F8025H12B1-FHR
F8025H12B1-FHR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL80X25MMTACH12VDC
F8025H12B1-FHR 数据手册
0.98 ±0.02 (25 ±0.5) 3.15 ±0.02 (80 ±0.5) 2.82 ±0.01 (71.5 ±0.3) 0.16 (4) .30 0.16 (4) STATIC PRESSURE - IN. OF WATER DC AXIAL FANS F8025-H series X .25 E H .20 M L .15 S .10 .05 0 4x Ø 0.18 (Ø 4.5) 10 20 30 40 50 60 AIR FLOW (CFM) (80 x 80 x 25 mm) 3.15 x 3.15 x 0.98 inches Construction: UL94V-0 PBT impeller & frame Model No. Bearing option: ball bearing or sleeve Connection: AWG 24, UL1007 lead wires Frame: flanged or ribbed Protection: Options: Current mA 12 V F8025S-H 12/24 24 75 50 Speed RPM 2,000 Air Volume M³/Min. 0.73 CFM 26 Max. Static Pressure (H2 0) MM INCH 1.75 0.07 Sound Noise Weight dbA g 22 82 F8025L-H 12/24 90 60 2,400 0.87 31 2.50 0.10 26 82 F8025M-H 12/24 120 80 2,800 0.99 35 3.00 0.12 29 82 thermal F8025H-H 12/24 145 90 3,200 1.13 40 4.25 0.17 32 82 tachometer output or locked rotor alarm signal; thermistor speed control; encapsulated motor; PWM speed control F8025E-H 12/24 240 140 3,600 1.30 46 5.25 0.21 35 82 F8025X-H 12/24 480 260 4,200 1.50 53 6.50 0.26 39 82 w w w.mechatronic s.com 04.14.15 Rated Voltage E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
F8025H12B1-FHR 价格&库存
很抱歉,暂时无法提供与“F8025H12B1-FHR”相匹配的价格&库存,您可以联系我们找货
