9SG1212P1G01
9SG1212P1G01
    SANYODENKI
    FAN120X38MM12VDCRBLSTACH,PWM
9SG1212P1G01 数据手册
120×120×38 mm San Ace 120 9SG type Model 9SG1224H101 is not certified. ■ General Specifications · Material……………………………………… Frame: Aluminum, Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Sensor Yellow · Mass………………………………………… 400 g ■ Specifications The models listed below have pulse sensors. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed SPL Operating temperature Expected life [V] [V] [A] [W] [min-1] [m3/min] [CFM] [Pa] [inchH2O] [dB (A)] [˚C] [h] 12 10.2 to 13.8 24 20.4 to 27.6 6000 6000 3400 6000 7.35 7.35 4.02 7.35 260 260 142 260 340 340 126 340 1.37 1.37 0.51 1.37 64 64 48 64 40000/60˚C (70000/40˚C) 40.8 to 55.2 48.0 48.0 11.0 48.0 -20 to +70 48 4.0 2.0 0.46 1.0 9SG1212G101 9SG1224G101 9SG1224H101 9SG1248G101 Max. airflow Max. static pressure Note 1: Sensor and control options are available for selection. Refer to the table on p. 636. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics 9SG1212G101 9SG1224G101 With pulse sensor Operating voltage range 1.25 400 350 300 1.00 250 0.75 200 0.50 0.25 0 (inch H2O) (Pa) 1.50 12 V 10.2 V 150 100 0 1.25 1 2 3 4 5 6 7 8 9 (m3/min) 50 100 150 200 250 300 Airflow CATALOG No. C1111B002 '21.9.IT (CFM) 450 400 350 300 1.00 250 0.75 200 0.50 0.25 50 0 184 1.75 13.8 V 0 (inch H2O) (Pa) 27.6 V 24 V 20.4 V 150 100 0 0.7 180 160 0.6 140 0.5 120 1 2 3 4 5 6 7 8 9 (m3/min) 50 100 150 200 250 300 Airflow (CFM) 27.6 V 24 V 20.4 V 0.4 100 0.3 0.2 0.1 50 0 With pulse sensor Operating voltage range Static pressure 1.50 450 Static pressure 1.75 9SG1224H101 With pulse sensor Operating voltage range (inch H2O) (Pa) Static pressure DC DC Fan 120 mm sq. DC Fan 0 80 60 40 20 0 1 2 3 4 5 (m3/min) 0 20 40 60 80 100120140160 180 (CFM) Airflow With pulse sensor DC Fan 120 mm sq. 9SG1248G101 DC ■ Airflow - Static Pressure Characteristics Operating voltage range (inch H2O) (Pa) 1.75 Static pressure 1.50 1.25 450 350 250 0.75 200 0.25 0 48 V 300 1.00 0.50 55.2 V 400 40.8 V 150 100 50 0 1 2 3 4 5 6 7 8 9 (m3/min) 0 50 100 150 200 250 300 (CFM) Airflow ■ Dimensions (unit: mm) 8-ø4.3±0.3 Mounting hole Lead wire AWG24 UL 1007 120±0.8 104.8±0.3 AWG22 UL 1430 (Model no.: 9SG1212G101 only) +30 300 0 (10) 6.5±0.3 (3.5) 104.8±0.3 120±0.8 6.5±0.3 (3.5) 38±0.5 Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side Outlet side 104.8±0.3 4-ø4.5 118 118 104.8±0.3 35 ø1 104.8±0.3 27 ø1 118 104.8±0.3 4-ø4.5 118 ■ Options Finger guards page: p. 585 Model no.: 109-019E, 109-019K, 109-019C, 109-019H Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1000G page: p. 592 Model no.: 109-1000F13 (13PPI), 109-1000F20 (20PPI), 109-1000F30 (30PPI), 109-1000F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 185
9SG1212P1G01 价格&库存
很抱歉,暂时无法提供与“9SG1212P1G01”相匹配的价格&库存,您可以联系我们找货
