963/963E
Benchtop Air Ionizers
Rapid neutralization of electrostatic charge
The ion-generation technology present in the 963 and
963E benchtop air ionizers is capable of producing
extremely large amounts of ions, resulting in nearly
instantaneous static charge neutralization. The 3M 963 is
capable of reducing a static charge of 1000V to 100V in
less than one second, at a one foot distance, when tested*
at the high fan speed. In addition, the powerful fan allows
the generated ions to be carried at high speed for long
distances. At a distance of three feet, the discharge time
only increases to approximately five seconds.
Intrinsically balanced, maintenance-free
3M ionizers have a proprietary, intrinsically balanced ion
generation system which ensures that equal levels of
positive and negative ions are produced despite variations
in line voltage, fan speed, and emitter point condition. No
adjustment or calibration is required to maintain ion
balance. This allows the unit to generate a balanced mix
of positive and negative ions - even if the emitter points
become dirty.
1
The use of ionized air in electronics work environments
eliminates the build up of potentially damaging static
charges. Air ionizers are primarily used to control static
charge on nonconductive materials. Grounding is
normally used to control charge on conductive objects and
personnel, however, nonconductors cannot be grounded to
drain electrostatic charge. Ionization is the only method of
neutralizing a static charge on a nonconductor. Ionized air
can neutralize static charges on circuit board substrates,
insulating tapes and plastic objects found in the work area.
The 3M™ 963 and 963E benchtop air ionizers, blanket the
benchtop with ionized air to help prevent static from
damaging sensitive electronics.
Two versions of Benchtop Air Ionizer available
The 963 benchtop air ionizer uses AC 120V power, while
the 963E uses AC 220V/230V power. Both ionizers
feature a two-speed fan, a power indicator lamp, a
static-dissipative plastic housing, and a combination
metal-plastic stand that can also double as a mounting
bracket.
Both the 963 and 963E are virtually maintenance free.
The ionizer’s unique design requires only periodic
cleaning of emitter points to maintain optimum
performance. The points do not require replacement and
the unit does not require adjustment before or after
cleaning.
Quiet and comfortable air flow
The two-speed fan in the 963 and 963E benchtop air
ionizers is extremely quiet at low speed. Where industrial
noise may irritate personnel and lower productivity, the
963 and 963E may be used without contributing
significantly to the ambient noise. The fan’s gentle airflow
does not disturb paper or delicate parts. The high-speed
fan setting can be used for more rapid neutralization of
static charges in environments where faster decay rates are
required.
Static-dissipative housing safe to use in ESD
sensitive areas
The injection-molded plastic case is constructed of
static-dissipative plastic. The conductivity of the case
prevents a static charge from building up on the surface of
the housing, a common problem with ionizers. This
“ESD-safe” design allows the ionizer to be part of your
overall static-safeguarded electronic workstation.
When tested according to ANSI/ESD S3.1-1991
Meets Global Regulatory Requirements
Global usage of electronic products are often dependent on
the product meeting regulatory requirements for the
country of usage. To achieve this end, the 3M™ Models
963 and 963E have been tested to, and have passed,
regulatory testing for U.S., Canada, Mexico and the
European Union. The 963 carries the UL, C-UL, and
NOM marks, while the 963E carries the CE mark.
Basic Features
• Two versions available, depending on operating voltage
• Neutralizes static charges on nonconductive objects
• Maintains equal balance of positive-negative ions
• Two-speed fan
• Static-dissipative housing
• UL, C-UL, CE, NOM certification.
963 Benchtop Air Ionizer Properties
Model
963
963E
Operating Voltage and Frequency
Power Outlet
Supplied Power Cord
AC 120V 60 Hz 0.2A 20W
IEC 320 Socket
6' (1.8m) cord with IEC 320 and NEMA
5-15 plugs
6.0" W x 7.4" H x 3.0" D
15.2cm W x 18.8cm H x 7.6cm D
2.5 lb. (1.1 kg)
low speed – 200 fpm (1.0 m/s)
high speed – 370 fpm (1.8 m/s)
1' (30cm) < 1 second at high fan speed
3' (91cm) < 5 seconds at high fan speed
UL, C-UL, NOM
1-year
AC 220V/230V 50/60 Hz 0.12A 20W
IEC 320 Socket
Continental Europe (EURO) plugs
2.5 lb. (1.1 kg)
low speed – 100 fpm (0.5 m/s)
high speed – 300 fpm (1.5 m/s)
CE
1-year
Dimensions
Weight
Air Velocity
Static Discharge Time*
Certifications and Approvals
Warranty
(All values are typical, not specifications)
For ordering information, technical information or
product information you can reach us at:
Phone 1-800-328-1368
Fax
1-800-828-9329or
1-512-984-2210
Important Notice
All statements, technical information, and recommendations related to
Seller’s products are based on information believed to be reliable, but the
accuracy or completeness thereof is not guaranteed. Before utilizing the
product, the user should determine the suitability of the product for its
intended use. The user assumes all risks and liability whatsoever in
connection with such use.
or implied, including but not limited to the implied warranties of
merchantability and fitness for a particular purpose which warranties are
hereby expressly disclaimed.
Any statements or recommendations of the Seller which are not contained
in the Seller’s current publications shall have no force or effect unless
contained in an agreement signed by an authorized officer of Seller. The
statements contained herein are made in lieu of all warranties, expressed
SELLER SHALL NOT BE LIABLE TO THE USER OR ANY OTHER PERSON
UNDER ANY LEGAL THEORY, INCLUDING BUT NOT LIMITED TO
NEGLIGENCE OR STRICT LIABILITY, FOR ANY INJURY OR FOR ANY
DIRECT, INDIRECT, SPECIAL, INCIDENTAL OR CONSEQUENTIAL
DAMAGES SUSTAINED OR INCURRED BY REASON OF THE USE OF ANY
OF THE SELLER’S PRODUCTS.
Electronic Handling & Protection Division
6801 River Place Blvd.
Austin, TX 78726-9000
www.3M.com/ehpd
Recycled paper
40% Pre-consumer waste paper
10% Post-consumer waste paper
Litho in USA.
© 3M 1999 98-0799-0457-3 (6910.0)JHA/WP
