R/W 0 The TXSYNC bit is logically ORed with the SYNC input pin during host write cycles to the Transmit Data Register (TX). If TXSYNC OR SYNC is a '1' the transmitter prefixes the transmitted word with a MIL-STD-1553 Command Sync. If TXSYNC OR SYNC is a '0' during a write to TX, then the transmitted word has a MIL-STD-1553 Data Sync. 5 CHAN R/W 0 The CHAN bit is logically ORed with the CHA/CHB input pin and the result used to Select between MIL-STD-1553 bus A or B during write transfers to the TX register, or reading data from the RX registers. When CHAN OR CHA/CHB is a '0' during a transmit operation, data is transmitted on MIL-STD-1553 bus A. When the result is a '1', MIL-STD-1553 bus B is selected. During HI-1575 data read cycles, if CHAN OR CHA/CHB is a '0', the RXA register is accessed, and if CHAN OR CHA/CHB is a '1' then the data is read from RXB. 6 - Read-only 0 Not used. Internally set to '0'. 7 RCVA Read-only 0 This bit reflects the state of the RCVA output pin. RCVA goes high whenever a new word is received on MIL-STD-1553 bus A. The received word may be read by the host from the RXA register. RCVA is reset on reading RXA or if the HI-1575 detects a new word arriving on bus A. If the data words are contiguous, then RCVA will be high for about 3 us before the new word resets it. The data is still available in the RXA register and may be retreived any time up until the RCVA flag goes high again. If the user does not read the data, the word is lost when the RCVA flag goes high on reception of the next word. 8 RSYNCA Read-only 0 RSYNCA indicates the Sync of the last MIL-STD-1553 word received on bus A. RSYNCA is a '0' for a Data sync, and a '1' for a Command Sync. When the RXA register is read, the RSYNCA value is also output on the SYNC I/O pin. 9 GAPA Read-only 0 GAPA is a '1' when there is no activity detected on MIL-STD-1553 bus A, for example during an inter-message gap. GAPA is a '0' whenever the HI-1575 detects bus traffic. 10 ERRORA Read-only 0 ERRORA goes high when the HI-1575 Manchester decoder receives an incorrectly encoded word on MIL-STD-1553 bus A 11 Read-only 0 Same function as RCVA but for MIL-STD-1553 bus B. RCVB Default Description 12 RSYNCB Read-only 0 Same function as RSYNCA but for MIL-STD-1553 bus B. 13 GAPB Read-only 0 Same function as GAPA but for MIL-STD-1553 bus B. 14 ERRORB Read-only 0 Same function as ERRORA but for MIL-STD-1553 bus B. 15 SENDDATA Read-only 1 SENDDATA goes high approximately 3.5 us after the start of a MIL-STD-1553 word transmission. SENDATA goes low approximately 18.5 us after the start of a MIL-STD-1553 word transmission. If new a new data word is written to the TX register while SENDDATA is high, that word will be transmitted contiguously after the currently transmitting word. FIGURE 2. STATUS AND MODE REGISTER HOLT INTEGRATED CIRCUITS 4 HI-1575 Write TX, (MIL-STD-1553 Status word) Write TX, (MIL-STD-1553 Data word) Read SAM, check SENDDATA=1 D15 - D0 TXDATA DON’T CARE SAM TXDATA DON’T CARE R/W VALID CHA/CHB DON’T CARE SYNC DON’T CARE REG DON’T CARE VALID STRB SYNC BUSA (B) SYNC 15 14 13 3 3 2 1 0 P SYNC SYNC 15 FIGURE 3. EXAMPLE TRANSMIT OPERATION Read RXA or RXB, (MIL-STD-1553 Data word) Read SAM BUSA (B) SYNC SYNC 15 14 13 12 2 1 0 P SYNC SYNC 15 14 13 RCVA (B) R/W DON’T CARE CHA/CHB DON’T CARE REG DON’T CARE VALID STRB D15 - D0 SAM SYNC RXA (B) SYNC FIGURE 4. EXAMPLE RECEIVE OPERATION CHAN OR CHA/CHB 0 1 X REG 0 0 1 Register Receiver A Data (RXA) Receiver B Data (RXB) Status & Mode Register (SAM) FIGURE 5. HI-1575 REGISTER MAP HOLT INTEGRATED CIRCUITS 5 12 HI-1575 The host reads the received word from the HI-1575 RXA or RXB register. The data word is read by pulsing STRB low, while R/W is high and REG is low. Figure 4 shows an example receive operation. The SYNC output indicates whether the word had a Command Sync (SYNC=1) or Data Sync (SYNC=0). SAM register bits 8 and 12 (RSYNCA and RSYNCB) retain the Sync values for the last word received on each bus. MIL-STD-1553 BUS CONNECTION The HI-1575 includes on-chip MIL-STD-1553 analog transceivers which are designed to drive the primary winding of a 1:2.5 turns-ratio MIL-STD-1553 isolation transformer. Figure 6 shows how the HI-1575 may be connected to the MIL-STD-1553 data bus as either a direct coupled stub (Bus A example), or a transformer coupled stub (Bus B example). Holt Integrated Circuits offers a wide range of single-core and dual-core coupling transformers suitable for use with the HI-1575. SAM bits 2 or 3 (RENA, RENB) can be used to independently enable or disable each receiver. Writing a '1' to RENA enables receiver A. A '0' disables the receiver. RENB performs the same function for the MIL-STD-1553 bus B. Note that because each receiver is internally connected to its transmitter, when a MIL-STD-1553 word is transmitted by the HI-1575 it will also be received on the same channel. This feature allows the terminal to self-monitor data transmitted to the MIL-STD-1553 data bus. 3.3 V VDD CLK 12.0 MHz 55 Ohms BUSA STRB MIL-STD-1553 BUS A (Direct Coupled) R/W 55 Ohms BUSA CHA/CHB 1:2.5 REG Host CPU D15:D0 SYNC HI-1575 RCVA RCVB 52.5 Ohms BUSB MIL-STD-1553 BUS B (Transformer Coupled) ERROR MR 52.5 Ohms BUSB 1:2.5 1:1.4 GND FIGURE 6. MIL-STD-1553 BUS CONNECTION Bit Period Command Word Data Word Status Word 1 2 3 SYNC 4 5 6 7 8 TERMINAL ADDRESS 9 R/T SYNC SYNC 10 11 12 13 14 15 16 17 18 19 20 SUBADDRESS / MODE DATA WORD COUNT P P DATA WORD SYNC SYNC TERMINAL ADDRESS ME CODE FOR FAILURE MODES SYNC FIGURE 7. MIL-STD-1553 WORD FORMATS HOLT INTEGRATED CIRCUITS 6 TF P HI-1575 TIMING DIAGRAMS BIT PERIOD BIT PERIOD BIT PERIOD t R1 BUSA - BUSA (BUSB - BUSB) t R1 COMMAND SYNC t R1 BUSA - BUSA (BUSB - BUSB) t R1 DATA SYNC t R3 BUSA - BUSA (BUSB - BUSB) t R2 t R2 t R3 ONE t R2 ZERO ONE FIGURE 8. MIL-STD-1553 BUS RECEIVER TIMING MID-SYNC MID-SYNC MID-PARITY MID-SYNC MID-PARITY MID-PARITY 1553 BUS COMMAND DATA tFH WORD WITH ERROR tFH tFH RCVA(B) tFR tFR ERROR tFR tRF tRF tRF STRB (Read RXA) (Read RXA) (Read SAM) FIGURE 9. HI-1575 RECEIVER TIMING REG REG VALID VALID tRWH tRWS tRRH tRRS tSTR tSTR STRB STRB tDWS tDRV tDWH D15:0 SYNC VALID tDRT VALID D15:0 SYNC tCHRS tCHWS tCHWH CHA/CHB tCHRH CHA/CHB tRWRS tRWWS tRWRH tRWWH R/W R/W Figure 10. DATABUS TIMING - WRITE. Figure 11. DATABUS TIMING - READ HOLT INTEGRATED CIRCUITS 7 HI-1575 RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS Supply voltage (VDD) Logic input voltage range Receiver differential voltage Driver peak output current Power dissipation at 25°C Solder Temperature Junction Temperature Storage Temperature Supply Voltage VDD....................................... 3.3V... ±5% -0.3 V to +5 V -0.3 V DC to +3.6 V 50 Vp-p +1.0 A 1.0 W 275°C for 10 sec. 175°C -65°C to +150°C Temperature Range Industrial Screening.........-40°C to +85°C Hi-Temp Screening........-55°C to +125°C NOTE: Stresses above absolute maximum ratings or outside recommended operating conditions may cause permanent damage to the device. These are stress ratings only. Operation at the limits is not recommended. DC ELECTRICAL CHARACTERISTICS VDD = 3.3 V, GND = 0V, TA = Operating Temperature Range (unless otherwise specified). PARAMETER SYMBOL CONDITION MIN TYP MAX UNITS 3.15 3.30 3.45 V Operating Voltage VDD Total Supply Current ICC1 Not Transmitting 4 10 mA ICC2 Transmit one channel @ 50% duty cycle 225 250 mA ICC3 Transmit one channel @ 100% duty cycle 425 500 mA 0.06 W 0.5 W Power Dissipation PD1 Not Transmitting PD2 Transmit one channel @ 100% duty cycle Min. Input Voltage (HI) VIH Digital inputs Max. Input Voltage (LO) VIL Digital inputs Min. Input Current (HI) IIH Digital inputs (without pull-down) Max. Input Current (LO) IIL Digital inputs (without pull-up) Pull-up / Pull-down current IPUD Digital inputs and data bus Min. Output Voltage (HI) VOH IOUT = -1.0mA, Digital outputs Max. Output Voltage (LO) VIH IOUT = 1.0mA, Digital outputs RECEIVER 0.3 70% VDD 30% VDD 20 µA -20 µA 275 uA 90% VDD 10% VDD (Measured at Point “AD“ in Figure 12 unless otherwise specified) Input resistance Input capacitance RIN Differential CIN Differential 2 5 Common mode rejection ratio CMRR 40 Input common mode voltage VICM -10.0 Detect VTHD No Detect VTHND Threshold Voltage - Direct-coupled Theshold Voltage - Transformer-coupled Detect VTHD No Detect VTHND Kohm 1 Mhz Sine Wave (Measured at Point “AD“ in Figure 12) 1.15 1 MHz Sine Wave (Measured at Point “AT“ in Figure 13) 0.86 pF dB +10.0 V-pk Vp-p 0.28 Vp-p Vp-p 0.20 Vp-p 6.0 9.0 Vp-p 18.0 27.0 Vp-p 10.0 mVp-p -90 90 mV -250 250 mV TRANSMITTER(Measured at Point “AD” in Figure 12 unless otherwise specified) Output Voltage Direct coupled VOUT Transformer coupled VOUT Output Noise VON Output Dynamic Offset Voltage Direct coupled VDYN Transformer coupled VDYN 35 ohm load (Measured at Point “AD“ in Figure 12) 70 ohm load (Measured at Point “AT“ in Figure 13) Differential, inhibited 35 ohm load (Measured at Point “AD“ in Figure 12) 70 ohm load (Measured at Point “AT“ in Figure 13) HOLT INTEGRATED CIRCUITS 8 HI-1575 AC ELECTRICAL CHARACTERISTICS VDD = 3.3 V, GND = 0V, TA =Operating Temperature Range (unless otherwise specified) PARAMETER TRANSMITTER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS (Measured at Point “AD” in Figure 12) RiseTtime tr 35 ohm load 100 300 ns Fall Time tf 35 ohm load 100 300 ns RECEIVER (See figures 8 and 9) Sync Transition Span tR1 1500 ns Short Data Transition Span Long Data Transition Span tR2 500 ns tR3 1000 Delay Mid-Parity to Flag Set tFH Flag Setup Time to Read tFR Flag Reset Delay tRF DATA BUS TIMING - WRITE ns 2500 0 ns ns 60 ns (See figure 10) Strobe STRB Pulse Width tSTR 50 ns REG Write Setup Time tRWS 50 ns REG Write Hold Time tRWH 10 ns Databus / SYNC Write Setup Time tDWS 50 ns Databus / SYNC Write Hold Time tDWH 10 ns CHA/CHB Write Setup Time tCHWS 50 ns CHA/CHB Write Hold Time tCHWH 10 ns R/W Write Setup Time tRWWS 50 ns R/W Write Hold Time tRWWH 10 ns Strobe STRB Pulse Width tSTR 50 ns REG Read Setup Time tRRS 50 ns REG Read Hold Time tRRH 10 Data Read to Databus Valid tDRV DATA BUS TIMING - READ (See figure 11) ns 60 ns 60 ns Data Read to Databus Tri-state tDRT 0 CHA/CHB Read Setup Time tCHRS 50 ns CHA/CHB Read Hold Time tCHRH 10 ns R/W Read Setup Time tRWRS 50 ns R/W Read Hold Time tRWRH 10 ns HI-1575 TRANSMITTER 1:2.5 55 W BUSA/B 35 W BUSA/B Isolation Transformer 55 W Point “AD“ 55 W 2.5:1 35 W 55 W Point “AD“ Isolation Transformer FIGURE 12. DIRECT COUPLED TEST CIRCUITS HOLT INTEGRATED CIRCUITS 9 HI-1575 RECEIVER HI-1575 HI -1575 TRANSMITTER 1:2.5 Point “AT” 1:1.4 BUSA/B 52.5 W (.75 Zo) 35 W (.5 Zo) BUSA/B 52.5 W (.75 Zo) Isolation Transformer Coupling Transformer 1.4:1 Point “AT” 2.5:1 52.5 W (.75 Zo) HI-1575 RECEIVER 35 W (.5 Zo) 52.5 W (.75 Zo) Coupling Transformer Isolation Transformer FIGURE 13. TRANSFORMER COUPLED TEST CIRCUITS HEAT SINKING THE LEADLESS PLASTIC CHIP CARRIER PACKAGE The HI-1575PCI/T is packaged in a 40 pin leadless plastic chip carrier (QFN). This package has a metal heat sink pad on its bottom surface, which should be soldered to the printed circuit board for optimum thermal dissipation. The package heat sink is electrically isolated and may be soldered to any convenient power plane or ground plane. Redundant "vias" between the exposed board surface and buried power or ground plane will enhance thermal conductivity. APPLICATIONS NOTE Holt Applications Note AN-500 provides circuit design notes regarding the use of Holt MIL-STD-1553 data communications devices. Layout considerations, as well as recommended interface and protection components are included. HOLT INTEGRATED CIRCUITS 10 HI-1575 THERMAL CHARACTERISTICS PACKAGE STYLE CONDITION qJA HI-1575PQI / T 32 pin PQFP Mounted on circuit board 59.5 °C / W HI-1575PCI / T 40 pin LPCC Heat sink pad soldered 27.5 °C / W PART NUMBER ORDERING INFORMATION HI - 1575 xx x x PART NUMBER LEAD FINISH Tin / Lead (Sn / Pb) Solder Blank 100% Matte Tin (Pb-free, RoHS compliant) F PART NUMBER TEMPERATURE RANGE FLOW BURN IN I -40°C TO +85°C I NO T -55°C TO +125°C T NO M -55°C TO +125°C M YES PART NUMBER PQ PC PACKAGE DESCRIPTION 32 PIN PLASTIC PQFP (32PTQS) 40 PIN CHIP SCALE PACKAGE (40PCS) (PCM not available) HOLT INTEGRATED CIRCUITS 11 HI-1575 REVISION HISTORY P/N DS1575 Rev Date D 04/20/11 Description of Change Added REG input to block diagram. Corrected D.C. Electrical Characteristics Table and package thickness dimension for the 32PTQS. HOLT INTEGRATED CIRCUITS 12 PACKAGE DIMENSIONS 32 PIN PLASTIC QUAD FLAT PACK (PQFP) inches (millimeters) Package Type: 32PQS .0057 ± .002 (0.145 ± .06) .354 BSC SQ (9.00) .0315 BSC (0.80) .276 BSC SQ (7.00) .015 ± .003 (0.375 ± .075) .024 ± .006 (0.60 ± .15) .039 ± .002 (1.0 ± .05) .006 ± .002 (0.14 ± .06) R See Detail A 0° £ Q £ 7° .047 max (1.20) .004 ± .002 (0.10 ± .05) .003 R min (.08) Detail A BSC = “Basic Spacing between Centers” is theoretical true position dimension and has no tolerance. (JEDEC Standard 95) 40-PIN PLASTIC CHIP-SCALE PACKAGE millimeters Electrically isolated heat sink pad on bottom of package. Connect to any ground or power plane for optimum thermal dissipation. 6.00 BSC Package Type: 40PCS 4.15 ± .15 0.50 BSC 6.00 BSC Top View 4.15 ± .15 Bottom View 0.25 typ 0.55 ± .10 See Detail A 1.00 max 0.2 typ 0.90 ± .10 BSC = “Basic Spacing between Centers” is theoretical true position dimension and has no tolerance. (JEDEC Standard 95) HOLT INTEGRATED CIRCUITS 13 0.02 typ Detail A
HI-1575PQI 价格&库存
很抱歉,暂时无法提供与“HI-1575PQI”相匹配的价格&库存,您可以联系我们找货
