TECHNICAL BULLETIN TB-3059
Ionizer Motion Sensor
Installation, Operation and Maintenance
Made in the
United States of America
The Ionizer Motion Sensor is compatible with the
following Desco ionizers:
Item
Description
50663 Benchtop Zero Volt Ionizer, Stainless Steel,
120VAC
50690 Benchtop Zero Volt Ionizer, Powder Coat,
120VAC
60505 High Output Benchtop Ionizer, 120VAC
Figure 1. Desco 60509 Ionizer Motion Sensor
Description
The Desco 60509 Ionizer Motion Sensor is designed
to automatically activate an ionizer when an operator
is present at a workstation and turn off when the
workstation is vacant. This product ensures that the
ionizer is activated when required. It also conserves
energy and increases maintenance intervals of the
ionizer by deactivating it when the workstation is vacant.
The Control Unit is capable of switching up to 5 amps at
120VAC and is fuse protected.
The Ionizer Motion Sensor consists of two components:
the Sensor Unit and Control Unit. The control unit
connects between the AC power cord and the ionizer
power input using standard IEC type (C13/C14)
connectors. The sensor unit is placed in a position
to “detect” an operator up to three feet away. The
sensitivity levels can be adjusted to: low (12 inches),
medium (24 inches) or high (36 inches). The Sensor
Unit should be mounted flush with the front edge of the
mounting surface whenever possible. This is done to
prevent reflected light from the mounting surface. The
two components communicate using a standard 6-pin
modular cable.
50664 Overhead Zero Volt Ionizer, 2-Fan, 120VAC
50665 Overhead Zero Volt Ionizer, 3-Fan, 120VAC
60640 Chargebuster® Overhead Ionizer, 2-Fan,
120VAC
60473 Chargebuster® Overhead Ionizer, 3-Fan,
120VAC
60467 Chargebuster® Overhead Ionizer with Lights,
2-Fan, 120VAC
60468 Chargebuster® Overhead Ionizer with Lights,
3-Fan, 120VAC
Packaging
1 Sensor Unit
1 Control Unit, 120VAC
1 Modular Cable, 2'
1 Modular Cable, 7'
2 Hook and Loop Fastener Strips
2 Screws
The Ionizer Motion Sensor utilizes a unique infrared
light and band pass filter to prevent interference from
other light sources. The band pass filter uses a reflected
infrared light with the specific frequency to sense the
presence of the operator. It does not require continuous
motion to remain activated. The deactivation delay
time can be set to 1 minute, 10 minutes or 1 hour
periods. This delay prevents the ionizer from turning on
and off frequently if an operator is only away from the
workstation momentarily.
DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178
DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com
TB-3059 Page 1 of 3
May 2020
© 2020 DESCO INDUSTRIES INC
Employee Owned
Features and Components
SENSITIVITY
DIP switches 1-3 control the sensitivity of Sensor.
B
Switch 1 Switch 2 Switch 3
Approximate
Sensitivity
ON
OFF
OFF
Low (0-12")
D
OFF
ON
OFF
Medium (12-24")
Figure 2. Sensor Unit features and components
OFF
OFF
ON
High (24-36")
A
C
E
G
DEACTIVATION DELAY TIME
DIP switches 4-6 control the deactivation delay time.
Switch 4 Switch 5 Switch 6
F
C
Figure 3. Control Unit features and components
A. Power LED: This LED will illuminate blue when an
operator or object has activated the device.
B. Infrared Emitter and Receiver: Detects when an
operator or object is present. Movement by the operator
is not necessary.
C. Communication Jacks: Use the included modular
cables to connect the Sensor Unit to the Control Unit.
D. DIP Switch: Use to adjust the sensor’s sensitivity
and deactivation delay time. See the installation
instructions on page 2 for more information.
E. IEC C14 Style Inlet: Connect the ionizer’s power
cord here.
F. Fuse Drawer: Accepts 5A, 250V slow blow fuses.
G. IEC C13 Style Outlet: Connect into the ionizer’s
power inlet.
Sensor Configuration
The Sensor’s sensitivity and deactivation delay time
are controlled by the DIP switches located on the back
of the Sensor Unit. Use the following tables for the DIP
switch settings and their corresponding values.
Approximate
Delay Time
ON
OFF
OFF
1 minute
OFF
ON
OFF
10 minute
OFF
OFF
ON
1 hour
default setting
Installation
1. Ensure that the ionizer does not exceed the
maximum power rating of 120VAC, 5A. Insert the
Control Unit into the ionizer’s IEC power inlet.
NOTE: If using the Desco High Output Benchtop
Ionizer or EMIT Benchtop Zero Volt Ionizer, set its
power switch to ON before connecting the Control
Unit. The Control Unit covers its power switch.
2. Determine the mounting location of the Sensor Unit.
Place it where only the operator can come into its
field of view. Do not place it where a fixture or item
can obstruct its line of sight. Use either the included
hook and loop fastener strips or screws to secure
the sensor to a surface. The Sensor Unit should be
mounted flush with the front edge of the mounting
3. Use either the 2 foot or 7 foot modular cable to
connect the Control Unit to the Sensor Unit.
4. Connect the ionizer’s power cord to the Control Unit
and the opposite end into an appropriate power
outlet.
5. Power the ionizer.
NOTE: Be sure to disconnect the power from the
Sensor Unit before making any changes to the DIP
switch. Failure to do so may result in damage to the
Sensor Unit.
TB-3059 Page 2 of 3
Employee Owned
Operation
Enter the sensor’s field of view. The blue LED will
illuminate upon activation. The ionizer will remain
powered as long as something is in the sensor’s view.
Movement is not necessary.
Leave the sensor’s field of view to activate the shutoff
delay timer. The Ionizer Motion Sensor’s LED will turn
off and unpower the ionizer once the preset deactivation
delay time is reached.
Maintenance
The fuse located in the Control Unit may be replaced by
removing the power cord and opening the fuse drawer
at the IEC inlet. The Control Unit uses one 5A, 250V
slow blow fuse. DO NOT use other ratings as it may
pose a safety hazard.
Figure 6. Replacing the fuse in the Control Unit
Specifications
Figure 4. Using the Ionizer Motion Sensor with the
Maximum Input
5A @ 120VAC, 50/60 Hz
Voltage and Frequency
Operating Temperature 50 to 95°F (10 to 35°C)
Figure 5. Using the Ionizer Motion Sensor with the
60473 Chargebuster® 3-Fan Overhead Ionizer
Environmental
Requirements
Indoor use only at altitudes
less than 6500 ft. (2 km)
Maximum relative humidity
of 80% up to 85°F (30°C)
decreasing linearly to 50% @
85°F (30°C)
Dimensions
(Sensor)
3.0" L x 2.0" W x .9" H
(76 mm x 51 mm x 23 mm)
Dimensions
(Control)
2.7" L x 2.0" W x 1.8" H
(69 mm x 51 mm x 46 mm)
Weight
(Sensor)
0.1 lbs. (0.05 kg)
Weight
(Control)
0.3 lbs. (0.1 kg)
Fuse
5A, 250V, slow blow
Country of Origin
Limited Warranty, Warranty Exclusions, Limit
of Liability and RMA Request Instructions
See the Desco Warranty Desco.com/Limited-Warranty.aspx
TB-3059 Page 3 of 3
Employee Owned
很抱歉,暂时无法提供与“60509”相匹配的价格&库存,您可以联系我们找货
