SMT-0827-SW-3V-R
SMT-0827-SW-3V-R
    PUIAUDIO
    BUZZER MAGNETIC 3.6V 8.5MM SMD
SMT-0827-SW-3V-R 数据手册
SPECIFICATIONS PARAMETERS VALUES RATED VOLTAGE (SQUARE WAVE) OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT UNIT Vp-p 3.6 Vp-p 2.5 ~ 4.5 60 mA 15 3 OHM 85 dBA 2730 200 Hz -40 ~ +85 C -50 ~ +95 C LCP Sn PLATED BRASS grams 0.6 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. 8.5 REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE CORRECT RESONANT FREQUENCY 3/29/2007 11/5/2007 6/12/2015 B.R. M.L. + TERMINAL 5.5 1.5 SOUND PORT 8.5 1.5 WASH TAB NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMT-0827-SW-3V-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 3/29/2007 D.F. 4/2/2007 R.W. 4/2/2007 11/5/2007 SMT-0827-SW-3V-R Transducer (Electro-Mech) Edition Sheet - 1/1
SMT-0827-SW-3V-R 价格&库存
很抱歉,暂时无法提供与“SMT-0827-SW-3V-R”相匹配的价格&库存,您可以联系我们找货
