CBT16212DL,518
CBT16212DL,518
    NEXPERIA(安世)
    SSOP56_300MIL
    IC BUS FET EXCH SW 12X2:2 56SSOP
CBT16212DL,518 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia CBT16212 24-bit bus exchange switch with 12-bit output enables Rev. 02 — 3 November 2008 Product data sheet 1. General description The CBT16212 provides 24 bits of high-speed TTL-compatible bus switching or exchanging. The low ON resistance of the switch allows connections to be made with minimal propagation delay. The CBT16212 operates either as a 24-bit bus switch or as a 12-bit bus exchanger, providing data exchange between four signal ports using the port select inputs (S0, S1 and S2). The CBT16212 is characterized for operation from –40 °C to +85 °C. 2. Features n 5 Ω switch connection between two ports n TTL compatible input levels n ESD protection: u HBM JESD22-A114E Class 1C exceeds 1500 V u CDM JESD22-C101C exceeds 1000 V n Latch-up performance: u JESD78 exceeds 100 mA 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version CBT16212DGG −40 °C to 85 °C TSSOP56 plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 CBT16212DL −40 °C to 85 °C SSOP56 plastic shrink small outline package; 56 leads; body width 7.5 mm SOT371-1 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 4. Functional diagram 1B1 2 3 4 5 6 7 9 10 11 12 13 14 15 16 18 20 21 22 23 24 25 26 27 28 1 56 55 1A1 54 1A2 1B2 2B1 2A1 53 52 2A2 2B2 3B1 3A1 51 50 3A2 3B2 4B1 4A1 48 47 4A2 4B2 5B1 5A1 46 45 5A2 5B2 6B1 6A1 44 43 6A2 6B2 7B1 7A1 42 41 7A2 7B2 8B1 8A1 40 39 8A2 8B2 9B1 9A1 37 36 9A2 9B2 10B1 10A1 1A1 2 1 of 12 channels 10B2 11B1 11A1 33 32 11A2 11B2 12B1 12A1 1A2 31 30 3 53 1B2 FLOW CONTROL 12A2 12B2 S0 29 S0 S1 S1 S2 S2 Functional diagram 1 56 55 001aai357 Fig 2. Logic diagram CBT16212_2 Product data sheet 1B1 10A2 001aai356 Fig 1. 54 35 34 © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 2 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 5. Pinning information 5.1 Pinning S0 1 56 S1 1A1 2 55 S2 1A2 3 54 1B1 2A1 4 53 1B2 2A2 5 52 2B1 3A1 6 51 2B2 3A2 7 50 3B1 GND 8 49 GND 4A1 9 48 3B2 4A2 10 47 4B1 5A1 11 46 4B2 5A2 12 45 5B1 6A1 13 44 5B2 6A2 14 7A1 15 43 6B1 CBT16212 42 6B2 7A2 16 41 7B1 VCC 17 40 7B2 8A1 18 39 8B1 GND 19 38 GND 8A2 20 37 8B2 9A1 21 36 9B1 9A2 22 35 9B2 10A1 23 34 10B1 10A2 24 33 10B2 11A1 25 32 11B1 11A2 26 31 11B2 12A1 27 30 12B1 12A2 28 29 12B2 001aai358 Fig 3. Pin configuration SOT364-1 (TSSOP56) and SOT371-1 (SSOP56) 5.2 Pin description Table 2. Pin description Symbol Pin Description S0, S1, S2 1, 56, 55 port select input 1A1 to 12A1 2, 4, 6, 9, 11, 13, 15, 18, 21, 23, 25, 27 A1 port 1A2 to 12A2 3, 5, 7, 10, 12, 14, 16, 20, 22, 24, 26, 28 A2 port GND 8, 19, 38, 49 ground (0 V) VCC 17 supply voltage 1B1 to 12B1 54, 52, 50, 47, 45, 43, 41, 39, 36, 34, 32, 30 B1 port 1B2 to 12B2 53, 51, 48, 46, 44, 42, 40, 37, 35, 33, 31, 29 B2 port CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 3 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 6. Functional description Table 3. Function selection[1] Port select input Input/output Function S2 S1 S0 nA1 nA2 L L L Z Z disconnect L L H nB1 Z nA1 = nB1 L H L nB2 Z nA1 = nB2 L H H Z nB1 nA2 = nB1 H L L Z nB2 nA2 = nB2 H L H Z Z disconnect H H L nB1 nB2 nA1 = nB1 and nA2 = nB2 H H H nB2 nB1 nA1 = nB2 and nA2 = nB1 [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit −0.5 +7.0 V −0.5 +7.0 V VCC supply voltage VI input voltage IIK input clamping current VI < 0 V −50 - mA VO output voltage output at HIGH level or OFF-state −0.5 +5.5 V output at LOW level IO output current Tstg storage temperature Ptot total power dissipation [1] - 128 mA −65 +150 °C Tamb = −40 °C to +125 °C SSOP56 package [3] - 850 mW TSSOP56 package [4] - 600 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 °C. [3] Above 55 °C the value of Ptot derates linearly with 11.3 mW/K. [4] Above 55 °C the value of Ptot derates linearly with 8 mW/K. 8. Recommended operating conditions Table 5. Operating conditions All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Symbol Parameter VCC Conditions Min Max Unit supply voltage 4.0 5.5 V VIH HIGH-level input voltage 2.0 - V VIL LOW-level input voltage - 0.8 V Tamb ambient temperature −40 +85 °C operating in free-air CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 4 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 9. Static characteristics Table 6. Static characteristics Tamb = −40 °C to +85 °C. Min Typ[1] Max Unit VCC = 4.5 V; II = −18 mA - - −1.2 V Symbol Parameter Conditions VIK input clamping voltage II input leakage current VCC = 0 V; VI = 5.5 V - - 10 µA VCC = 5.5 V; VI = VCC or GND - - ±1 µA - - 3 µA - - 2.5 mA - 4.7 - pF - 11.5 - pF - - 21 Ω VI = 0 V; II = 64 mA - 4 7 Ω VI = 0 V; II = 30 mA - 4 7 Ω VI = 2.4 V; II = 15 mA - 6 12 Ω ICC supply current VCC = 5.5 V; IO = 0 A; VI = VCC or GND ∆ICC additional supply current per port select input pin; VCC = 5.5 V; one input at 3.4 V, other inputs at VCC or GND CI input capacitance port select input pins; VI = 3 V or 0 V; VCC = 5.0 V; Cio(off) off-state input/output capacitance VO = 3 V or 0 V; VCC = 0 V RON ON resistance VCC = 4.0 V [2] [3] VI = 2.4 V; II = 15 mA VCC = 4.5 V [3] [1] All typical values are measured at Tamb = 25 °C. [2] This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND. [3] Measured by the voltage drop between the A and the B terminals at the indicated current through the switch. ON resistance is determined by the lowest voltage of the two (A or B) terminals. 10. Dynamic characteristics Table 7. Dynamic characteristics Tamb = −40 °C to +85 °C; VCC = 4.5 V to 5.5 V; for test circuit see Figure 6. Symbol Parameter propagation delay tpd Conditions Min Max Unit input A or B to output B or A; see Figure 4 [1][2] - 0.25 ns 2.4 8.0 ns 2.4 8.0 ns ten enable time port select input to output A or B; Figure 5 [3] tdis disable time port select input to output A or B; Figure 5 [4] [1] This parameter is warranted but not production tested. The propagation delay is based on the RC time constant of the typical ON resistance of the switch and a load capacitance of 50 pF, when driven by an ideal voltage source (zero output impedance). [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZL and tPZH. [4] tdis is the same as tPLZ and tPHZ. CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 5 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 11. Waveforms VI input GND VM VM tPLH tPHL VOH output VM VOL VM 001aah986 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 4. Input to output propagation delays VI Sn input GND 3.5 V output OFF to LOW LOW to OFF V OL output OFF to HIGH HIGH to OFF VM VM tPZL tPLZ VM VOL + 0.3 V tPZH tPHZ VOH VOH − 0.3 V VM GND 001aaj055 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 5. Table 8. Enable and disable times Measurement points Supply voltage Input Output VCC VM VM 4.5 V to 5.5 V 1.5 V 1.5 V CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 6 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables VEXT VCC VI RL VO G DUT RT CL RL mna616 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 6. Test circuit Table 9. Test data Supply voltage Input Load VEXT VCC VI tr = tf CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 4.5 V to 5.5 V GND to 3.0 V ≤ 2.5 ns 50 pF 500 Ω open open 7.0 V CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 7 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 12. Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 detail X 28 w M bp e 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 Fig 7. REFERENCES IEC JEDEC JEITA MO-153 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT364-1 (TSSOP56) CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 8 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables SSOP56: plastic shrink small outline package; 56 leads; body width 7.5 mm SOT371-1 D E A X c y HE v M A Z 29 56 Q A2 A1 A (A 3) θ pin 1 index Lp L 28 1 bp e 0 detail X w M 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 18.55 18.30 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8 o 0 o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT371-1 Fig 8. REFERENCES IEC JEDEC JEITA MO-118 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 Package outline SOT371-1 (SSOP56) CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 9 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes CBT16212_2 03112008 Product data sheet - CBT16212_1 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Table 7 “Dynamic characteristics”: – Enable time: min value changed from 3.6 into 2.4. – Disable time: min value changed from 4.5 into 2.4. CBT16212_1 20010928 Product data CBT16212_2 Product data sheet - - © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 10 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com CBT16212_2 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 02 — 3 November 2008 11 of 12 CBT16212 NXP Semiconductors 24-bit bus exchange switch with 12-bit output enables 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2008. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 3 November 2008 Document identifier: CBT16212_2
CBT16212DL,518 价格&库存
很抱歉,暂时无法提供与“CBT16212DL,518”相匹配的价格&库存,您可以联系我们找货
