74LVCH16244ABX,518
74LVCH16244ABX,518
    NEXPERIA(安世)
    SOT-1134-2
    IC BUF NON-INVERT 3.6V 60HXQFN
74LVCH16244ABX,518 数据手册
74LVC16244A; 74LVCH16244A 16-bit buffer/line driver; 5 V input/output tolerant; 3-state Rev. 16 — 21 September 2021 Product data sheet 1. General description The 74LVC16244A; 74LVCH16244A is a 16-bit buffer/line driver with 3-state outputs. The device can be used as four 4-bit buffers, two 8-bit buffers or one 16-bit buffer. The device features four output enables (1OE, 2OE, 3OE and 4OE), each controlling four of the 3-state outputs. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. The 74LVCH16244A bus hold on data inputs eliminates the need for external pull-up resistors to hold unused inputs. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range from 1.2 V to 3.6 V 5 V tolerant inputs/outputs for interfacing with 5 V logic IOFF circuitry provides partial Power-down mode operation CMOS low power consumption Multibyte flow-through standard pin-out architecture Low inductance multiple power and ground pins for minimum noise and ground bounce Direct interface with TTL levels High-impedance when VCC = 0 V All data inputs have bus hold. (74LVCH16244A only) Complies with JEDEC standard: • JESD8-7A (1.65 V to 1.95 V) • JESD8-5A (2.3 V to 2.7 V) • JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-B exceeds 200 V • CDM ANSI/ESDA/Jedec JS-002 exceeds 1000 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 3. Ordering information Table 1. Ordering information Type number Temperature range Package 74LVC16244ADGG Name Description Version -40 °C to +125 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 -40 °C to +125 °C TVSOP48 plastic thin shrink small outline package; 48 leads; body width 4.4 mm; lead pitch 0.4 mm SOT480-1 74LVCH16244ADGG 74LVC16244ADGV 74LVCH16244ADGV 4. Functional diagram 1A0 1A1 1A2 1A3 1OE 47 2 46 3 44 5 43 6 1Y0 3A0 1Y1 3A1 1Y2 3A2 1Y3 3A3 1 3OE 36 13 35 14 33 16 32 17 3Y0 3Y1 1 1OE 48 2OE 25 3OE 24 4OE 3Y2 3Y3 1A0 1A1 25 1A2 1A3 2A0 2A1 41 40 8 9 2Y0 2Y1 4A0 4A1 19 30 29 20 2A0 2A1 4Y0 2A2 2A3 3A0 4Y1 3A1 2A2 2A3 2OE 38 37 11 12 2Y2 2Y3 48 4A2 4A3 4OE 22 27 23 26 3A2 4Y2 3A3 4A0 4A1 4Y3 4A2 24 4A3 EN1 EN2 EN3 EN4 47 46 Logic symbol 2 1 3 44 5 43 6 41 40 1 8 2 9 38 11 37 12 36 35 1 3 13 14 33 16 32 17 30 29 1 4 19 20 27 22 26 23 1Y0 1Y1 1Y2 1Y3 2Y0 2Y1 2Y2 2Y3 3Y0 3Y1 3Y2 3Y3 4Y0 4Y1 4Y2 4Y3 001aae231 mna996 Fig. 1. 1 Fig. 2. IEC logic symbol VCC data input to internal circuit mna705 Fig. 3. Bus hold circuit 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 2 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 5. Pinning information 5.1. Pinning 1OE 1 48 2OE 1Y0 2 47 1A0 1Y1 3 46 1A1 GND 4 45 GND 1Y2 5 44 1A2 1Y3 6 43 1A3 VCC 7 42 VCC 2Y0 8 41 2A0 2Y1 9 40 2A1 GND 10 39 GND 2Y2 11 38 2A2 2Y3 12 37 2A3 74LVC16244A 74LVCH16244A 3Y0 13 3Y1 14 36 3A0 35 3A1 GND 15 34 GND 3Y2 16 33 3A2 3Y3 17 32 3A3 VCC 18 31 VCC 4Y0 19 30 4A0 4Y1 20 29 4A1 GND 21 28 GND 4Y2 22 27 4A2 4Y3 23 26 4A3 4OE 24 25 3OE 001aaj052 Fig. 4. Pin configuration SOT362-1 (TSSOP48) and SOT480-1 (TVSOP48) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 48, 25, 24 output enable input (active LOW) 1Y0 to 1Y3 2, 3, 5, 6 data output 2Y0 to 2Y3 8, 9, 11, 12 data output 3Y0 to 3Y3 13, 14, 16, 17 data output 4Y0 to 4Y3 19, 20, 22, 23 data output GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 1A0 to 1A3 47, 46, 44, 43 data input 2A0 to 2A3 41, 40, 38, 37 data input 3A0 to 3A3 36, 35, 33, 32 data input 4A0 to 4A3 30, 29, 27, 26 data input 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 3 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input Output nOE nAn nYn L L L L H H H X Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage output HIGH or LOW [2] -0.5 VCC + 0.5 V output 3-state [2] -0.5 +6.5 V IO output current - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] VI < 0 V [1] VO = 0 V to VCC Tamb = -40 °C to +125 °C; [3] mA The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. For SOT362-1 (TSSOP48) packages: Ptot derates linearly with 12.2 mW/K above 109 °C. For SOT480-1 (TVSOP48) packages: Ptot derates linearly with 5.5 mW/K above 60 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC 1.65 - 3.6 V 1.2 - 3.6 V supply voltage functional VI input voltage VO output voltage 0 - 5.5 V output HIGH or LOW 0 - VCC V output 3-state 0 - 5.5 V -40 - +125 °C Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate VCC = 1.2 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 4 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage Conditions -40 °C to +85 °C VCC = 1.2 V VCC = 1.65 V to 1.95 V LOW-level output voltage Min Typ[1] Max Min Max 1.08 - - 1.08 - V 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V - - 0.12 - 0.12 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC-0.2 - - VCC-0.3 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = -8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = -18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = -24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 μA; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V - ±0.1 ±5 - ±20 μA - ±0.1 ±5 - ±20 μA LOW-level input VCC = 1.2 V voltage VCC = 1.65 V to 1.95 V HIGH-level output voltage -40 °C to +125 °C Unit 0.35VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 3.6 V VI = VIH or VIL II input leakage current VCC = 3.6 V; VI = 5.5 V or GND IOZ OFF-state output current VI = VIH or VIL; VCC = 3.6 V; VO = 5.5 V or GND IOFF power-off VCC = 0 V; VI or VO = 5.5 V leakage current - ±0.1 ±10 - ±20 μA ICC supply current VCC = 3.6 V; IO = 0 A; VI = VCC or GND - 0.1 20 - 80 μA ΔICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 - 5000 μA CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 5.0 - - - pF IBHL bus hold LOW current VCC = 1.65; VI = 0.58 V 10 - - 10 - μA 30 - - 25 - μA [2] [3][4] VCC = 2.3; VI = 0.7 V VCC = 3.0; VI = 0.8 V IBHH bus hold HIGH current 74LVC_LVCH16244A Product data sheet 75 - - 60 - μA -10 - - -10 - μA VCC = 2.3; VI = 1.7 V -30 - - -25 - μA VCC = 3.0; VI = 2.0 V -75 - - -60 - μA VCC = 1.65; VI = 1.07 V [3] [4] All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 5 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state Symbol Parameter IBHLO IBHHO [1] [2] [3] [4] [5] Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max 200 - - 200 - μA VCC = 2.7 V 300 - - 300 - μA VCC = 3.6 V 500 - - 500 - μA -200 - - -200 - μA VCC = 2.7 V -300 - - -300 - μA VCC = 3.6 V -500 - - -500 - μA bus hold LOW overdrive current VCC = 1.95 V bus hold HIGH overdrive current VCC = 1.95 V [3] [5] [3] [5] All typical values are measured at VCC = 3.3 V and Tamb = 25 °C. The bus hold circuit is switched off when VI > VCC allowing 5.5 V on the input terminal. Valid for data inputs only. Control inputs do not have a bus hold circuit. The specified sustaining current at the data input holds the input below the specified VI level. The specified overdrive current at the data input forces the data input to the opposite logic input state. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 7. Symbol Parameter tpd ten propagation delay enable time Conditions -40 °C to +85 °C Typ[1] Max Min Max - 11.0 - - - ns VCC = 1.65 V to 1.95 V 1.5 4.8 10.7 1.5 11.3 ns VCC = 2.3 V to 2.7 V 1.0 2.6 5.3 1.0 5.9 ns VCC = 2.7 V 1.0 2.6 4.7 1.0 6.0 ns VCC = 3.0 V to 3.6 V 1.1 2.2 4.1 1.1 5.5 ns nAn to nYn; see Fig. 5 [2] VCC = 1.2 V nOE to nYn; see Fig. 6 [2] - 15.0 - - - ns VCC = 1.65 V to 1.95 V 1.5 6.2 12.1 1.5 12.7 ns VCC = 2.3 V to 2.7 V 1.0 3.5 6.4 1.0 7.1 ns VCC = 2.7 V 1.0 3.3 5.8 1.0 7.5 ns VCC = 3.0 V to 3.6 V 1.0 2.8 4.6 1.0 6.0 ns - 10.0 - - - ns VCC = 1.65 V to 1.95 V 2.5 4.4 8.7 2.5 9.4 ns VCC = 2.3 V to 2.7 V 1.0 2.4 4.9 1.0 5.3 ns VCC = 2.7 V 1.0 3.2 6.2 1.0 8.0 ns 1.8 3.1 5.2 1.8 6.5 ns - 4.8 - - - pF - 8.3 - - - pF - 11.4 - - - pF disable time nOE to nYn; see Fig. 6 [2] VCC = 1.2 V VCC = 3.0 V to 3.6 V CPD per input; VI = GND to VCC power dissipation VCC = 1.65 V to 1.95 V capacitance VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V [1] [2] [3] Unit Min VCC = 1.2 V tdis -40 °C to +125 °C [3] Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively. tpd is the same as tPLH and tPHL; ten is the same as tPZL and tPZH; tdis is the same as tPLZ and tPHZ. 2 2 CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF 2 VCC = supply voltage in Volts; N = number of inputs switching; ∑(CL x VCC x fo) = sum of the outputs. 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 6 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 10.1. Waveforms and test circuit VI nAn input VM VM GND tPLH tPHL VOH VM nYn output VM VOL mna171 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. The input (nAn) to output (nYn) propagation delays VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs disabled outputs enabled mna362 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. 3-state enable and disable times Table 8. Measurement points Supply voltage Input Output VCC VM VI VM VX VY 1.2 V 0.5 × VCC VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 1.65 V to 1.95 V 0.5 × VCC VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V 0.5 × VCC VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 1.5 V 2.7 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 1.5 V 2.7 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 7 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC VI G RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 7. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 8 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 11. Package outline TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 Fig. 8. References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Package outline SOT362-1 (TSSOP48) 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 9 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state TVSOP48: plastic thin shrink small outline package; 48 leads; body width 4.4 mm; lead pitch 0.4 mm SOT480-1 E D A X c y HE v M A Z 25 48 Q A2 (A 3) A1 pin 1 index A θ Lp L detail X 1 24 w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.85 0.25 0.23 0.13 0.20 0.09 9.8 9.6 4.5 4.3 0.4 6.6 6.2 1 0.7 0.5 0.4 0.3 0.2 0.07 0.08 0.4 0.1 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT480-1 Fig. 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 03-02-18 19-12-11 MO-153 Package outline SOT480-1 (TVSOP48) 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 10 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC_LVCH16244A v.16 20210921 Product data sheet - Modifications: • • Type numbers 74LVC16244ADL and 74LVCH16244ADL (SOT370-1/SSOP48) removed. Section 1 and Section 2 updated. 74LVC_LVCH16244A v.15 20190215 Modifications: • • • 74LVC_LVCH16244A v.14 20170615 Modifications: • • • 74LVC_LVCH16244A v.15 Product data sheet - 74LVC_LVCH16244A v.14 Type numbers 74LVC16244AEV and 74LVCH16244AEV (SOT702-1) removed. Type numbers 74LVC16244ABX and 74LVCH16244ABX (SOT1134-2) removed. Type numbers 74LVC16244ADGV and 74LVCH16244ADGV (SOT480-1) added. Product data sheet - 74LVC_LVCH16244A v.13 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Fig. 1 updated. 74LVC_LVCH16244A v.13 20140207 Modifications: • 74LVC_LVCH16244A v.12 20120305 Product data sheet - 74LVC_LVCH16244A v.11 74LVC_LVCH16244A v.11 20111027 Product data sheet - 74LVC_LVCH16244A v.10 74LVC_LVCH16244A v.10 20110429 Product data sheet - 74LVC_LVCH16244A v.9 74LVC_LVCH16244A v.9 20100318 Product data sheet - 74LVC_LVCH16244A v.8 74LVC_LVCH16244A v.8 20081117 Product data sheet - 74LVC_LVCH16244A v.7 74LVC_LVCH16244A v.7 20031208 Product specification - 74LVC_LVCH16244A v.6 74LVC_LVCH16244A v.6 20030130 Product specification - 74LVC_LVCH16244A v.5 74LVC_LVCH16244A v.5 20021030 Product specification - 74LVC_H16244A v.4 74LVC_H16244A v.4 19971028 Product specification - 74LVC16244A_ 74LVCH16244A v.3 74LVC16244A_ 74LVCH16244A v.3 19971028 Product specification - 74LVC16244A v.2 74LVC16244A v.2 19970630 Product specification - 74LVC16244A v.1 74LVC16244A v.1 - - - 74LVC_LVCH16244A Product data sheet Product data sheet - 74LVC_LVCH16244A v.12 Table 5: Minimum VCC changed from 2.3 V to 1.65 V (errata). - All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 11 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC_LVCH16244A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 12 / 13 74LVC16244A; 74LVCH16244A Nexperia 16-bit buffer/line driver; 5 V input/output tolerant; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 7 11. Package outline.......................................................... 9 12. Abbreviations............................................................ 11 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 September 2021 74LVC_LVCH16244A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 16 — 21 September 2021 © Nexperia B.V. 2021. All rights reserved 13 / 13
74LVCH16244ABX,518 价格&库存
很抱歉,暂时无法提供与“74LVCH16244ABX,518”相匹配的价格&库存,您可以联系我们找货
