3.15 ±0.02
(80 ±0.5)
.98 ±0.02
(25 ±0.5)
2.81 ±0.01
(71.5 ±0.3)
.25
Ø0.17
(Ø4.3 ±0.2)
STATIC PRESSURE - IN. OF WATER
AC AXIAL FANS
UF80B series
0.16
(4)
Ø2.99
(Ø76)
Operating voltage: 115 or 230 VAC
Construction:
aluminum die cast frame;
UL94V-0 PBT impeller
Bearing option:
ball bearing or sintered bronze
sleeve
Motor:
.05
5
10
15
0.31
(8)
TERMINAL TYPE
Model No.
Rated Freq. Input Rated Locked Speed
Voltage
Power Cur.
Cur.
Air Volume
M³/Min. CFM
Max. Static Sound Weight
Pressure (H2 0) Noise
V
HZ
W
A
A
RPM
MM
INCH
dbA
kg
UF80B12-_ _H
115
60
11
0.12
0.13
3,100
0.68
24
5.5
0.22
35
0.26
shaded pole
Air Flow:
exhaust over struts
UF80B23-_ _H
230
60
14
0.07
0.08
3,100
0.68
24
5.5
0.22
35
0.26
Connection:
terminal or 22 AWG lead wire
UF80B12-_ _L
115
60
11
0.12
0.13
2,400
0.50
18
3.5
0.14
31
0.26
Protection:
impedance
UF80B23-_ _L
230
60
14
0.06
0.07
2,400
0.50
18
3.5
0.14
31
0.26
Options:
dual voltage 115/230VAC,
IP55; IP55 + salt fog
w w w.mechatronic s.com
12.20.18
L
.10
AIR FLOW (CFM)
0.12
(3)
0.35
(8.5)
3.15 x 3.15 x 0.98 inches
H
.15
LEAD WIRE TYPE
(80 x 80 x 25 mm)
.20
E - mail: S ales @ M echatronic s.com
Fa x : 425 -2 2 2- 515 5
Tel: 425 -2 2 2- 5 9 0 0
800-453-4569
Cooling Simplified
很抱歉,暂时无法提供与“UF80B12-BTLR”相匹配的价格&库存,您可以联系我们找货
