SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 1W/0.5M
(AT 0.8, 1.0, 1.2, 1.5, kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
2
4
4 15%
W
W
OHM
86
3
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
D
E
F
G
RELEASED FROM ENGINEERING
ADDED MOUNTING HOLE DIMENSION
REVISED MAX. INPUT POWER
REVISED OPERATING TEMPERATURE
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVEISED SPL & TEMPERATURE SPECIFICATIONS
REVISED TEMPERATURE SPECIFICATION
ADJUST RESONANT FREQUENCY RANGE TO READ Fo
12/7/2005
12/18/2007
7/18/2008
10/14/2008
11/8/2008
8/15/2012
8/21/2012
5/3/2017
R.W.
B.R.
C.W.
B.R.
M.L.
M.L.
M.L.
2003, Projects Unlimited Inc.
dBA
5%
370 20%
Fo ~ 20,000
ABS
PAPER
Nd-Fe-B
-40 ~ +80
16.5
Hz
Hz
28.4
C
grams
22
0.2
0.2
33.5
25.6
0.2
0.2
40
13
0.3
3
0.2
0.2
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AS04004PO-R.idw
Designed by
Date
Checked by
Date
Approved by
J.A.F.
12/6/2005
B.R.
12/7/2005
E.P.
Date
Drawn Date
12/7/2005 11/8/2008
AS04004PO-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AS04004PO-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 30+39.3490830+4.73690
- 60+35.4057960+4.26220
- 90+34.8184990+4.19150
- 240+34.14729240+4.11070
