Model ACL 390
ACL 390
Surface Resistance Meter
This durable and lightweight handheld meter
measures both Surface Resistivity between two
points (Rtt) and Resistance to Ground (Rtg). Test
Range is from 103 to 1012 ohms. Meter automatically
generates a 10v or 100v test voltage for a 9 volt
battery with results shown through a multi-colored
LED display. Meter can be used with the built-in
parallel stainless steel electrodes or with optional
external electrodes.
• Meter includes ground cord and case.
• Optional 5 pound weigh kit is avaliable.
Benefits
Features
Lightweight and durable
Multi-colored LED display
Measures automatically with 10v and 100v
Test range 103 - 1012 Ω
10% accuracy
Measures surface resistance
Measures resistance to ground
Long lasting, portable and easy to carry
Easy to read, color indicates range
Safe and easy to use
Measures conductive, dissipative and insulative
Reliable
Fixed probes built-in with peripheral jacks for
optional external probes
When purchased with accessory kit, Meter complies with ESDA, ANSI, NFPA, UL, ASTM, Military, and EIA standards
1960 East Devon Ave. • Elk Grove Village, IL 60007 • (847) 981-9212 • Fax: (847) 981-9278
www.aclstaticide.com • info@aclstaticide.com
MKB 11/05
ACL 390 Surface Resistance Meter
Specifications:
Power Supply
Test Voltage
Range
Accuracy
Weight
Size
9 volt alkaline battery
10 volt / 100 volt
103 - 1012 Ω
+/- 10%
8.5 ounces
2.5" x 5" x 1 1/8"
Supplied With:
Tester
Carrying pouch
9v battery (installed)
Grounding cord and alligator clip
Calibration certificate
Optional Weight Kit Available
External probes will meet Industry standards for testing
RTT and Volume Resistance. Probes are powder coated
black and have an attached handle with a durable and
conductive rubber base.
ACL 391 includes:
• Carrying Case with foam lining
• Two 5lb, 2.5" RTT, RTG disk probes
• Two accordion banana cords
5lb probes with cables
MKB 11/05
ISO 9001: 2000
Reg. to: ACL Inc. Cert No. A3656
很抱歉,暂时无法提供与“ACL391”相匹配的价格&库存,您可以联系我们找货
