Part Numbering System
NMBTC.COM / 818.341.3355
New Part Numbering System
0 8 0 2 5 S A 1 2 M A A 0 0
1
1. Size
2
3
Part #
Thickness
(mm)
Part #
25
025
10
10
30
030
15
15
35
035
040
25
25
50
050
28
28
52
052
32
32
55
055
38
38
60
060
50
50
80
080
56
56
92
092
76
76
119
119
100
A0
127
127
210
B1
150
150
172
172
6. Speed
Current
5
DC Fan
AC Fan
H
1
J
2
K
3
L
4
M
5
N
6
P
7
Q
8
R
9
S
A
T
Rib
Flange
Terminal
Single
Flange
Special
Rib Type
N/A
A
Coating
B
Potting
C
N/A
E
Coating
F
Potting
G
N/A
N
Coating
P
Potting
Q
N/A
S
Coating
T
Potting
U
N/A
W
Coating
Y
Potting
Z
Flange Type
3
Through Hole
One Side Flange Type
Steel
A
B
B
Steel
Ceramic
C
D
Other Div.
A
Other Div.
Other Div.
B
Other Div.
DC Fan
AC Fan
CL
C
FS
F
Stainless
Stainless
E
F
FB
D
Other Div.
H
Stainless
Ceramic
G
J
EL/WB
E
BG/BM/Motorized
G
Other Div.
H
I
MS
Sleeve
S
M
Rational Sleeve
M
O
HSB Type Sleeve
H
I
PC/PS
P
JL
J
HS
S
KL
K
TS
T
GL/ML/NL/SL
M
Other Div.
W
5. Rating Voltage
DC FAN
AC FAN
PL
P
Rating
Voltage
BT
Q
5V
05
100V
A0
RL
R
6V
06
115V
A1
SB
S
9V
09
200V
B0
FT/JT
T
12V
12
220V
B2
VL
V
24V
24
230V
B3
Other Div.
W
36V
36
240V
B4
48V
48
3X0V
CX
4X0V
DX
5X0V
EX
Part #
Flange
T 4mm
+L/W
N/A
A
Flange
T 6mm
+L/W
Flange
T 6mm
+T Type
Single
Flange
Special
Model
Ball
Bearing
DC Fan
Supporter
Flange
T 4mm
+T Type
Part #
8. Output Signal, Speed Control & Protect Function
Casing
Type
One Side Rib Type
Steel
Part #
Coating
B
Potting
C
N/A
E
Coating
F
Potting
G
N/A
J
Coating
K
Single/
Two Phase
Three-Phase
Output
Signal
Speed
Control
Open
Closed
Open
Closed
Standard
Constant
A
C
E
1
None-SI
Variable
B
D
F
2
Lock
Constant
L
N
G
3
or Life-S
Variable
M
P
H
4
Constant
T
V
J
5
Variable
U
W
K
6
TACHO
Potting
L
N/A
N
Coating
P
Function
Output Signal
Potting
Q
N/A
A
N/A
S
Impedance
Protect
Yes
B
Coating
T
Impedance
Protet - Fuse
N/A
F
Yes
G
Potting
U
N/A
W
Coating
Y
Potting
Z
9. Individual Specifications
Through Hole
A
Series
AC Fan
Part #
Part #
Bearing
Part #
O
Supporter
9
8
Out Ring
Series
DC Fan
Casing
7
4. Bearing
7. Termination & Supporter
Part
6
3. Series
2. Thickness
Size
(mm)
4
Part #
Standard
00
Custom
01-99
Fan Blade
1 Digit
OEM
1 Digit
AC Fan
Thermal
Protection
Thermal
+ Fuse
2 Voltages
2 Voltages
+ Fuse
Part #
PX4
N/A
QX4
RX4
SX4
N/A
U
Yes
V
N/A
W
Yes
Y
很抱歉,暂时无法提供与“08025KA-12M-EA-00”相匹配的价格&库存,您可以联系我们找货
