9WP0612G401
9WP0612G401
    SANYODENKI
    FAN60X25MM12VDCIP68TACH
9WP0612G401 数据手册
Splash Proof Fan 60×60×25 mm IP68 ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in indoor free air at 60°C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black Yellow Sensor · Mass………………………………………… 110 g · Ingress protection………………………… IP68 ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 10.2 to 13.2 9WP0612G401 12 9WP0612D401 9WP0612H401 9WP0624J401 9WP0624G401 9WP0624H401 9WP0648H401 10.2 to 13.8 21.6 to 26.4 24 48 20.4 to 27.6 40 to 53 Max. airflow [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] SPL Operating temperature [dB (A)] [˚C] 0.21 2.52 5600 0.78 27.5 87.3 0.351 39 0.21 0.11 0.2 0.13 0.06 0.04 2.52 1.32 4.8 3.12 1.44 1.92 5150 3800 7600 5600 3800 3800 0.72 0.53 1.06 0.78 0.53 0.53 25 18.7 37.1 27.5 18.7 18.7 73.5 40.2 155.0 87.3 40.2 40.2 0.3 0.161 0.622 0.351 0.161 0.161 37 28 44 39 28 28 Expected life [h] 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) -20 to +60 -20 to +70 -20 to +60 40000/60˚C (70000/40˚C) -20 to +70 60000/60˚C (90000/40˚C) Note: Sensor and control options are available for selection. Refer to the table on pp. 638 to 639. ■ Airflow - Static Pressure Characteristics 9WP0612D401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 110 100 90 80 70 60 50 40 30 20 10 0 13.2 V 12 V 10.2 V 60 0.30 0.25 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) 5 10 15 20 25 30 Airflow CATALOG No. C1111B002 '21.9.IT (CFM) 0.25 0.20 80 13.8 V 60 12 V 0.20 0.15 0.10 0.05 0 280 (inch H2O) (Pa) 0.40 100 0.35 0 10.2 V 40 20 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) 0 5 10 15 20 25 30 Airflow With pulse sensor Operating voltage range (inch H2O) (Pa) Static pressure 0.45 9WP0612H401 With pulse sensor Static pressure 9WP0612G401 Static pressure Splash Proof Fan 60 mm sq. DC San Ace 60W 9WP type (CFM) 0.15 0.10 13.8 V 50 12 V 40 10.2 V 30 20 0.05 0 10 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 0 5 10 15 Airflow 20 25 (CFM) ■ Airflow - Static Pressure Characteristics 9WP0624G401 Operating voltage range Operating voltage range Static pressure 26.4 V 24 V 21.6 V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 (m3/min) 0 5 10 15 20 25 30 35 40 45 0.45 110 0.40 100 0.35 90 80 0.30 70 0.25 60 0.20 50 0.15 40 30 0.10 20 0.05 10 0 0 (inch H2O) (Pa) 0.20 27.6 V 24 V 20.4 V 5 10 15 20 25 30 Airflow 9WP0648H401 0.15 0.10 60 27.6 V 50 24 V 40 20.4 V 30 20 0.05 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) 0 (CFM) 0.25 Static pressure 0.8 200 0.7 180 160 0.6 140 0.5 120 0.4 100 0.3 80 60 0.2 40 0.1 20 0 0 With pulse sensor Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) Static pressure 9WP0624H401 With pulse sensor 10 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 0 (CFM) Airflow DC With pulse sensor 5 10 15 20 25 (CFM) Airflow With pulse sensor Operating voltage range (inch H2O) (Pa) 0.25 60 Static pressure 53 V 50 0.20 48 V 40 0.15 30 0.10 40 V 20 0.05 10 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 0 5 10 15 20 25 (CFM) Airflow ■ Dimensions (unit: mm) (With ribs) +1 60 0 50±0.3 25±0.5 4-ø4.3±0.3 Mounting hole (3) (3) +50 300 0 50±0.3 +1 60 0 Lead wire AWG24 UL 1007 (10) Rotating direction Airflow direction CATALOG No. C1111B002 '21.9.IT 281 Splash Proof Fan 60 mm sq. 9WP0624J401 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 59 50±0.3 59 29.7 62 .7 4-ø4.5 50±0.3 Splash Proof Fan 60 mm sq. DC 29.7 ■ Options Finger guards Model no.: 109-139E, 109-139H 282 CATALOG No. C1111B002 '21.9.IT page: p. 584 Resin finger guards Model no.: 109-1003G page: p. 591
9WP0612G401 价格&库存
很抱歉,暂时无法提供与“9WP0612G401”相匹配的价格&库存,您可以联系我们找货
