74HC3GU04GD,125
74HC3GU04GD,125
    NEXPERIA(安世)
    XFDFN8
    IC INVERTER 3CH 3-INP 8XSON
74HC3GU04GD,125 数据手册
74HC3GU04 Triple unbuffered inverter Rev. 6 — 29 January 2019 Product data sheet 1. General description The 74HC3GU04 is a triple unbuffered inverter. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • Wide supply voltage range from 2.0 V to 6.0 V Symmetrical output impedance High noise immunity Low-power dissipation Balanced propagation delays Multiple package options ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description 74HC3GU04DP -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; SOT505-2 8 leads; body width 3 mm; lead length 0.5 mm 74HC3GU04DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm 4. Marking Table 2. Marking Type number Marking code[1] 74HC3GU04DP HU4 74HC3GU04DC HU4 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. Version SOT765-1 74HC3GU04 Nexperia Triple unbuffered inverter 5. Functional diagram 1 1A 1Y 1 1 7 3 1 5 6 1 2 7 3 2A 2Y 5 6 3A 3Y 2 mna720 Fig. 1. mna721 Logic symbol Fig. 2. IEC logic symbol 6. Pinning information 6.1. Pinning 74HC3GU04 1A 1 8 VCC 3Y 2 7 1Y 2A 3 6 3A GND 4 5 2Y 001aak022 Fig. 3. Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 6.2. Pin description Table 3. Pin description Symbol Pin Description 1A, 2A, 3A 1, 3, 6 data input 1Y, 2Y, 3Y 7, 5, 2 data output GND 4 ground (0 V) VCC 8 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input Output nA nY L H H L 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 2 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max Unit VCC supply voltage -0.5 +7.0 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current IO output current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA VO = -0.5 V to (VCC + 0.5 V) [1] - ±25 mA ICC quiescent supply current [1] - 50 mA IGND ground current [1] -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 300 mW Max Unit [1] [2] Conditions Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate Min Typ 2.0 5.0 6.0 V 0 - VCC V 0 - VCC V -40 +25 +125 °C VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Min Max VIH HIGH-level input voltage VCC = 2.0 V 1.7 1.1 - 1.7 - V VCC = 4.5 V 3.6 2.4 - 3.6 - V VCC = 6.0 V 4.8 3.1 - 4.8 - V VCC = 2.0 V - 0.9 0.3 - 0.3 V VCC = 4.5 V - 2.1 0.9 - 0.9 V VCC = 6.0 V - 2.9 1.2 - 1.2 V VIL LOW-level input voltage 74HC3GU04 Product data sheet -40 °C to +85 °C All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 -40 °C to +125 °C © Unit Nexperia B.V. 2019. All rights reserved 3 / 14 74HC3GU04 Nexperia Triple unbuffered inverter Symbol VOH VOL Parameter Conditions HIGH-level output voltage -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.63 5.81 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V VI = VIH or VIL VI = VIH or VIL LOW-level output voltage - 0.16 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±1.0 - ±1.0 μA ICC supply current per input pin; VI = VCC or GND; IO =0A; VCC = 6.0 V - - 10 - 20 μA CI input capacitance - 3.0 - - - pF [1] All typical values are measured at Tamb = 25 °C. 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 5. Symbol Parameter -40 °C to +85 °C tt transition time CPD -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 2.0 V - 13 75 - 90 ns VCC = 4.5 V - 6 15 - 18 ns VCC = 6.0 V - 5 13 - 15 ns VCC = 2.0 V - 18 95 - 125 ns VCC = 4.5 V - 6 19 - 25 ns VCC = 6.0 V - 5 16 - 20 ns - 5 - - - pF propagation delay nA to nY; see Fig. 4 tpd [1] [2] [3] [4] Conditions [2] nY; see Fig. 4 [3] power dissipation VI = GND to VCC capacitance [4] All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. tt is the same as tTLH and tTHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 4 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 11.1. Waveforms and test circuit VI VM nA input VM GND t PHL t PLH VOH 90 % VM VM nY output 10 % VOL t THL t TLH mna722 Measurement points are given in Table 9. Fig. 4. Propagation delay data input (nA) to data output (nY) and transition time output (nY) Table 9. Measurement points Type 74HC3GU04 VI negative pulse Input Output VM VM 0.5 × VCC 0.5 × VCC tW 90 % VM VM 10 % 0V tf tr VI positive pulse 0V tr tf 90 % VM VM 10 % tW VCC VI G DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 10. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 5. Test circuit for measuring switching times Table 10. Test data Type Input 74HC3GU04 74HC3GU04 Product data sheet S1 position Load VI tr, tf CL RL tPHL, tPLH GND to VCC ≤ 6 ns 50 pF 1 kΩ open All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 5 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 11.2. Additional characteristics Rbias = 560 kΩ VCC 0.47 µF input output 100 µF VI (f = 1 kHz) A IO GND mna050 VO is constant. Fig. 6. Test set-up for measuring forward transconductance mnb124 30 gfs (mA/V) 20 10 0 0 2 4 6 VCC (V) 8 Tamb = 25 °C. Fig. 7. Typical forward transconductance as a function of supply voltage 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 6 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 12. Typical transfer characteristics mnb121 150 ICC (µA) VO (V) 120 1.6 90 1.2 60 0.8 30 0.4 0 0 0.4 0.8 1.2 1.6 VI (V) 2 5 I CC (mA) VO (V) 8 4 6 3 4 2 2 1 0 0 VCC = 2.0 V; IO = 0 A. Fig. 8. mnb122 10 2 0 1 2 3 4 VI (V) 5 0 VCC = 4.5 V; IO = 0 A. Typical transfer characteristics VCC = 2.0 V Fig. 9. Typical transfer characteristics VCC = 4.5 V mnb123 20 I CC (mA) 6 VO (V) 16 12 3 8 4 0 0 2 4 VI (V) 6 0 VCC = 6.0 V; IO = 0 A. Fig. 10. Typical transfer characteristics VCC = 6.0 V 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 7 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 13. Application information Some applications for the 74HC3GU04 are: • • Linear amplifier (see Fig. 11) Crystal oscillator (see Fig. 13). All values given are typical values unless otherwise specified. R2 VCC 1 µF R1 U04 ZL mna052 ZL > 10 kΩ. R1 ≥ 3 kΩ. R2 ≤ 1 MΩ. Open loop amplification: AOL = 20 (typical). Voltage amplification: . Vo(p-p) = VCC - 1.5 V centered at 0.5 × VCC. Unity gain bandwidth product is 5 MHz (typical). Input capacitance see Fig. 12. Fig. 11. Linear amplifier application mna054 80 input capacitance (pF) (1) 60 (2) 40 (3) 20 0 0 2 4 6 VI (V) 8 (1) VCC = 2.0 V. (2) VCC = 4.5 V. (3) VCC = 6.0 V. Fig. 12. Typical input capacitance as a function of the input voltage 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 8 / 14 74HC3GU04 Nexperia Triple unbuffered inverter R1 R2 U04 out C1 C2 mna053 Test data is given in Table 11 and Table 12. C1 = 47 pF (typical). C2 = 22 pF (typical). R1 = 1 MΩ to 10 MΩ (typical). R2 optimum value depends on the frequency and required stability against changes in VCC or average minimum ICC. (ICC = 2 mA at VCC = 3.0 V and f = 1 MHz.) Fig. 13. Crystal oscillator application Table 11. External components for resonator (f < 1 MHz) Frequency R1 R2 C1 C2 10 kHz to 15.9 kHz 2.2 MΩ 220 kΩ 56 pF 20 pF 16 kHz to 24.9 kHz 2.2 MΩ 220 kΩ 56 pF 10 pF 25 kHz to 54.9 kHz 2.2 MΩ 100 kΩ 56 pF 10 pF 55 kHz to 129.9 kHz 2.2 MΩ 100 kΩ 47 pF 5 pF 130 kHz to 199.9 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF 200 kHz to 349.9 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF 350 kHz to 600 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF Table 12. Optimum value for R2 Frequency R2 3 kHz 6 kHz 10 kHz 14 kHz > 14 kHz 74HC3GU04 Product data sheet Optimum 2.0 kΩ minimum required ICC 8.0 kΩ minimum influence due to change in VCC 1.0 kΩ minimum required ICC 4.7 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 2.0 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 2.0 kΩ minimum influence by VCC replace R2 by C3 = 35 pF (typical) All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 9 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 14. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Fig. 14. Package outline SOT505-2 (TSSOP8) 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 10 / 14 74HC3GU04 Nexperia Triple unbuffered inverter VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 15. Package outline SOT765-1 (VSSOP8) 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 11 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 15. Abbreviations Table 13. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 16. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC3GU04 v.6 20190129 Product data sheet - 74HC3GU04 v.5 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HC3GU04GD (SOT996-2/XSON8) removed. 74HC3GU04 v.5 20131002 Modifications: • 74HC3GU04 v.4 20100111 Modifications: • 74HC3GU04 v.3 20090511 Product data sheet - 74HC3GU04 v.2 74HC3GU04 v.2 20031126 Product specification - 74HC3GU04 v.1 74HC3GU04 v.1 20030818 Product specification - - 74HC3GU04 Product data sheet Product data sheet - 74HC3GU04 v.4 For type number 74HC3GU04GD XSON8U has changed to XSON8. Product data sheet - 74HC3GU04 v.3 Marking code for 74HC3GU04DP package changed from HU04 to HU4 All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 12 / 14 74HC3GU04 Nexperia Triple unbuffered inverter 17. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC3GU04 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 13 / 14 74HC3GU04 Nexperia Triple unbuffered inverter Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 2 7. Functional description................................................. 2 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................3 10. Static characteristics..................................................3 11. Dynamic characteristics.............................................4 11.1. Waveforms and test circuit........................................ 5 11.2. Additional characteristics........................................... 6 12. Typical transfer characteristics................................. 7 13. Application information............................................. 8 14. Package outline........................................................ 10 15. Abbreviations............................................................ 12 16. Revision history........................................................12 17. Legal information......................................................13 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 29 January 2019 74HC3GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 29 January 2019 © Nexperia B.V. 2019. All rights reserved 14 / 14
74HC3GU04GD,125 价格&库存
很抱歉,暂时无法提供与“74HC3GU04GD,125”相匹配的价格&库存,您可以联系我们找货
