Long Life Fan
60
San Ace 60L
25mm thick
mm sq.
■ General Specifications
・Material …………………… Frame: Aluminum, Impeller: Plastics (Flammability: UL94V-1)
・Expected Life …………… Refer to specifications (L10:Survival rate: 90% at 60℃ ,
rated voltage, and continuously run in a free air state)
・Lead Wire ………………… 䊝red 䊞black or blue Sensor yellow
・Storage Temperature …−30℃ to +70℃(Non-condensing)
60×60×25mm
■ Specifications
〔Mass:100g〕
The following nos. have pulse sensors.
Rated Voltage Operating Voltage Range Rated Current Rated Input
Model No.
[V]
109L0612G401
109L0612S401
109L0612H401
109L0612F401
109L0612M401
109L0624D401
109L0624S401
109L0624H401
109L0624F401
109L0624M401
109L0648G401
109L0648H401
12
[V]
10.2 to 13.8
24
20.4 to 27.6
48
40.8 to 55.2
40 to 53
Rated Speed
Max. Air Flow
Max. Static Pressure
[A]
[W]
[min-1]
[m³/min]
[CFM]
0.24
0.17
0.11
0.09
0.06
0.12
0.08
0.06
0.05
0.04
0.07
0.04
2.88
2.04
1.32
1.08
0.72
2.88
1.92
1.44
1.20
0.96
3.36
1.92
5,600
4,600
3,800
3,200
2,600
5,150
4,600
3,800
3,200
2,600
5,600
3,800
0.78
0.65
0.53
0.44
0.36
0.72
0.65
0.53
0.44
0.36
0.78
0.53
27.5
23.0
18.7
15.5
12.7
25.4
23.0
18.7
15.5
12.7
27.5
18.7
SPL
Operating Temperature Expected Life
[Pa] [inchH²O] [dB(A)]
87.3
56.8
40.2
29.4
19.6
73.8
56.8
40.2
29.4
19.6
87.3
40.2
0.35
0.228
0.161
0.118
0.079
0.296
0.230
0.161
0.118
0.079
0.35
0.161
39
33
28
24
33
28
24
28
[h]
− 20 to + 70
100,000
− 20 to + 60
− 20 to + 70
80,000
100,000
・Available options: ⇒ Without Sensor
・Please inquire as the availability of these functions depend on the model. ⇒ Lock Sensor
Low speed Sensor
■ Dimensions(Unit : mm)
■ Reference dimension of
mounting holes and vent opening(Unit : mm)
+1
60 0
8-φ4.3±0.3
Mounting
取付用穴 Hole 3.5±0.3
Lead
Wire
リード線
AWG24
UL1007
Inlet side, Outlet side
25±0.5
59
3.5±0.3
50±0.3
29.7
4-φ4.5
+50
300 0
Rotating
Direction
回転方向
Air Flow
Direction
風吹出方向
■ Options(Unit : mm)
Finger guards
Resin Finger guards
Model:109-139E
:109-139H
Model:109-1003G
Color
Surface treatment :Nickel-chrome plating(silver)
:Cation electropainting(black)
+1
4.3±0.3
50±0.3
62
75
φ70.7
281
60.5±1
φ1.6
φ1.6
+1.5
ー0.5
φ53
4 0
60.5±1
6.5±0.5
50±0.3
4-2±0.5
4-φ4.3±0.3
59
29.7
(10)
50±0.3
62
.7
50±0.3
+1
60 0
50±0.3
Resin filter kits
64±1
Model:109-1003F13(13PPI)
,109-1003F20(20PPI)
:109-1003F30(30PPI)
,109-1003F40(40PPI)
9.5±0.5
4-φ4.3±0.3
50±0.3
64±1
50±0.3
4-φ10±0.5
4-2±0.5
■ Air Flow - Static Pressure Characteristics
0.05
13.8V
12V
10.2V
5
10 15 20 25 30
0.25
0.20
0.15
0.10
0.05
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min)
0.35
0.30
0.4
120
110
100
90
80
70
60
50
40
30
55.2V
48V
40.8V
Air風量
Flow
5
10 15 20 25 30
S speed
0.20
50
0.15
40
0.25
13.8V/27.6V
12V/24V
10.2V/20.4V
30
0.10
10
10
15
0.20
0.15
13.8V/27.6V
40
12V/24V
10.2V/20.4V
10
0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min)
10
15
(CFM)
25
30(CFM)
F speed
0.20
50
53V
0.15
40
48V
30
40V
0.10
10
15
25(CFM)
Air風量
Flow
109L0612H401
109L0624H401
109L0648H401
M speed
(inch H2O)(Pa)
0.12
13.8V/27.6V
40
12V/24V
0.10
10.2V/20.4V
0.1 0.2 0.3 0.4 0.5 0.6 (m3/min)
10
15
30
13.8V/27.6V
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
15
109L0624D401
Air風量
Flow
30
5
(m3/min)
H speed
50
(CFM)
0.20
0.05
(inch H2O)(Pa)
0.10
109L0612S401
109L0624S401
0.15
Air風量
Flow
(inch H2O)(Pa)
Air風量
Flow
30
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 (m3/min)
0.1
H speed
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
60
20.4V
0.2
(CFM)
(inch H2O)(Pa)
80
0.25
24V
60
109L0648G401
(inch H2O)(Pa)
70
80
Air風量
Flow
109L0612G401
0.30
0.3
(CFM)
100
27.6V
→ Static
→ Pressure
静圧
0.25
0.20
0.15
0.10
0.45
(inch H2O)
(Pa)
→ Static
Pressure
→ 静圧
0.40
0.35
0.30
120
110
100
90
80
70
60
50
40
30
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
0.45
D speed
(inch H2O)(Pa)
Long Life Fan 60mm
G speed
G speed
(inch H2O)(Pa)
Air風量
Flow
109L0612F401
109L0624F401
(CFM)
0.10
0.08
12V/24V
0.04
10.2V/20.4V
10
0.02
5
0.3
0.4
10
15
0.5 (m3/min)
(CFM)
Air風量
Flow
109L0612M401
109L0624M401
282
很抱歉,暂时无法提供与“109L0612H402”相匹配的价格&库存,您可以联系我们找货
