Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CMI-1614C-120 | DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
• includes driving circuit
• wave solderable
• washable
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
typ
max
12.0
operating voltage
9.0
current consumption
rated frequency
sound pressure level
at 10 cm (A-weight), rated voltage
dimensions
Ø16.0 x 14.0
1,900
2,200
90
95
units
Vdc
13.0
Vdc
35
mA
2,500
Hz
dBA
mm
weight
5.0
material
PPS (S-206)
terminal
pin type (Au plating)
g
operating temperature
-40
85
°C
storage temperature
-40
85
°C
max
units
260
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
ŔŰŭťŦųŪůŨġőŰŵĻijķıƲĶƱń
Temperature (°C)
5±D0Tfd!nby
Dppmjoh!cz!bjs
B,C>21Tfd!Nby
őųŦĮũŦŢŵŪůŨġIJķıƱńġŎŢŹ
5±D0Tfd!nby
IJijıŴŦŤġŎŢŹ
Time (sec)
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMI-1614C-120 | DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
CMI-1614C-120
CUI CHINA
01
10
ŘņņŌ
ıIJġ
ıijġ
Śņłœ
IJıĮĮĮijıIJı
IJIJĮĮĮijıIJIJ
PERFORMANCE CURVES
Voltage vs. Current Consumption
at 25°C
100
95
90
85
6
8
10
12
14
Voltage (Vdc)
16
18
Sound Pressure Level (dB)
Voltage vs. Sound Pressure Level
at 10 cm, 25°C
cuidevices.com
30
25
10
6
8
10
12
14
Voltage (Vdc)
16
18
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Tray Size: 320 x 170 x 28 mm
Carton Size: 690 x 390 x 350 mm
Tray QTY: 50 pcs per tray
Carton QTY: 2,000 pcs per carton
3&6
Lot No.
XXXXXXXXXX
Model No. XXXXXXXXXX
Quantity.
XXXX
Pcs
Date:
DD MM YY
G
MADE IN CHINA
CUI Inc
The label is placed on the inner
boxes and outer carton.
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
03/31/2016
1.01
updated mechanical drawing
05/24/2016
1.02
brand update
11/22/2019
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMI-1614C-120”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+16.1064750+1.99800
- 150+16.03121150+1.98867
- 250+16.03085250+1.98862
- 500+16.03050500+1.98858
- 1000+16.030151000+1.98854
- 国内价格 香港价格
- 1+29.342671+3.63995
- 10+23.9398510+2.96973
- 25+22.0726625+2.73811
- 50+20.7626750+2.57560
- 100+19.53544100+2.42337
- 250+18.02991250+2.23661
- 450+17.13100450+2.12510
- 950+16.26723950+2.01795
