74AHCT30PW,112
74AHCT30PW,112
    NEXPERIA(安世)
    TSSOP-14_5X4.4MM
    IC GATE NAND 1CH 8-INP 14TSSOP
74AHCT30PW,112 数据手册
74AHC30; 74AHCT30 8-input NAND gate Rev. 5 — 6 May 2020 Product data sheet 1. General description The 74AHC30; 74AHCT30 is a high-speed Si-gate CMOS device and is pin compatible with Lowpower Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7-A. The 74AHC30; 74AHCT30 provides an 8-input NAND function. 2. Features and benefits • • • • • • • Balanced propagation delays All inputs have Schmitt-trigger actions Inputs accept voltages higher than VCC Input levels: • For 74AHC30: CMOS level • For 74AHCT30: TTL level ESD protection: • HBM JESD22-A114E exceeds 2000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101C exceeds 1000 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package 74AHC30D Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; SOT402-1 body width 4.4 mm -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm -40 °C to +125 °C XQFN12 74AHCT30D 74AHC30PW 74AHCT30PW 74AHC30BQ 74AHCT30BQ 74AHC30GU12 SOT762-1 plastic, extremely thin quad flat package; no leads; SOT1174-1 12 terminals; body 1.70 × 2.0 × 0.50 mm 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 4. Marking Table 2. Marking codes Type number Marking 74AHC30D 74AHC30D 74AHCT30D 74AHCT30D 74AHC30PW AHC30 74AHCT30PW AHCT30 74AHC30BQ AHC30 74AHCT30BQ AHT30 74AHC30GU12 A3 [1] [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 1 A 2 B 3 C 4 D 5 E 6 F 11 G 12 H 1 2 3 4 8 Y 8 5 6 11 12 mna488 mna489 Pin numbers are shown for SO14, TSSOP14 and DHVQFN14 packages only Fig. 1. & Logic symbol Pin numbers are shown for SO14, TSSOP14 and DHVQFN14 packages only Fig. 2. IEC logic symbol A B C D Y E mna490 F G H Fig. 3. Logic diagram 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 2 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 6. Pinning information 6.1. Pinning 1 A terminal 1 index area B 2 13 n.c. C 3 12 H D 4 11 G E 5 10 n.c. F 6 9 n.c. GND 7 8 Y 12 H 4 11 G E 5 F 6 GND(1) 13 n.c. 10 n.c. 9 n.c. 001aak237 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND 001aai162 Fig. 4. 3 D 8 14 VCC C Y 1 2 7 A B GND 74AHC30 74AHCT30 14 VCC 74AHC30 74AHCT30 Pin configuration SO14 and TSSOP14 Fig. 5. Pin configuration DHVQFN14 terminal 1 index area A 1 12 VCC 74AHC30 11 n.c. 10 H C 3 9 G D 4 8 Y E 5 7 F GND 6 B 2 aaa-016961 Transparent top view Fig. 6. Pin configuration XQFN12 (SOT1174-1) 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 3 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 6.2. Pin description Table 3. Pin description Symbol Pin Description SO14, TSSOP14 and DHVQFN14 XQFN12 A 1 1 data input B 2 2 data input C 3 3 data input D 4 4 data input E 5 5 data input F 6 7 data input GND 7 6 ground (0 V) Y 8 8 data output n.c. 9 - not connected n.c. 10 - not connected G 11 9 data input H 12 10 data input n.c. 13 11 not connected VCC 14 12 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Output Input A B C D E F G H Y L X X X X X X X H X L X X X X X X H X X L X X X X X H X X X L X X X X H X X X X L X X X H X X X X X L X X H X X X X X X L X H X X X X X X X L H H H H H H H H H L 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 4 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions Min Max Unit supply voltage -0.5 +7.0 V VI input voltage -0.5 +7.0 V IIK input clamping current VI < -0.5 V [1] -20 - mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] -20 +20 mA IO output current VO = -0.5 V to (VCC + 0.5 V) -25 +25 mA ICC supply current - +75 mA IGND ground current -75 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW - 250 mW Tamb = -40 °C to +125 °C SO14, TSSOP14 and DHVQFN14 [2] XQFN12 [1] [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC30 74AHCT30 Unit Min Typ Max Min Typ Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 3.3 V ± 0.3 V - - 100 - - - ns/V VCC = 5.0 V ± 0.5 V - - 20 - - 20 ns/V 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 5 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V 74AHC30 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = -50 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -50 μA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = -50 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = -8.0 mA; VCC = 4.5 V 3.94 - - 3.80 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 μA CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4 - - - - - pF 74AHC_AHCT30 Product data sheet VI = 5.5 V or GND; VCC = 0 V to 5.5 V VI = VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 6 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 74AHCT30 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = -50 μA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.80 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V IO = 8.0 mA - - 0.36 - 0.44 - 0.55 V VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 μA IO = -8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 μA ΔICC additional per input pin; supply current VI = VCC - 2.1 V; other pins at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4 - - - - - pF 74AHC_AHCT30 Product data sheet VI = VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 7 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8. Symbol Parameter Conditions 25 °C -40 °C to +85 °C Min Typ[1] Max -40 °C to +125 °C Unit Min Max Min Max 74AHC30 tpd propagation A, B, C, D, E, F, G, H to Y; see Fig. 7 and Fig. 8 [2] delay VCC = 3.0 V to 3.6 V CL = 15 pF - 5.0 9.5 1.0 11.0 1.0 12.0 ns CL = 50 pF - 6.7 12.0 1.0 14.5 1.0 15.5 ns CL = 15 pF - 3.6 6.5 1.0 7.5 1.0 8.0 ns CL = 50 pF - 4.9 8.0 1.0 9.5 1.0 10.5 ns - 10 - - - - - pF 1.0 7.5 1.0 8.0 ns VCC = 4.5 V to 5.5 V CPD power fi = 1 MHz; dissipation VI = GND to VCC capacitance [3] 74AHCT30; VCC = 4.5 V to 5.5 V tpd propagation A, B, C, D, E, F, G, H to Y; see Fig. 7 and Fig. 8 [2] delay CL = 15 pF 3.3 6.5 CL = 50 pF CPD [1] [2] [3] power fi = 1 MHz; dissipation VI = GND to VCC capacitance [3] - 4.7 8.5 1.0 9.5 1.0 10.5 ns - 12 - - - - - pF Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 8 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 11.1. Waveforms VI A, B, C, D, E, F, G, H input GND VM tPHL tPLH VOH VM Y output mna491 VOL Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Input to output propagation delays Table 9. Measurement points Type Input Output VM VM 74AHC30 0.5 × VCC 0.5 × VCC 74AHCT30 1.5 V 0.5 × VCC VI negative pulse VM tf tr tr VI GND VM 10 % GND positive pulse tW 90 % tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 10. Definitions for test circuit: RT = termination resistance should be equal to the output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Fig. 8. Test circuit for measuring switching times Table 10. Test data Type Load Input Test VI tr, tf CL 74AHC30 VCC ≤ 3.0 ns 15 pF, 50 pF tPLH, tPHL 74AHCT30 3.0 V ≤ 3.0 ns 15 pF, 50 pF tPLH, tPHL 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 9 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 Fig. 9. JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 10 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 10. Package outline SOT402-1 (TSSOP14) 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 11 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 11. Package outline SOT762-1 (DHVQFN14) 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 12 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate XQFN12: plastic, extremely thin quad flat package; no leads; 12 terminals; body 1.70 x 2.00 x 0.50 mm SOT1174-1 X B D terminal 1 index area A E A A1 A3 detail X 5 C C A B C ∅v ∅w b y1 C y 7 e1 1 11 terminal 1 index area e L1 L 0 1 2 mm scale Dimensions Unit(1) max nom min mm A A1 0.5 0.05 A3 b 0.25 0.127 0.20 0.00 0.15 D E e e1 1.8 1.7 1.6 2.1 2.0 1.9 0.4 1.6 L L1 0.55 0.50 0.15 0.45 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT1174-1 --- MO-288 --- sot1174-1_po European projection Issue date 10-04-07 10-04-21 Fig. 12. Package outline SOT1174-1 (XQFN12) 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 13 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 13. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT30 v.5 20200506 Product data sheet - 74AHC_AHCT30 v.4 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Table 5: Derating values for Ptot total power dissipation have been updated. 74AHC_AHCT30 v.4 20150722 Modifications: • 74AHC_AHCT30 v.3 20090626 Modifications: • • • 74AHC_AHCT30 v.2 20080530 Product data sheet - 74AHC_AHCT30 v.1 74AHC_AHCT30 v.1 19991130 Product specification - - 74AHC_AHCT30 Product data sheet Product data sheet - 74AHC_AHCT30 v.3 - 74AHC_AHCT30 v.2 Added type number 74AHC30GU12. Product data sheet Section 3: DHVQFN14 package added. Section 8: derating values added for DHVQFN14 package. Section 12: outline drawing added for DHVQFN14 package. All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 14 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AHC_AHCT30 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 15 / 16 74AHC30; 74AHCT30 Nexperia 8-input NAND gate Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 4 7. Functional description................................................. 4 8. Limiting values............................................................. 5 9. Recommended operating conditions..........................5 10. Static characteristics..................................................6 11. Dynamic characteristics.............................................8 11.1. Waveforms................................................................. 9 12. Package outline........................................................ 10 13. Abbreviations............................................................ 14 14. Revision history........................................................14 15. Legal information......................................................15 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 May 2020 74AHC_AHCT30 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 6 May 2020 © Nexperia B.V. 2020. All rights reserved 16 / 16
74AHCT30PW,112 价格&库存
很抱歉,暂时无法提供与“74AHCT30PW,112”相匹配的价格&库存,您可以联系我们找货
