austriamicrosystems AG
is now
ams AG
The technical content of this austriamicrosystems datasheet is still valid.
Contact information:
Headquarters:
ams AG
Tobelbaderstrasse 30
8141 Unterpremstaetten, Austria
Tel: +43 (0) 3136 500 0
e-Mail: ams_sales@ams.com
Please visit our website at www.ams.com
Data Sheet
AS1970 - AS1975
L o w - Vo l ta g e S i n g l e / D u a l / Q u a d C o m pa r a t o r s
1 General Description
2 Key Features
CMOS Push/Pull Output Sinks and Sources 8mA
(AS1970/AS1972/AS1974)
CMOS Open-Drain Output Voltage Extends Beyond
VCC (AS1971/AS1973/AS1975)
Quiescent Supply Current: 8.5µA per Comparator
Internal Hysteresis: 3mV
3V/5V Logic-Level Translation
Single-Supply Operation: 2.5 to 5.5V
The comparators are available as the standard products
listed in Table 1.
Common-Mode Input Voltage Range Extends
250mV Above the Rails
Table 1. Standard Products
Low Propagation Delay: 300ns
Output Type
Minimized Overall Power Consumption
Push/Pull
Supply Current @1MHz Switching Frequency: 80µA
Open-Drain
No Phase Reversal for Overdriven Inputs
Package Types:
- 5-pin SOT23 – AS1970/AS1971
- 8-pin MSOP – AS1972/AS1973
- 14-pin TSSOP – AS1974/AS1975
Model
lv
am
lc s
on A
te G
nt
st
il
Low input bias current (1.0pA, typ), low input offset voltage (0.5mV, typ), and internal hysteresis (3mV) make
these comparators ideal for low-power single-cell applications including power-management and power-monitoring systems.
al
id
The AS1970 - AS1975 are single/dual/quad comparators that operate with supplies from 2.5 to 5.5V making
them perfect for all 3- and 5-volt applications. The comparators can also operate with dual supplies (±1.25 to
±2.75V), and require very little supply current (down to
8.5µA) with minimal propagation delay (300ns).
The AS1970/AS1972/AS1974 push/pull output can sink
or source current.
The AS1971/AS1973/AS1975 open-drain output can be
pulled beyond VCC to a maximum of 5.5V > VEE. These
open-drain versions are ideal for logic-level translators
or bipolar-to-unipolar converters.
3 Applications
The AS1970/AS1971 are available in a 5-pin SOT23
package. The AS1972/AS1973 are available in a 8-pin
MSOP package. The AS1974/AS1975 are available in a
14-pin TSSOP package.
The devices are ideal for battery-powered systems,
mobile communication devices, zero-crossing detectors,
window comparators, level translators, threshold detectors/discriminators, ground/supply-sensing applications,
IR receivers or any other space-limited application with
low power-consumption requirements.
ca
Large internal output drivers allow Rail-to-Rail output
swings with loads of up to 8mA.
ch
ni
Figure 1. Block Diagrams
INA+
INA+
IN+
Te
IN-
VCC
AS1970/AS1971
OUT
INA-
INAOUTA
INB+
INB-
INB+
VEE
INB-
INC+
OUTB
INCIND+
VCC
AS1972/AS1973
VEE
INDVCC
www.austriamicrosystems.com
Revision 1.02
OUTA
OUTB
OUTC
AS1974/AS1975
OUTD
VEE
1 - 18
AS1970
Data Sheet
- Pinout and Packaging
4 Pinout and Packaging
Pin Assignments
Figure 2. Pin Assignments (Top View)
8 VCC
OUTA 1
5 VEE
7 OUTB
INA- 2
VCC 2
AS1972/
AS1973
AS1970/
AS1971
INA- 2
INA+ 3
VCC 4
6 INB-
INA+ 3
INB+ 5
5 INB+
VEE 4
INB- 6
13 IND-
12 IND+
AS1974/
AS1975
OUTB 7
8-pin MSOP
5-pin SOT23
11 VEE
10 INC+
am
lc s
on A
te G
nt
st
il
4 IN-
IN+ 3
al
id
OUT 1
14 OUTD
lv
OUTA 1
9 INC-
8 OUTC
14-pin TSSOP
Pin Descriptions
Table 2. Pin Descriptions
Description
IN-
Comparator Inverting Input
IN+
Comparator Non-Inverting Input
INA-
Comparator A Inverting Input
INA+
Comparator A Non-Inverting Input
INB-
Comparator B Inverting Input
INB+
Comparator B Non-Inverting Input
INC-
Comparator C Inverting Input
INC+
Comparator C Non-Inverting Input
IND-
Comparator D Inverting Input
IND+
Comparator D Non-Inverting Input
ni
See Figure 2
Pin Name
ca
Pin Number
OUT
Comparator A Output
OUTB
Comparator B Output
OUTC
Comparator C Output
OUTD
Comparator D Output
ch
Te
Comparator Output
OUTA
VCC
Positive Supply Voltage
VEE
Negative Supply Voltage
Revision 1.02
2 - 18
AS1970
Data Sheet
- Absolute Maximum Ratings
5 Absolute Maximum Ratings
Stresses beyond those listed in Table 3 may cause permanent damage to the device. These are stress ratings only,
and functional operation of the device at these or any other conditions beyond those indicated in Section 6 Electrical
Characteristics on page 4 is not implied. Exposure to absolute maximum rating conditions for extended periods may
affect device reliability.
Table 3. Absolute Maximum Ratings
Max
Units
7
V
-0.3
VCC
+ 0.3
V
-0.3
VCC
+ 0.3
V
-0.3
+7
V
10
s
INx+, INx- to VEE
OUTx to VEE
OUTx Short-Circuit Duration to VEE or VCC
5-pin SOT23
571
mW
Derate 7.1mW/ºC above +70ºC
8-pin MSOP
727
mW
Derate 9.1mW/ºC above +70ºC
14-pin TSSOP
727
mW
-40
+85
ºC
+150
ºC
-65
+150
ºC
am
lc s
on A
te G
nt
st
il
Continuous Power
Dissipation
(TAMB = +70ºC)
Comments
al
id
Min
lv
Parameter
Supply Voltage VCC to VEE
Operating Temperature Range
Junction Temperature Range
Storage Temperature Range
260
ºC
Te
ch
ni
ca
Package Body Temperature
The reflow peak soldering temperature
(body temperature) specified is in
accordance with IPC/JEDEC J-STD020C “Moisture/Reflow Sensitivity
Classification for Non-Hermetic Solid
State Surface Mount Devices”.
The lead finish for Pb-free leaded
packages is matte tin (100% Sn).
Revision 1.02
3 - 18
AS1970
Data Sheet
- Electrical Characteristics
6 Electrical Characteristics
VCC = 2.7 to 5.5V, VEE = 0V, VCM = 0V, TAMB = -40 to +85ºC (unless otherwise specified). Typ values are at TAMB = +25ºC.
Table 4. Electrical Characteristics
Parameter
Conditions
Min
VCC
Supply Voltage
Inferred from PSRR test
2.5
Supply Current
VCC = 5V, No Load, AS1974/AS1975
36
VCC = 5V, No Load, AS1972/AS1973
18
VCC = 5V, No Load, AS1970, AS1971
11
VCC = 2.7V, No Load, AS1974/AS1975
34
VCC = 2.7V, No Load, AS1972/AS1973
17
VCC = 2.7V, No Load, AS1970, AS1971
Power-Supply Rejection Ratio
VCMR
Common-Mode Voltage Range
2.5V ≤ VCC ≤ 5.5V, TAMB = +25ºC
Units
5.5
V
64
32
19
60
VOS
Input Offset Voltage
1
10
55
18
80
dB
TAMB = +25ºC
VEE
- 0.25
VCC
+ 0.25
TAMB = -40 to +85ºC
VEE
VCC
Full Common-Mode Range,
TAMB = +25ºC
2
±0.5
TAMB = -40 to +85ºC
IB
Input Bias Current
V
±6
mV
±8
Input Hysteresis
VHYS
µA
30
am
lc s
on A
te G
nt
st
il
PSRR
Max
lv
IDD
Typ
al
id
Symbol
±3
3, 4
0.001
10
mV
nA
IOS
Input Offset Current
0.5
pA
CIN
Input Capacitance
3.5
pF
CMRR
Common-Mode Rejection Ratio
TAMB = +25ºC
80
dB
ILEAK
Output Leakage Current
AS1971/AS1973/AS1975 only
ni
OUTx Output Voltage Low
Te
ch
VOL
VOH
OUTx Output Voltage High
(AS1970/AS1972/AS1974 only)
1.0
Sourcing or Sinking, VOUT = VEE or VCC,
VCC = 5V
60
VCC = 2.7V
18
VCC = 5V, ISINK = 8mA,
TAMB = +25ºC
0.2
ca
ISC
Output Short-Circuit Current
52
TAMB = -40 to +85ºC
mA
0.4
0.55
V
VCC = 2.7V, ISINK = 3.5mA,
TAMB = +25ºC
0.15
TAMB = -40 to +85ºC
0.3
0.4
TAMB = +25ºC
4.6
TAMB = -40 to +85ºC
4.45
TAMB = +25ºC
2.4
TAMB = -40 to +85ºC
2.3
Revision 1.02
µA
4.85
V
2.55
4 - 18
AS1970
Data Sheet
Table 4. Electrical Characteristics (Continued)
tRISE
OUTx Rise Time
Conditions
OUTx Fall Time
tFALL
Typ
VCC = 5V, CLOAD = 15pF
32
VCC = 5V, CLOAD = 50pF
50
VCC = 5V, CLOAD = 200pF
80
22
32
60
AS1970/AS1972/AS1974 only,
CLOAD = 15pF, 10mV Overdrive
400
CLOAD = 15pF, 100mV Overdrive
300
AS1971/AS1973/AS1975 only,
CLOAD = 15pF, RPULLUP = 5.1kΩ,
10mV Overdrive
Max
Propagation Delay
tPD+
ns
400
AS1971/AS1973/AS1975 only, CLOAD =
100mV Overdrive
300
420
270
Power-Up Time
tPU
Units
ns
am
lc s
on A
te G
nt
st
il
tPD-
Min
al
id
Parameter
lv
Symbol
ns
µs
Te
ch
ni
ca
1. Inferred from the VOS test. Both or either inputs can be driven 0.3V beyond either supply rail without output
phase reversal.
2. VOS is defined as the center of the hysteresis band at the input.
3. IB is defined as the average of the two input bias currents (IB-, IB+).
4. Guaranteed by design.
Revision 1.02
5 - 18
AS1970
Data Sheet
- Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s
7 Typical Operating Characteristics
Figure 3. Supply Current vs. Temperature
(per comparator)
Figure 4. Supply Current vs. Output Transition
Frequency (per comparator)
1000
12
VCC = 5V
10
VCC = 3V
8
6
100
VCC = 5V
10
VCC = 2.7V
lv
14
1
-40
-20
60
80
100
am
lc s
on A
te G
nt
st
il
-60
0.1
Temp (°C)
e
VCC = 2.7V
VCC = 5V
10
1
0.1
0.01
0.1
1
10
VCC = 2.7V
10
ca
ni
1
60
50
40
Te
1
10
100
3.00
2.90
VCC = 5V
30
VCC = 2.7V
Figure 8. VOS vs. Temperature
Offset Voltage (mV)]
70
VCC = 5V
Output Source Current (mA)
ch
Output Sink Current (mA) e
80
1000
100
0.1
0.01
100
Figure 7. ISINK vs. Temperature
90
100
1000
100
10
Figure 6. VOH vs. ISOURCE ; VIN+ > VIN-
Output High Voltage (mV)
Output Low Voltage (mV) e
100
1
Output Transition Frequency (kHz)
Figure 5. VOL vs. ISINK; VIN+ < VIN1000
al
id
16
Supply Current (µA)e
Supply Current (µA) e
18
10
2.80
2.70
2.60
2.50
2.40
2.30
2.20
2.10
-60 -40 -20
60
80
100
-60 -40 -20
Temperature (°C)
60
80 100
Temperature (°C)
Revision 1.02
6 - 18
AS1970
Data Sheet
Figure 9. tPD+ vs. CLOAD; VCC = 3V, VOD = 50mV
Figure 10. tPD+ vs. CLOAD; VCC = 5V, VOD = 50mV
450
To VOUT = 50% of Final Value
450
400
350
To VOUT = 10% of Final Value
300
250
400
350
al
id
500
300
250
200
400
600
800
1000
Capacitive Load (pF)
600
800
1000
am
lc s
on A
te G
nt
st
il
Figure 12. tPD+ vs. VOD
600
280
Propagation Delay Pt D+ (ns) ]
270
260
250
240
500
400
VCC = 2.7V
300
VCC = 5V
200
-20
60
80
100
Temperature (°C)
40
80
VCC
Out
50mV/Div
2V/Div
ni
ch
Out
Te
160
200
Figure 14. Power-Up Delay; VOD = 50mV
ca
Figure 13. 1MHz Response; VOD = 50mV
400ns/Div
120
Input Overdrive (mV)
2V/Div
-40
2V/Div
290
400
Figure 11. tPD+ vs. Temperature; VOD = 50mV
In+
lv
550
4µs/Div
Revision 1.02
7 - 18
2V/Div
al
id
In+
100ns/Div
Te
ch
ni
ca
am
lc s
on A
te G
nt
st
il
100ns/Div
lv
2V/Div
In+
Out
50mV/Div
Figure 16. tPD-; VOD = 50mV
50mV/Div
Figure 15. tPD+; VOD = 50mV
Out
AS1970
Data Sheet
Revision 1.02
8 - 18
AS1970
Data Sheet
- Detailed Description
8 Detailed Description
The AS1970 - AS1975 are single/dual/quad low-power, comparators. The devices operate with a supply voltage range
between 2.5 and 5.5V while consuming down to 8.5µA per comparator. Their common-mode input voltage range
extends 0.25V beyond each rail.
Internal hysteresis ensures clean output switching, even with slow input signals. Large internal output drivers allow railto-rail output swing with up to 8mA loads.
al
id
The output stage design minimizes supply-current surges while switching, virtually eliminating the power supply transients typical. The AS1970/AS1972/AS1974 push/pull output stage sinks and sources current, wheras the AS1971/
AS1973/AS1975 open-drain output stage can be pulled beyond VCC to an absolute maximum of 5.5V > VEE.
Input Stage
lv
The input common-mode voltage range extends from -0.25V to (VCC + 0.25V), and the comparators can operate at
any differential input voltage within this voltage range. Input bias (IB) current is 1.0pA (typ) if the input voltage is within
the common-mode voltage range.
Output Stage
am
lc s
on A
te G
nt
st
il
Inputs are protected from over-voltage by internal ESD protection diodes connected to the supply rails. As the input
voltage exceeds the supply rails, these diodes become forward biased and begin to conduct and the bias currents
increase exponentially as the input voltage exceeds the supply rails.
The push/pull and open-drain output stages were designed to provide rail-to-rail operation with up to 8mA loads. Even
at loads of up to 8mA, the supply-current change during an output transition is extremely small (see Figure 4 on page
6). Figure 4 shows the minimal supply-current increase as the output switching frequency approaches 1MHz. This
characteristic eliminates the need for power-supply filter capacitors to reduce glitches created by comparator switching
currents.
Te
ch
ni
ca
Because of the unique design of its output stage, the AS1970 - AS1975 can dramatically increase battery life, even in
high-speed applications.
Revision 1.02
9 - 18
AS1970
Data Sheet
- Application Information
9 Application Information
Figure 17 shows a typical application circuit for the AS1970 - AS1975 comparators.
Figure 17. Typical Application Diagram – Threshold Detector
VIN
al
id
2
4
VCC
IN-
RPULLUP †
AS1970 - AS1975
1
3
lv
OUT
5
IN+
VEE
am
lc s
on A
te G
nt
st
il
Hysteresis (AS1970/AS1972/AS1974)
The AS1970/AS1972/AS1974 have 3mV internal hysteresis. Additional hysteresis can be generated with three resistors using positive feedback (Figure 18), however this method also slows hysteresis response time.
Figure 18. Additional Hysteresis AS1970/AS1972/AS1974
VCC
R3
R1
VIN
R2
VCC
OUT
VEE
VREF
ca
Resistor Selection Example
For the circuit shown in Figure 18, the following steps can be used to calculate values for R1, R2, and R3.
ni
1. Select R3 first. The current through R3 should be at least 1µA to minimize errors caused by leakage current. The
current through R3 at the trip point is:
ch
(VREF - VOUT)/R3
The two possible output states in solving for R3 yields these two formulas:
(EQ 1)
R3 = VREF/1µA
(EQ 2)
R3 = (VREF - VCC)/1µA
(EQ 3)
Te
For example, for VREF = 1.2V and VCC = 5V, the two R3 resistor values are 1.2MΩ and 3.8MΩ. Use the smaller of
the two resulting resistor values; in this case a standard 1.2MΩ resistor should be used for R3.
2. Choose the hysteresis band (VHB). For this example, use VHB = 50mV.
3. Calculate R1 according to the following equation:
R1 = R3(VHB/VCC)
(EQ 4)
Substituting the example values for R3 and VHB gives:
R1 = 1.2MΩ(50mV/5V) = 12kΩ
Revision 1.02
10 - 18
AS1970
Data Sheet
4. Choose the trip point for VIN rising (VTHR) (see page 12). This is the threshold voltage at which the AS1970 AS1975 switches its output from low to high as VIN rises above the trip point. For this example, choose VTHR = 3V.
5. Calculate R2 as:
R2 = 1/[VTHR/(VREF x R1) - (1/R1) - (1/R3)]
(EQ 5)
Substituting the example values gives:
R2 = 1/[3.0V/(1.2V x 12kΩ) - (1/12kΩ) - (1/1.2MΩ)] = 8.05kΩ
al
id
In this example, a standard 8.2kΩ resistor should be used for R2.
6. Verify the trip voltages and hysteresis as:
VTHR = VREF x R1[(1/R1) + (1/R2) + (1/R3)]
(EQ 6)
VTHF = VTHR - (R1 x VCC/R3)
(EQ 7)
Hysteresis = VTHR - VTHF
lv
(EQ 8)
Hysteresis (AS1971/AS1973/AS1975)
am
lc s
on A
te G
nt
st
il
The AS1971/AS1973/AS1975 have 3mV internal hysteresis. Their open-drain outputs require an external pullup resistor (Figure 19), and additional hysteresis can be generated using positive feedback.
Figure 19. Additional Hysteresis AS1971/AS1973/AS1975
VCC
R3
R4
R1
VIN
R2
VCC
OUT
VEE
VREF
For the circuit shown in Figure 19, the following steps can be used to calculate values for R1, R2, R3, and R4:
ca
1. Select R3 according to one of:
R3 = VREF/500µA
(EQ 9)
R3 = (VREF - VCC)/500µA - R4
(EQ 10)
ni
Use the smaller of the two resulting resistor values.
ch
2. Choose the hysteresis band required (VHB). For this example, use 50mV.
3. Calculate R1 as:
R1 = (R3 + R4)(VHB/VCC)
(EQ 11)
Te
4. Choose the trip point for VIN rising (VTHR) (see page 12). This is the threshold voltage at which the comparator
5. Calculate R2 as:
R2 = 1/[VTHR /(VREF x R1) - (1/R1) - 1/(R3 + R4)]
(EQ 12)
6. Verify the trip voltages and hysteresis as follows:
VIN rising: VTHR = VREF x R1 x [1/R1 + 1/R2 + 1/(R3 + R4)]
(EQ 13)
VIN falling: VTHF = VREF x R1 x [1/R1 + 1/R2 + 1/(R3+R4)] - 1/(R3+R4) x VCC
(EQ 14)
(EQ 15)
Revision 1.02
11 - 18
AS1970
Data Sheet
Hysteresis Band
Internal hysteresis creates two trip points (shown in Figure 20): rising input voltage (VTHR) and falling input voltage
(VTHF). The area between the trip points is the hysteresis band (VHB). When the comparator input voltages are equivalent, the hysteresis effectively causes one comparator input to move quickly past the other, thus taking the input out of
the region where oscillation occurs.
In Figure 20 REF has a fixed voltage applied and IN+ is varied. If the inputs are reversed the output will be inverted.
al
id
Figure 20. Threshold Hysteresis Band
Thresholds
IN+
VTHR
Hysteresis
Band
VHB
lv
REF
VTHF
am
lc s
on A
te G
nt
st
il
OUT
Zero-Crossing Detector
Figure 21 shows the AS1970 in a zero-crossing detector circuit. The inverting input is connected to ground, and the
non-inverting input is connected to a 100mVp-p signal source. As the signal at the non-inverting input crosses 0V, the
signal at OUT changes states.
Figure 21. Zero-Crossing Detector
100mVp-p
3
IN+
4
1
OUT
IN-
AS1970
2
5
VCC
VEE
ca
Logic Level Translator
ni
The comparators can be used as a 5V/3V logic translator as shown in Figure 22. The circuit in Figure 22 converts 5Vto 3V-logic levels, and provides the full 5V logic-swing without creating overvoltage on the 3V logic inputs. When the
comparator is powered by a 5V supply, RPULLUP for the open-drain output should be connected to the +3V supply voltage.
For 3V-to-5V logic-level translations, connect the +3V supply voltage to VCC and the +5V supply voltage to RPULLUP.
ch
Figure 22. Logic Level Translator
2
Te
+3/+5V
+3/+5V
VCC
AS1971
100kΩ
4
100kΩ
+5/+3V
Logic In
IN3
RPullup
IN+
1
OUT
+5/+3V
Logic Out
5
VEE
Revision 1.02
12 - 18
AS1970
Data Sheet
Layout Considerations
The AS1970 - AS1975 requires proper layout and design techniques for optimum performance.
Te
ch
ni
ca
am
lc s
on A
te G
nt
st
il
lv
al
id
Power-supply bypass capacitors are not typically needed, although 100nF bypass capacitors should be used when
supply impedance is high, when supply leads are long, or when excessive noise is expected on the supply lines.
Minimize signal trace lengths to reduce stray capacitance.
A ground plane and surface-mount components are recommended.
Revision 1.02
13 - 18
AS1970
Data Sheet
- Package Drawings and Markings
10 Package Drawings and Markings
The AS1970 - AS1975 are available in a 5-pin SOT23 package and an 8-pin MSOP package.
am
lc s
on A
te G
nt
st
il
lv
al
id
Figure 23. 5-pin SOT23 Package
Controlling dimension is millimeters.
Foot length measured at intercept point between datum A and lead surface.
Package outline exclusive of mold flash and metal burr.
Package outline inclusive of solder plating.
Meets JEDEC MO178.
Te
1.
2.
3.
4.
5.
Min
Max
0.90
1.45
0.00
0.15
0.90
1.30
0.30
0.50
0.09
0.20
2.80
3.05
2.60
3.00
1.50
1.75
0.30
0.55
0.95 REF
1.90 REF
0º
8º
ch
Notes:
ni
ca
Symbol
A
A1
A2
b
C
D
E
E1
L
e
e1
α
Revision 1.02
14 - 18
AS1970
Data Sheet
am
lc s
on A
te G
nt
st
il
lv
al
id
Figure 24. 8-pin MSOP Package
Symbol
A
A1
A2
D
Typ
1.10
0.10
0.86
3.00
±Tol
Max
±0.05
±0.08
±0.10
Symbol
b
b1
c
c1
Typ
0.33
0.30
0.18
0.15
±Tol
+0.07/-0.08
±0.05
±0.05
+0.03/-0.02
θ1
θ2
θ3
L
L1
aaa
bbb
ccc
e
S
3.0º
±3.0º
12.0º
12.0º
0.55
0.95 BSC
0.10
0.08
0.25
0.65 BSC
0.525 BSC
±3.0º
±3.0º
±0.15
2.95
±0.10
E
E1
E2
E3
E4
R
R1
t1
t2
4.90
3.00
2.95
0.51
0.51
0.15
0.15
0.31
0.41
±0.15
±0.10
±0.10
±0.13
±0.13
+0.15/-0.08
+0.15/-0.08
±0.08
±0.08
ch
ni
ca
D2
Notes:
All dimensions are in millimeters and all angles in degrees (unless otherwise noted).
Datums B and C to be determined at datum plane H.
Dimensions D and E1 are to be determined at datum plane H.
Dimensions D2 and E2 are for the top package; dimensions D and E1 are for the bottom package.
Cross section A-A to be determined at 0.13 to 0.25mm from the leadtip.
Dimensions D and D2 do not include mold flash, protrusion, or gate burrs.
Dimensions E1 and E2 do not include interlead flash or protrusion.
Te
1.
2.
3.
4.
5.
6.
7.
Revision 1.02
15 - 18
AS1970
Data Sheet
am
lc s
on A
te G
nt
st
il
lv
al
id
Figure 25. 14-pin TSSOP Package
1, 2
A
A1
A2
L
R
R1
b
b1
c
c1
D
E1
E
4.90
4.30
5.00
1.40
6.4 BSC
5.10
4.50
1, 2
Note
5
Symbol
θ1
L1
aaa
bbb
ccc
ddd
e
θ2
θ3
Variations
3, 8
e
4, 8
N
0.65mm Lead Pitch
Min
Nom
Max
0º
8º
1.0 Ref
0.10
0.10
0.05
0.20
0.65 BSC
12º Ref
12º Ref
0.65 BSC
14
Note
6
ni
Notes:
0.65mm Lead Pitch
Min
Nom
Max
1.10
0.05
0.15
0.85
0.90
0.95
0.50
0.60
0.75
0.09
0.09
0.19
0.30
0.19
0.22
0.25
0.09
0.20
0.09
0.16
ca
Symbol
Te
ch
1. All dimensions are in millimeters; angles in degrees.
2. Dimensions and tolerancing per ASME Y14.5M-1994.
3. Dimension D does not include mold flash, protrusions, or gate burrs. Mold flash, protrusions, or gate burrs shall not
exceed 0.15mm per side.
4. Dimension E1 does not include interlead flash or protrusion. Interlead flash or protrusion shall not exceed 0.25mm
per side.
5. Dimension b does not include dambar protrusion. Allowable dambar protrusion shall be 0.08mm total in excess of
dimension b at maximum material condition. Dambar cannot be located on the lower radius of the foot. Minimum
space between protrusion and adjacent lead is 0.07mm for 0.5mm pitch packages.
6. Terminal numbers shown are for reference only.
7. Datums A and B to be determined at datum plane H.
8. Dimensions D and E1 to be determined at datum plane H.
9. This dimension applies only to variations with an even number of leads per side. For variations with an odd number
of leads per package, the center lead must be coincident with the package centerline, datum A.
10. Cross section A-A to be determined at 0.10 to 0.25mm from the leadtip.
Revision 1.02
16 - 18
AS1970
Data Sheet
- Ordering Information
11 Ordering Information
The comparators are available as the standard products shown in Table 5.
Table 5. Ordering Information
Model
Marking
Description
Delivery Form
Package
ASI6
Low-Voltage Single Comparator, Push/Pull
Tape and Reel
5-pin SOT23
AS1971-T
ASI7
Low-Voltage Single Comparator, Open-Drain
Tape and Reel
5-pin SOT23
AS1972
989
Low-Voltage Dual Comparator, Push/Pull
Tubes
AS1972-T
989
Low-Voltage Dual Comparator Push/Pull
Tape and Reel
al
id
AS1970-T
8-pin MSOP
8-pin MSOP
AS1973
990
Low-Voltage Dual Comparator, Open-Drain
Tubes
AS1973-T
990
Tape and Reel
8-pin MSOP
AS1974
AS1974
Low-Voltage Quad Comparator, Push/Pull
Tubes
14-pin TSSOP
AS1974-T
AS1974
Tape and Reel
14-pin TSSOP
lv
8-pin MSOP
AS1975
Low-Voltage Quad Comparator, Open-Drain
Tubes
14-pin TSSOP
AS1975
Tape and Reel
14-pin TSSOP
Te
ch
ni
ca
am
lc s
on A
te G
nt
st
il
AS1975
AS1975-T
Revision 1.02
17 - 18
AS1970
Data Sheet
Copyrights
Copyright © 1997-2007, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe.
Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner.
All products and companies mentioned are trademarks or registered trademarks of their respective companies.
al
id
Disclaimer
am
lc s
on A
te G
nt
st
il
lv
Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing
in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding
the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior
to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information.
This product is intended for use in normal commercial applications. Applications requiring extended temperature
range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or lifesustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for
each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard
production flow, such as test flow or test location.
ni
ca
The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However,
austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to
personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or
consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of
austriamicrosystems AG rendering of technical or other services.
ch
Contact Information
Te
Headquarters
A-8141 Schloss Premstaetten, Austria
Fax: +43 (0) 3136 525 01
For Sales Offices, Distributors and Representatives, please visit:
http://www.austriamicrosystems.com/contact
Revision 1.02
18 - 18
