CBT3384D,112
CBT3384D,112
    NEXPERIA(安世)
    SOIC24
    IC BUS SWITCH 5 X 1:1 24SO
CBT3384D,112 数据手册
CBT3384 10-bit bus switch with 5-bit output enables Rev. 7 — 6 March 2019 Product data sheet 1. General description The CBT3384 provides ten bits of high-speed TTL-compatible bus switching. The low ON resistance of the switch allows connections to be made with minimal propagation delay. The CBT3384 device is organized as two 5-bit bus switches with two separate output enable (1OE, 2OE) inputs. When nOE is LOW, the switch is on and port A is connected to the B port. When nOE is HIGH, each switch is disabled. 2. Features • • • • • 5 Ω switch connection between two ports TTL-compatible control input levels See CBTD3384 for CBT3384 with level shifting diodes Latch-up protection exceeds 100 mA per JESD78 ESD protection: • HBM JESD22-A114E exceeds 2000 V • CDM JESD22-C101C exceeds 1000 V • Specified from -40 °C to +85 °C 3. Ordering information Table 1. Ordering information Type Package number Temperature range Name Description Version CBT3384D SO24 plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 TSSOP24 plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 -40 °C to +85 °C CBT3384PW -40 °C to +85 °C CBT3384 Nexperia 10-bit bus switch with 5-bit output enables 4. Functional diagram 1A1 1A5 1OE 2A1 2A5 2OE Fig. 1. 3 2 11 10 1B1 1B5 1 14 15 22 23 2B1 2B5 13 001aak877 Logic diagram 5. Pinning information 5.1. Pinning CBT3384 CBT3384 1OE 1 1 2 24 VCC 23 2B5 1OE 1B1 1B1 2 24 VCC 23 2B5 1A1 3 22 2A5 1A1 3 22 2A5 1A2 4 21 2A4 1A2 4 21 2A4 1B2 5 20 2B4 1B2 5 20 2B4 1B3 6 19 2B3 1B3 6 19 2B3 1A3 7 18 2A3 1A3 7 18 2A3 1A4 8 17 2A2 1A4 8 17 2A2 1B4 9 16 2B2 1B4 9 16 2B2 1B5 10 15 2B1 1B5 10 15 2B1 1A5 11 14 2A1 1A5 11 14 2A1 GND 12 13 2OE GND 12 13 2OE 001aak879 001aak878 Fig. 2. Pin configuration for SO24 (SOT137-1) Fig. 3. Pin configuration for TSSOP24 (SOT355-1) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 13 output enable input (active LOW) 1A1 to 1A5 3, 4, 7, 8, 11 data input/output (A port) 2A1 to 2A5 14, 17, 18, 21, 22 data input/output (A port) 1B1 to 1B5 2, 5, 6, 9, 10 data input/output (B port) 2B1 to 2B5 15, 16, 19, 20, 23 data input/output (B port) GND 12 ground (0 V) VCC 24 positive supply voltage CBT3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 2 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. Input Input/output 1OE 2OE 1An, 1Bn 2An, 2Bn L L 1An = 1Bn 2An = 2Bn L H 1An = 1Bn Z H L Z 2An = 2Bn H H Z Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Tamb = -40 °C to +85 °C, unless otherwise specified. Symbol Parameter VCC supply voltage VI input voltage IO output current IIK input clamping current Tstg storage temperature [1] Conditions Min Max Unit -0.5 +7.0 V -0.5 +7.0 V VO < 0 V - ±128 mA VI/O = 0 V -50 - mA -65 +150 °C [1] The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed. 8. Recommended operating conditions Table 5. Operating conditions All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Symbol Parameter VCC VIH Min Typ Max Unit supply voltage 4.5 - 5.5 V HIGH-state input voltage 2.0 - - V VIL LOW-state input voltage - - 0.8 V Tamb ambient temperature -40 - +85 °C CBT3384 Product data sheet Conditions operating in free air All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 3 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = -40 °C to +85 °C Min Typ [1] Max Unit VIK input clamping voltage VCC = 4.5 V; II = -18 mA - - -1.2 V II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - - ±1 μA ICC supply current VCC = 5.5 V; IO = 0 mA; VI = VCC or GND - - 3 μA ΔICC additional supply current per input pin; VCC = 5.5 V; one input at [2] 3.4 V, other inputs at VCC or GND - - 2.5 mA Vpass pass voltage output HIGH; VI = VCC = 5.0 V; IO = -100 μA 3.6 3.9 4.2 V CI input capacitance control pins; VI = 3 V or 0 V - 4.0 - pF Cio(off) off-state input/output capacitance port off; VI = 3 V or 0 V; nOE = VCC - 10.0 - pF RON ON resistance VCC = 4.5 V; VI = 0 V; II = 64 mA [3] - 5 7 Ω VCC = 4.5 V; VI = 0 V; II = 30 mA [3] - 5 7 Ω VCC = 4.5 V; VI = 2.4 V; II = -15 mA [3] - 10 15 Ω [1] [2] [3] All typical values are at VCC = 5 V, Tamb = 25 °C. This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND. Measured by the voltage drop between the nAn and the nBn terminals at the indicated current through the switch. ON resistance is determined by the lowest voltage of the two (nAn or nBn) terminals. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 6. Symbol Parameter tpd Conditions Tamb = 25 °C Min Typ Max Min Max - - 0.25 - 0.25 ns OFF-state to HIGH nOE to nAn or nBn; see Fig. 5 propagation delay VCC = 5.0 V ± 0.5 V 1.2 2.3 5.7 1.2 5.6 ns OFF-state to LOW nOE to nAn or nBn; see Fig. 5 propagation delay VCC = 5.0 V ± 0.5 V 1.2 2.3 5.7 1.2 6.0 ns HIGH to OFF-state nOE to nAn or nBn; see Fig. 5 propagation delay VCC = 5.0 V ± 0.5 V 1.7 3.6 5.2 1.7 5.5 ns LOW to OFF-state nOE to nAn or nBn; see Fig. 5 propagation delay VCC = 5.0 V ± 0.5 V 1.7 2.7 5.2 1.7 6.6 ns propagation delay nAn, nBn to nBn, nAn; see Fig. 4 [1][2] VCC = 5.0 V ± 0.5 V tPZH tPZL tPHZ tPLZ [1] [2] Tamb = -40 °C to +85 °C Unit The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance, when driven by an ideal voltage source (zero output impedance). tpd is the same as tPLH and tPHL. CBT3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 4 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables 10.1. Waveforms and test circuit VI VM nAn, nBn input VM GND tPHL tPLH VOH VM nBn, nAn output VM VOL 001aak881 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 4. The data input (nAn, nBn) to output (nBn, nAn) propagation delay times VI VM nOE input VM GND tPZL tPLZ output LOW to OFF OFF to LOW 3.5 V VM VX VOL tPZH tPHZ output HIGH to OFF OFF to HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aak298 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. Enable and disable times Table 8. Measurement points Supply voltage Input VCC VI VCC = 5.0 V ± 0.5 V GND to 3.0 V CBT3384 Product data sheet Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 5 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω. The outputs are measured one at a time with one transition per measurement. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 6. Test circuit for measuring switching times Table 9. Test data Supply voltage VCC = 5.0 V ± 0.5 V CBT3384 Product data sheet Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH GND to 3.0 V ≤ 2.5 ns 50 pF 500 Ω open 7.0 V open All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 6 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables 11. Package outline SO24: plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 D E A X c HE y v M A Z 24 13 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 12 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 15.6 15.2 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.019 0.013 0.014 0.009 0.61 0.60 0.30 0.29 0.05 0.419 0.043 0.043 0.055 0.394 0.016 0.039 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 7. REFERENCES OUTLINE VERSION IEC JEDEC SOT137-1 075E05 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT137-1 (SO24) CBT3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 7 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm D SOT355-1 E A X c HE y v M A Z 13 24 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 12 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 7.9 7.7 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT355-1 Fig. 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Package outline SOT355-1 (TSSOP24) CBT3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 8 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model PRR Pulse Rate Repetition TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes CBT3384 v.7 20190306 Product data sheet - CBT3384 v.6 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number CBT3384DB (SOT340-1) and CBT3384DK (SOT556-1) removed. CBT3384 v.6 20091102 Modifications: • • • • Product data sheet - CBT3384 v.5 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Changed: Table 6 1. Pass voltage values have changed. 2. Undershoot static current protection removed. Changed: Table 7 1. Enable and disable times values have changed. CBT3384 v.5 20011220 Product specification - CBT3384 v.4 CBT3384 v.4 20010319 Product specification - CBT3384 v.3 CBT3384 v.3 20001113 Product specification - CBT3384 v.2 CBT3384 v.2 20000128 Product specification - - CBT3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 9 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal CBT3384 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 10 / 11 CBT3384 Nexperia 10-bit bus switch with 5-bit output enables Contents 1. General description...................................................... 1 2. Features.........................................................................1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 4 10.1. Waveforms and test circuit........................................ 5 11. Package outline.......................................................... 7 12. Abbreviations.............................................................. 9 13. Revision history..........................................................9 14. Legal information......................................................10 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 March 2019 CBT3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 11 / 11
CBT3384D,112 价格&库存
很抱歉,暂时无法提供与“CBT3384D,112”相匹配的价格&库存,您可以联系我们找货
