9A0824M4D01
9A0824M4D01
    SANYODENKI
    FAN80X25MM24VDCLOCK
9A0824M4D01 数据手册
80×80×25 mm San Cooler 80 9A type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Sensor Yellow · Mass………………………………………… 90 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 9A0812S401 9A0812H401 9A0812F401 9A0812M401 9A0812L401 12 9A0824G401 9A0824S401 9A0824H401 9A0824F401 9A0824M401 9A0824L401 24 Max. airflow [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] SPL Operating temperature [dB (A)] [˚C] Expected life [h] 0.38 4.56 4500 1.5 53.0 80.3 0.323 40 -20 to +60 30000/60˚C (53000/40˚C) 2.16 1.56 1.32 1.08 0.72 3400 2900 2600 2350 1850 1.2 1.03 0.92 0.83 0.65 42.4 36.4 32.5 29.3 23.0 48 35.3 28.4 22.5 14.7 0.193 0.142 0.114 0.09 0.059 34 29 26 23 20 -20 to +70 40000/60˚C (70000/40˚C) 7 to 13.8 0.18 0.13 0.11 0.09 0.06 12 to 26.4 0.21 5.04 4500 1.5 53.0 80.3 0.323 40 -20 to +60 30000/60˚C (53000/40˚C) 0.1 0.07 0.06 0.05 0.04 2.4 1.68 1.44 1.2 0.96 3400 2900 2600 2350 1850 1.2 1.03 0.92 0.83 0.65 42.4 36.4 32.5 29.3 23.0 48 35.3 28.4 22.5 14.7 0.193 0.142 0.114 0.09 0.059 34 29 26 23 20 -20 to +70 40000/60˚C (70000/40˚C) 6 to 13.2 9A0812G401 6 to 13.8 12 to 27.6 14 to 27.6 Note 1: Sensor and control options are available for selection. Refer to the table on p. 624. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics 9A0812G401 9A0812S401 With pulse sensor Operating voltage range 0.30 0.25 0.20 0.15 0.10 0.05 0 13.2 V 12 V 6V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0 10 20 30 40 50 60 70 (CFM) Airflow 114 (m3/min) CATALOG No. C1111B002 '21.9.IT 0.25 60 0.20 50 0.15 0.10 (inch H2O) (Pa) 70 0.20 Static pressure 0.35 0.30 13.8 V 40 12 V 30 6V 20 0.05 10 0 0 With pulse sensor Operating voltage range (inch H2O) (Pa) 100 90 80 70 60 50 40 30 20 10 0 Static pressure 0.40 9A0812H401 With pulse sensor Operating voltage range (inch H2O) (Pa) Static pressure DC DC Fan 80 mm sq. DC Fan 0.5 0 10 20 1.0 30 Airflow 40 1.5 (m3/min) 50 (CFM) 0.15 50 40 13.8 V 30 12 V 6V 0.10 20 0.05 0 10 0 0.5 0 10 20 1.0 30 Airflow 40 1.5 (m3/min) 50 (CFM) 9A0812M401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 40 0.12 13.8 V 12 V 20 6V 0.06 10 13.8 V 20 12 V 0.06 0.04 6V 10 0.02 0.02 0 0.08 0 0.5 0 10 1.0 20 30 40 0 1.5 (m3/min) 50 0 0.5 10 0 (CFM) Airflow 9A0824G401 9A0824S401 With pulse sensor 0.25 0.20 0.15 0.10 0.05 0 0.30 26.4 V 24 V 12 V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0 (m3/min) 0.25 60 0.20 50 0.15 0.10 27.6 V 40 24 V 30 12 V 20 0.05 10 0 0 0.5 10 20 0.12 Static pressure Static pressure 24 V 12 V 10 40 50 0.08 0 0.5 0 10 1.0 20 30 40 0 1.5 (m3/min) 50 With pulse sensor 27.6 V 30 24 V 12 V 0.10 20 0.05 10 0 0.5 10 20 1.0 30 1.5 (m3/min) 40 50 (CFM) Airflow 9A0824L401 With pulse sensor Operating voltage range 0.10 27.6 V 20 24 V 12 V 10 0 0.5 10 Airflow ■ Dimensions (unit: mm) (m3/min) 40 (CFM) (inch H2O) (Pa) 0 (CFM) 30 40 0 30 0.06 0.04 1.0 20 50 (CFM) 0.02 0.02 0 30 0.15 0 1.5 (m3/min) With pulse sensor 0.10 27.6 V 0.06 0.04 1.0 Operating voltage range 40 20 10 Operating voltage range 0.20 9A0824M401 0.14 0.08 0.5 9A0824H401 (inch H2O) (Pa) 0.10 0 Airflow With pulse sensor 30 7V 0.02 (inch H2O) (Pa) 0 (inch H2O) (Pa) 0.12 10 0 70 10 20 30 40 50 60 70 (CFM) Operating voltage range 0.16 13.8 V 12 V Airflow With pulse sensor Airflow 9A0824F401 0.04 40 (CFM) (inch H2O) (Pa) 100 90 80 70 60 50 40 30 20 10 0 Static pressure Static pressure 0.30 30 20 0.06 0 (m3/min) Operating voltage range (inch H2O) (Pa) 0.35 20 0.08 Airflow Operating voltage range 0.40 1.0 Static pressure 0.04 0.10 0.10 30 0.10 0.08 (inch H2O) (Pa) 30 Static pressure 0.12 Static pressure Static pressure 0.14 With pulse sensor Operating voltage range Static pressure (inch H2O) (Pa) 0.16 9A0812L401 With pulse sensor DC Fan 80 mm sq. 9A0812F401 DC ■ Airflow - Static Pressure Characteristics 20 1.0 30 Airflow (m3/min) 40 (CFM) 0.08 20 0.06 0.04 27.6 V 24 V 10 14 V 0.02 0 0 0.5 0 10 20 1.0 30 (m3/min) 40 (CFM) Airflow (With ribs) 80±0.5 71.5±0.3 4-ø4.3±0.3 Mounting hole 25±0.5 (4) (4) +50 300 0 71.5±0.3 80±0.5 Lead wire AWG24 UL 1007 (10) Rotating direction Airflow direction CATALOG No. C1111B002 '21.9.IT 115 Inlet side, Outlet side 71.5±0.3 4-ø4.5 71.5±0.3 0 ø9 78.5 DC DC Fan 80 mm sq. ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) 78.5 ■ Options Finger guards page: p. 584 Model no.: 109-049E, 109-049H, 109-049C Resin filter kits Model no.: 109-1002G page: p. 592 Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI), 109-1002F30 (30PPI), 109-1002F40 (40PPI) 116 CATALOG No. C1111B002 '21.9.IT Resin finger guards page: p. 591
9A0824M4D01 价格&库存
很抱歉,暂时无法提供与“9A0824M4D01”相匹配的价格&库存,您可以联系我们找货
