Counter Rotating Fan
60
San Ace 60
51mm thick (CR type), 76mm thick (CRA type)
76mm thick (CR type)
mm sq.
■ General Specifications With a pulse sensor Specifications for pulse sensors
Refer to Page 309
・Material …………………… Frame: Plastics (Flammability: UL94V-0),
Impeller:Plastics (Flammability: UL94V-1)
・Expected Life …………… Varies for each model(L10:Survival rate:90% at 60℃ ,
rated voltage, and continuously run in a free air state)
䊝red
䊞black Sensor yellow
Outlet 䊝orange 䊞gray Sensor purple
・Storage Temperature …−30℃ to +70℃(Non-condensing)
・Lead Wire ………………… Inlet
60×60×76mm
〔Mass:230g〕
CR type
■ Specifications
Model No.
Rated Voltage Operating Voltage Range Rated Current Rated Input
[V]
[V]
[A]
Rated Speed
[min-1]
[W]
Inlet
9CR0612S001
9CR0612H001
Without Sensor
12
3.2
2.7
10.8 to 13.2
Available upon request for all the
Pulse Sensor models above.
Max. Air Flow
[m³/min]
[CFM]
2.26
1.98
80
70
Lock Sensor
SPL
Operating Temperature Expected Life
[h]
−10 to +60
40,000
Outlet
11,500 7,000
10,300 6,500
38.4
32.4
Max. Static Pressure
[Pa] [inchH²O] [dB(A)]
550
450
2.21
1.81
66
64
Please inquire as the availability of these functions depend
PWM Control on the model.
■ Dimensions(Unit : mm)
Inlet side
Outlet side
76±0.5
(4)
60±0.5
(4)
50±0.3
(10)
50±0.3
(10)
+50
300 0
Lead
Wire
リード線
AWG24
UL1007
UL1007
AWG24
Rotating
Direction
回転方向
Air Flow
Direction
風吹出方向
■ Reference dimension of mounting holes and vent opening(Unit : mm)
Inlet side, Outlet side
59
50 ± 0.3
191
59
50 ± 0.3
4-φ4.5
29.7
62
.7
29.7
4-φ4.3±0.3
Mounting
Hole
取付用穴
Rotating
Direction
回転方向
60±0.5
+50
300 0
4-φ4.3±0.3
Mounting
Hole
取付用穴
■ Options(Unit : mm)
Finger guards
Resin finger guards
Model:109-139E
:109-139H
Model:109-1003G
Color
Surface treatment :Nickel-chrome plating(silver)
:Cation electropainting(black)
+1
4 0
4.3±0.3
60.5±1
6.5±0.5
50±0.3
4-2±0.5
4-φ4.3±0.3
Counter Rotating Fan 60mm
62
50±0.3
+1.5
75 ー0.5
60.5±1
φ1.6
φ1.6
φ53
φ70.7
Resin filter kits
Model:109-1003F13(13PPI)
,109-1003F20(20PPI)
:109-1003F30(30PPI)
,109-1003F40(40PPI)
9.5±0.5
64±1
4-φ4.3±0.3
50±0.3
64±1
50±0.3
4-φ10±0.5
4-2±0.5
■ Air Flow - Static Pressure Characteristics
S speed
(inch H2O)(Pa)
H speed
(inch H2O)(Pa)
2.5
700
600
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
2.5
12V
2.0
1.5
500
10.8V
400
300
1.0
200
0.5
100
13.2V
0.5 1.0 1.5 2.0 2.5 3.0 (m3/min)
60
80 100
Air風量
Flow
9CR0612S001
(CFM)
2.0
13.2V
500
12V
1.5
400
10.8V
300
1.0
200
0.5
1.0
1.5
2.0
2.5 (m3/min)
0 10 20 30 40 50 60 70 80 90(CFM)
Air風量
Flow
9CR0612H001
60mm
3.0
192
很抱歉,暂时无法提供与“9CR0612P0S03”相匹配的价格&库存,您可以联系我们找货
