AI-4028-P-SP32-R
AI-4028-P-SP32-R
    PUIAUDIO
    DC Buzzer Pulse, Slow 2.8kHz 1.5 PPS Piezo 4 ~ 32V 98dB @ 12V, 10cm
AI-4028-P-SP32-R 数据手册
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 3 ~ 32 9 98 2,800 500 SLOW PULSE -20 ~ +60 -30 ~ +60 ABS Sn PLATED BRONZE 16 Vdc Vdc mA dBA Hz 1.5 pulse/sec REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED VOLTAGE RANGE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED PIN LENGTH TO 8.5mm REVISED VOLTAGE RANGE 7/10/2006 1/28/2008 2/25/2008 9/25/2015 2/24/2020 B.R. B.R. M.L. M.V. 2003, Projects Unlimited Inc. C C - 23 grams 18.9 40 8.4 38.5 33.6 40 8.5 6.65 4.75 7.15 6.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-4028-P-SP32-R.idw Designed by Date Checked by Date Approved by J.D. 7/10/2006 E.P. 7/10/2006 R.W. Date Drawn Date 7/10/2006 2/25/2008 AI-4028-P-SP32-R Indicator Edition Sheet - 1/1
AI-4028-P-SP32-R 价格&库存
很抱歉,暂时无法提供与“AI-4028-P-SP32-R”相匹配的价格&库存,您可以联系我们找货
