Large Enclosed Piezo Element w/Wires
PRODUCT ID: 1739
DESCRIPTION
This large (30mm diameter) piezo element is nicely enclosed with mounting holes
so you can attach easily. Piezo elements convert vibration to voltage or voltage to
vibration. That means you can use this as a buzzer for making beeps, tones and
alerts AND you can use it as a sensor, to detect fast movements like knocks. You
can also use it under a drum pad to make a drum/crash sensor
It's rated for up to 12Vpp use but you can also use 3 or 5V square waves and its
plenty loud. For music use with an Arduino, check out the Tone tutorial. For
sensing, the Knock tutorial is your guide! There are thin wires attached, we plugged
them into a solderless breadboard, but they might too thin to plug in directly into
the Arduino socket headers.
https://www.adafruit.com/product/1739
1/21/2016
Technical Details
Rated Voltage (Square Wave): 12Vp-p
Operating Voltage: 1-30Vp-p
Rated Current (MAX): 3.5mA
Min. Sound Output at ten cm: 85db
Resonant Frequency: 1300Hz ± 500 / 4000HZ ± 500
Operating Temperature: -20℃ ~ +60℃
Dimensions:
Mounting Hole Width: 41mm / 1.6"
Diameter: 30mm / 1.2"
Center diameter: 5.7mm / 0.2"
Weight: 4.3g
很抱歉,暂时无法提供与“1739”相匹配的价格&库存,您可以联系我们找货
