CEP-1160
CEP-1160
    CUIDEVICES
    BUZZER PIEZO 10V 14MM RADIAL
CEP-1160 数据手册
Additional Resources: Product Page Date: 9/22/2006 Part No: CEP-1160 Unit: mm Specifications N U 20 Vp-p max. 10 mA max. at 10 Vp-p, square wave, 4.0 KHz 76 db min. at 10 cm / 10 Vp-p, square wave, 4.0 KHz 17,000 pF ±30% at 1 KHz / 1 V -20 ~ +60° C -30 ~ +70° C ø14.0 x H7.0 mm 0.7 g max. ABS UL-94 1/16” HB (Blue) Pin type yes TI Operating voltage Current consumption Sound pressure level Electrostatic capacity Operating tempurature Storage tempurature Dimensions Weight Material Terminal RoHS Page No: 1 of 4 ED Description: piezo audio transducer Appearance Drawing D IS C O N Tolerance: ±0.5 Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Additional Resources: Product Page Date: 9/22/2006 Part No: CEP-1160 Unit: mm Description: piezo audio transducer Page No: 2 of 4 TI N U ED Typical Frequency Response Curve D IS C O N Measurement Method S.P.L. Measuring Circuit Input Signal: 10 Vp-p, 4.0 KHz, Square Wave Mic: RION S.P.L. meter UC30 or equivalent S.G.: Hewlett Packard 33120A Function Generator or equivalent Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Additional Resources: Mechanical Characteristics Soldering Heat Resistance Terminal Mechanical Strength Date: 9/22/2006 Description: piezo audio transducer Page No: 3 of 4 Evaluation Standard Test Condition 90% min. of the lead terminals Lead terminals are immersed in rosin for will be wet with solder. 5 seconds and then immersed in solder bath (Except the edge of the terminal) of 270 ±5°C for 3 ±1 seconds. Lead terminals are immersed up to 1.5mm from No interference in operation. buzzer’s body in solder bath of 300 ±5°C for 3 ±0.5 seconds or 260 ±5°C for 10 ±1 seconds. No damage or cutting off. For 10 seconds, the force of 9.8N (1.0kg) is applied to each terminal in axial direction. The buzzer shall be measured after applying The value of oscillation a vibration amplitude of 1.5 mm with 10 to frequency/current consumption 55 Hz band of vibration frequency to each of should be ±10% of the initial the 3 perpendicular directions for 2 hours. measurements. The SPL should The part will be dropped from a height of be within ±10dB compared with 75 cm onto a 40 mm thick wooden board 3 the initial measurement. times in 3 axes (X, Y, Z) for a total of 9 drops. N Drop Test Environment Test Item High temp. test Test Condition After being placed in a chamber at +70°C for 240 hours. After being placed in a chamber at -30°C for 240 hours. After being placed in a chamber at +40°C and 90±5% relative humidity for 240 hours. The part shall be subjected to 5 cycles. One cycle will consist of: N Low temp. test TI 1. Not recommended for wave soldering Evaluation Standard The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. D IS C O Humidity test Temp. cycle test Unit: mm U Vibration Notes: Part No: CEP-1160 ED Item Solderability1 Product Page Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Additional Resources: Product Page Date: 9/22/2006 Part No: CEP-1160 Unit: mm Description: piezo audio transducer Page No: 4 of 4 Reliability Test Test Condition 1. Continuous life test: The part will be subjected to 250 hours of continuous operation at +45°C with rated voltage applied. U 2. Intermittent life test: A duty cycle of 1 minute on, 1 minute off, a minimum of 5,000 times at room temp (+25 ±2°C) with rated voltage applied. Test Conditions a) Tempurature: +5 ~ +35°C a) Tempurature: +25 ±2°C Packaging b) Humidity: 45 - 85% b) Humidity: 60 - 70% c) Pressure: 860-1060 mbar c) Pressure: 860-1060 mbar N Standard Test Condition Judgement Test Condition Evaluation Standard The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. ED Item Operating (Life Test) D IS C O N TI Each minimum unit will be individually packaged and be placed ina carton box. The box will be clearly marked with Part Number, Quantity, and Outgoing Inspection Number. There will be no mechanical damage on products during transportation and/or in storage. Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062
CEP-1160 价格&库存
很抱歉,暂时无法提供与“CEP-1160”相匹配的价格&库存,您可以联系我们找货
