UF92A12-BWHR
UF92A12-BWHR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL92X38MM115VACWIRE
UF92A12-BWHR 数据手册
3.62 ±0.02 (92 ±0.5) 1.50 ±0.02 (38 ±0.5) 3.25 ±0.01 (82.5 ±0.3) 0.35 0.16 (4) ø0.17 ±0.01 (ø4.3 ±0.2) ø3.46 (ø88) 11.8 ±0.75 (300 ±20) UL 1007 22AWG H 0.30 STATIC PRESSURE - IN. OF WATER AC AXIAL FANS UF92A series 0.25 0.20 0.15 0.10 0.05 0 10 LEAD WIRE TYPE (92 x 92 x 38 mm) 3.62 x 3.62 x 1.5 inches 0.12 (3) Operating voltage: 115 or 230 VAC 0.33 (8.5) Construction: die cast aluminum frame; UL94V-0 PBT impeller Bearing option: ball bearing Motor: shaded pole Air Flow: exhaust over struts Connection: terminal or 22 AWG lead wire Protection: impedance w w w.mechatronic s.com 12.15.14 Model No. 20 30 40 50 AIR FLOW (CFM) TERMINAL TYPE 0.31 (8) Rated Freq. Input Rated Locked Speed Voltage Power Cur. Cur. Air Volume V HZ W A A RPM MM INCH dbA kg UF92A12-__H 115 60 12 0.16 0.25 3,300 1.3 46 8.1 0.32 38 0.45 UF92A23-__H 230 60 12 0.09 0.13 3,300 1.3 46 8.1 0.32 38 0.45 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 M³/Min. CFM Max. Static Sound Weight Pressure (H2 0) Noise 800-453-4569 Cooling Simplified
UF92A12-BWHR 价格&库存
很抱歉,暂时无法提供与“UF92A12-BWHR”相匹配的价格&库存,您可以联系我们找货
