Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
INTEGRATED CIRCUITS
74LVT162245B
3.3V LVT 16-bit transceiver
with 30Ω termination resistors (3-State)
Product specification
Supersedes data of 1995 Aug 22
IC23 Data Handbook
1998 Feb 19
3.3V 16-bit transceiver with 30Ω
74LVT162245B
FEATURES
DESCRIPTION
• 16-bit bidirectional bus interface
• 3-State buffers
• Output capability: +12mA/-12mA
• TTL input and output switching levels
• Input and output interface capability to systems at 5V supply
• Bus-hold data inputs eliminate the need for external pull-up
The 74LVT162245B is a high-performance BiCMOS product
designed for VCC operation at 3.3V.
This device is a 16-bit transceiver featuring non-inverting 3-State
bus compatible outputs in both send and receive directions. The
control function implementation minimizes external timing
requirements. The device features an Output Enable (nOE) input for
easy cascading and a Direction (DIR) input for direction control.
resistors to hold unused inputs
The 74LVT162245B is designed with 30Ω series resistance in both
the High and Low states of the output. This design reduces line
noise in applications such as memory address drivers, clock drivers,
and bus transceivers/transmitters.
• Live insertion/extraction permitted
• Outputs include series resistance of 30Ω making external
termination resistors unnecessary
• Power-up 3-State
• No bus current loading when output is tied to 5V bus
• Latch-up protection exceeds 500mA per JEDEC Std 17
• ESD protection exceeds 2000V per MIL STD 883 Method 3015
The 74LVT162245B is the same as the 74LVT16245B-1. The part
number has been changed to reflect industry standards.
and 200V per Machine Model
• Same part as 74LVT16245B-1
QUICK REFERENCE DATA
SYMBOL
CONDITIONS
Tamb = 25°C
PARAMETER
tPLH
tPHL
Propagation delay
nAx to nBx or nBx to nAx
CL = 50pF;
VCC = 3.3V
TYPICAL
UNIT
2.5
ns
CIN
Input capacitance DIR, OE
VI = 0V or 3.0V
3
pF
CI/O
I/O pin capacitance
VI/O = 0V or 3.0V
9
pF
ICCZ
Total supply current
Outputs disabled; VCC = 3.6V
70
µA
ORDERING INFORMATION
PACKAGES
TEMPERATURE RANGE
OUTSIDE NORTH AMERICA
NORTH AMERICA
DWG NUMBER
48-Pin Plastic SSOP Type III
–40°C to +85°C
74LVT162245B DL
VT162245B DL
SOT370-1
48-Pin Plastic TSSOP Type II
–40°C to +85°C
74LVT162245B DGG
VT162245B DGG
SOT362-1
PIN DESCRIPTION
LOGIC SYMBOL
PIN NUMBER
SYMBOL
1, 24
nDIR
NAME AND FUNCTION
1DIR
1
Direction control input
47, 46, 44, 43,
41, 40, 38, 37,
36, 35, 33, 32,
30, 29, 27, 26
nA0 – nA7
2, 3, 5, 6, 8, 9,
11, 12, 13, 14,
16, 17, 19, 20,
22, 23
nB0 – nB7
25, 48
nOE
Output enable input
(active-Low)
4, 10, 15, 21, 28,
34, 39, 45
GND
Ground (0V)
7, 18, 31, 42
VCC
Positive supply voltage
2DIR
48
1A0
47
2
46
3
44
5
43
6
41
8
40
9
38
11
37
12
24
25
1OE
1B0
2A0
1B1
2A1
1B2
2A2
1B3
2A3
1B4
2A4
1B5
2A5
1B6
2A6
1B7
2A7
36
13
35
14
33
16
32
17
30
19
29
22
26
23
2OE
2B0
Data inputs/outputs (A side)
1A1
1A2
Data inputs/outputs (B side)
1A3
1A4
1A5
1A6
1A7
2B1
2B2
2B3
2B4
2B5
2B6
2B7
SA00021
1998 Feb 19
2
853-1766 18989
74LVT162245B
PIN CONFIGURATION
LOGIC SYMBOL (IEEE/IEC)
1DIR
1
48 1OE
1OE
48
1B0
2
47 1A0
1DIR
1
1B1
3
46 1A1
4
45 GND
1B2
5
44 1A2
1B3
6
43 1A3
VCC
7
42 VCC
1B4
8
41 1A4
1B5
9
40 1A5
2DIR
GND
2B0
1A0
1A2
1A3
1A4
37 1A7
1A5
36 2A0
13
1A6
2B1 14
35 2A1
GND 15
34 GND
1A7
2A0
2B2 16
33 2A2
2B3 17
32 2A3
18
31 VCC
2A2
2B4 19
30 2A4
2A3
2B5 20
29 2A5
2A4
VCC
GND
21
2B6 22
2A5
27 2A6
2A6
26 2A7
2DIR 24
25 2OE
24
3 EN1 (BA)
∇1
47
2A7
1B0
46
3
44
5
43
6
41
8
40
9
38
11
37
12
1B1
1B2
1B3
1B4
1B5
∇1
36
13
1B6
1B7
2B0
35
14
33
16
32
17
2B3
30
19
2B4
29
22
26
23
2B1
2B2
2B5
2B6
2B7
SV00066
FUNCTION TABLE
SW00061
INPUTS
SCHEMATIC OF EACH OUTPUT
VCC
VCC
H
L
X
Z
22Ω
OUTPUT
20Ω
SW00202
1998 Feb 19
2
2∇
2A1
28 GND
2B7 23
G3
2∇
1A1
38 1A6
1B7 12
25
3 EN2 (AB)
39 GND
10
1B6 11
3 EN1 (BA)
3 EN2 (AB)
2OE
GND
G3
3
INPUTS/OUTPUTS
nOE
nDIR
nAx
nBx
L
L
nAx = nBx
Inputs
L
H
Inputs
nBx = nAx
H
X
Z
Z
= High voltage level
= Low voltage level
= Don’t care
= High Impedance “off ” state
74LVT162245B
ABSOLUTE MAXIMUM RATINGS1,2
PARAMETER
SYMBOL
VCC
IIK
RATING
UNIT
–0.5 to +4.6
V
–50
mA
–0.5 to +7.0
V
VO < 0
–50
mA
Output in Off or High state
–0.5 to +7.0
V
Output in Low state
128
Output in High state
–64
DC supply voltage
DC input diode current
VI < 0
voltage3
VI
DC input
IOK
DC output diode current
VOUT
CONDITIONS
DC output
voltage3
IOUT
O
DC output current
Tstg
Storage temperature range
mA
–65 to +150
°C
NOTES:
1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the
device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
2. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150°C.
3. The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
RECOMMENDED OPERATING CONDITIONS
SYMBOL
VCC
PARAMETER
LIMITS
DC supply voltage
UNIT
MIN
MAX
2.7
3.6
V
V
VI
Input voltage
VIH
High-level input voltage
VIL
Input voltage
0.8
V
IOH
High-level output current
–12
mA
IOL
Low-level output current
12
mA
∆t/∆v
Input transition rise or fall rate; Outputs enabled
10
ns/V
Tamb
Operating free-air temperature range
+85
°C
1998 Feb 19
2.0
–40
4
V
74LVT162245B
DC ELECTRICAL CHARACTERISTICS
LIMITS
SYMBOL
PARAMETER
TEST CONDITIONS
Temp = –40°C to +85°C
MIN
TYP1
MAX
0.8
–1.2
VIK
Input clamp voltage
VCC = 2.7V; IIK = –18mA
VOH
High-level output voltage
VCC = 3.0V; IOH = –12mA
VOL
Low-level output voltage
VCC = 3.0V; IOL = 12mA
0.3
0.8
VCC = 3.6V; VI = VCC or GND
0.1
±1
0.1
10
0.5
10
VCC = 3.6V; VI = 0
0.1
-5
VCC = 0V; VI or VO = 0 to 4.5V
0.1
±100
Input leakage current
II
Output off current
IHOLD
Bus H
B
Hold
ld currentt
A or B outputs6
IPU/PD
VCC = 3V; VI = 0.8V
75
130
VCC = 3V; VI = 2.0V
–75
–130
VCC = 0V to 3.6V; VCC = 3.6V
±500
V
µA
µA
µA
VO = 5.5V; VCC = 3.0V
75
125
µA
Power up/down 3-State output
current3
VCC ≤ 1.2V; VO = 0.5V to VCC; VI = GND or VCC;
OE/OE = Don’t care
40
±100
µA
0.07
0.12
4.2
6
0.07
0.12
0.1
0.2
VCC = 3.6V; Outputs High, VI = GND or VCC, IO = 0
Quiescent supply current
ICCZ
∆ICC
V
Current into an output in the
High state when VO > VCC
ICCH
ICCL
I/O Data
pins4
V
2.5
Control pins
VCC = 0 or 3.6V; VI = 5.5V
IOFF
IEX
2.0
UNIT
VCC = 3.6V; Outputs Low, VI = GND or VCC, IO = 0
VCC = 3.6V; Outputs Disabled; VI = GND or VCC, IO =
Additional supply current per
input pin2
05
VCC = 3V to 3.6V; One input at VCC-0.6V,
Other inputs at VCC or GND
mA
mA
NOTES:
1. All typical values are at VCC = 3.3V and Tamb = 25°C.
2. This is the increase in supply current for each input at the specified voltage level other than VCC or GND
3. This parameter is valid for any VCC between 0V and 1.2V with a transition time of up to 10msec. From VCC = 1.2V to VCC = 3.3V ± 0.3V a
transition time of 100µsec is permitted. This parameter is valid for Tamb = 25°C only.
4. Unused pins at VCC or GND.
5. ICCZ is measured with outputs pulled to VCC or GND.
6. This is the bus hold overdrive current required to force the input to the opposite logic state.
AC CHARACTERISTICS
GND = 0V; tR = tF = 2.5ns; CL = 50pF; RL = 500Ω; Tamb = –40°C to +85°C.
LIMITS
SYMBOL
PARAMETER
VCC = 3.3V ±0.3V
WAVEFORM
VCC = 2.7V
MIN
TYP1
MAX
MAX
UNIT
tPLH
tPHL
Propagation delay
nAx to bBx or bBx to nAx
1
1.0
1.0
2.5
2.2
3.5
3.5
3.9
3.9
ns
tPZH
tPZL
Output enable time
to High and Low level
2
1.5
1.5
3.5
3.2
5.3
4.4
6.4
5.0
ns
tPHZ
tPLZ
Output disable time
from High and Low Level
2
1.5
1.5
3.5
4.3
4.8
6.7
5.1
5.9
ns
NOTE:
1998 Feb 19
5
74LVT162245B
AC WAVEFORMS
VM = 1.5V, VIN = GND to 2.7V
2.7V
2.7V
NAX OR NBX
INPUT
NOE INPUT
1.5V
1.5V
1.5V
1.5V
0V
0V
TPLZ
TPZL
TPLH
TPHL
3.0V
VOH
NBX OR NAX
OUTPUT
1.5V
OUTPUT
1.5V
VOL + 0.3V
1.5V
TPHZ
TPZH
VOL
VOL
VOH
VOH – 0.3V
SV00065
OUTPUT
1.5V
Waveform 1. Input to Output Propagation Delays
0V
SV00067
Waveform 2. 3-State Output Enable and Disable Times
TEST CIRCUIT AND WAVEFORMS
6V
VCC
VIN
VOUT
PULSE
GENERATOR
tW
90%
OPEN
RL
GND
10%
10%
0V
tTHL (tF)
CL
tTLH (tR)
tTLH (tR)
RL
tTHL (tF)
90%
POSITIVE
PULSE
Test Circuit for 3-State Outputs
SWITCH
tPHZ/tPZH
GND
tPLZ/tPZL
6V
tPLH/tPHL
open
AMP (V)
90%
VM
VM
10%
10%
tW
SWITCH POSITION
TEST
AMP (V)
VM
VM
NEGATIVE
PULSE
D.U.T.
RT
90%
0V
VM = 1.5V
Input Pulse Definition
INPUT PULSE REQUIREMENTS
DEFINITIONS
FAMILY
RL = Load resistor; see AC CHARACTERISTICS for value.
CL = Load capacitance includes jig and probe capacitance;
74LVT16
Amplitude
Rep. Rate
tW
tR
2.7V
≤10MHz
500ns
≤2.5ns
tF
≤2.5ns
RT = Termination resistance should be equal to ZOUT of
pulse generators.
SW00003
1998 Feb 19
6
SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm
1998 Feb 19
7
74LVT162245B
SOT370-1
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1mm
1998 Feb 19
8
74LVT162245B
SOT362-1
NOTES
1998 Feb 19
9
74LVT162245B
with 30 termination resistors (3-State)
74LVT162245B
Data sheet status
Data sheet
status
Product
status
Definition [1]
Objective
specification
Development
This data sheet contains the design target or goal specifications for product development.
Specification may change in any manner without notice.
Preliminary
specification
Qualification
This data sheet contains preliminary data, and supplementary data will be published at a later date.
Philips Semiconductors reserves the right to make chages at any time without notice in order to
improve design and supply the best possible product.
Product
specification
Production
This data sheet contains final specifications. Philips Semiconductors reserves the right to make
changes at any time without notice in order to improve design and supply the best possible product.
[1] Please consult the most recently issued datasheet before initiating or completing a design.
Definitions
Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For
detailed information see the relevant data sheet or data handbook.
Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one
or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or
at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended
Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips
Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or
modification.
Disclaimers
Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can
reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications
do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application.
Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard
cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no
responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these
products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless
otherwise specified.
Copyright Philips Electronics North America Corporation 1998
All rights reserved. Printed in U.S.A.
811 East Arques Avenue
P.O. Box 3409
Sunnyvale, California 94088–3409
Telephone 800-234-7381
print code
Document order number:
yyyy mmm dd
10
Date of release: 05-96
9397-750-03553
