AI-4429-P-CP12-2-R
AI-4429-P-CP12-2-R
    PUIAUDIO
    AUDIOPIEZOINDICATOR4-16VPNL
AI-4429-P-CP12-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 4 ~ 16 25 105 2,900 500 CONTINUOUS/ SLOW PULSE -20 ~ +60 -30 ~ +70 ABS Ni PLATED BRASS 38.5 Vdc Vdc mA dBA Hz 0 pulse/sec 1.5 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING REVISED MOUNTING RING DIMENSIONS 5/10/2016 2/25/2020 M.V. 2003, Projects Unlimited Inc. C C grams 33.5 8.3 1 0.3 20.8 12.7 0.3 7.5 8 43 1 (-) FOR PULSE TONE 27.5 13 0.3 0.1 28.2 34 6.5 0.2 30.7 0.3 0.3 (+) FOR PULSE & SINGLE TONE (-) FOR SINGLE TONE 0.8 33 9.2 1 0.9 0.15 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-4429-P-CP12-2-R.idw Designed by Date Checked by Date Approved by J.D. 5/10/2016 E.P. 5/10/2016 B.R. Date Drawn Date 5/10/2016 5/10/2016 AI-4429-P-CP12-2-R Indicator Edition Sheet - 1/1
AI-4429-P-CP12-2-R 价格&库存
很抱歉,暂时无法提供与“AI-4429-P-CP12-2-R”相匹配的价格&库存,您可以联系我们找货
