Stereo Enclosed Speaker Set - 3W 4 Ohm
PRODUCT ID: 1669
Description
Listen up! This set of two 2.8" x 1.2" speakers are the perfect addition to any audio
project where you need 4 ohm impedance and 3W or less of power. We particularly like
these speakers as they are small and enclosed for good audio volume and quality. The
pair have a handy SPK input cable to add audio to your displays (the connectors are
similar to the JST-PH series which is ~2.0mm spacing).
We're specifically carrying these to use with our 10.1 inch, 7 inch, or 5.6 inch 1280x800
Display w/ Audio driver boards. However, they work peachy-keen with any of our audio
amps as well, such as the MAX98306, TS2012 or TPA2016 stereo class D amplifiers.
Technical Details
o
o
o
o
o
Weight: 25g per speaker
Dimensions: 30mm x 70mm x 17mm / 1.2" x 2.8" x .7"
Cable is 30" long total, 15" from each speaker to SPK plug
3.1mm diameter mounting holes
24mm x 64mm mounting rectangle
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1669”相匹配的价格&库存,您可以联系我们找货
