9WF0924H401
9WF0924H401
    SANYODENKI
    FAN92X25MM24VDCOILPROOFTACH
9WF0924H401 数据手册
Oil Proof Fan 92×92×25 mm San Ace 92WF 9WF type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black Sensor Yellow · Mass………………………………………… 120 g This fan can be used in environments with oil mist.* * Environment where cutting oil creates oil mist. Conduct a product evaluation with the type of oil to be used. ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 24 9WF0924H401 20.4 to 27.6 0.13 3.12 3900 Note: Sensor and control options are available for selection. Refer to the table on p. 637. ■ Airflow - Static Pressure Characteristics 9WF0924H401 With pulse sensor Operating voltage range (inch H2O) (Pa) Static pressure 0.3 80 27.6 V 70 24 V 60 0.2 20.4 V 50 40 0.1 30 20 10 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 (m3/min) 0 10 20 30 40 50 (CFM) Airflow ■ Dimensions (unit: mm) (With ribs) 92±0.5 82.5±0.3 4-ø4.3±0.3 Mounting hole (4) 25±0.5 (4) Lead wire AWG24 UL 1430 92±0.5 82.5±0.3 Oil Proof Fan 92 mm sq. DC · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) +50 300 0 (10) Rotating direction 384 CATALOG No. C1111B002 '21.9.IT Airflow direction Max. airflow [m3/min] 1.45 [CFM] 51.2 Max. static pressure [Pa] 66 [inchH2O] 0.26 SPL Operating temperature [dB (A)] [˚C] [h] -20 to +70 40000/60˚C (70000/40˚C) 42.5 Expected life ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) 4- ø 4.5 02 90.5 82.5±0.3 90.5 82.5±0.3 90.5 2 ø9 Outlet side 4- ø 4.5 ø1 90.5 82.5±0.3 Inlet side 82.5±0.3 page: p. 584 Oil Proof Fan 92 mm sq. Finger guards DC ■ Options Model no.: 109-099E, 109-099H, 109-099C CATALOG No. C1111B002 '21.9.IT 385
9WF0924H401 价格&库存
很抱歉,暂时无法提供与“9WF0924H401”相匹配的价格&库存,您可以联系我们找货
