09225VA (92 X 25L)
Legacy Part No. 3610VL
NMBTC.COM / 818.341.3355
Characteristic Curves
General Specifications
Motor Protection:
Auto Restart/Polarity Protection
.80
Insulation Resistance:
P-Q Curve
(Pa)
In H2O
Speed Curve
200
6000
Q
10M Ω or over with a DC500V Megger
P
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
N
150
4500
M
L
.40
100
.20
50
K
3000
Speed
Static Pressure
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
.60
Ps
Expected Life
Failure Rate: 10%
60°C 40,000 Hours (AA/EA)
K
0.0
1.0
0.0
35
L
M
N
P
Q
3.0
70
105
(m3/min)
CFM
Air Flow
Material
Outline
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
NAME
PLATE
.169
(4 – φ4.3)
4
(φ .13
10
5)
3.25
(82.5)
3.62
(89.0)
3.25
(82.5± 0.3)
3.62
(92.0 ± 0.5)
.98
(25.0± 0.5)
3.25
(82.5)
3.62
(89.0)
3.25
(82.5)
3.62
(89.0)
3
(φ .70
94
.169
(4 – φ4.3)
3.62
(92.0± 0.5)
AIR
3.25
(82.5± 0.3)
0.169
(4−φ4.3± 0.2)
Panel Cut-Outs
inch
Units: (mm)
11.8
min (300)
ROTATION
LOT NO.
3.25
(82.5)
3.62
(89.0)
INLET SIDE
OUTLET SIDE
Specifications
Rated
Voltage
MODEL
Operating Current
Voltage
Input
Speed
Power
Max.
Max. Static
Air Flow
Noise
Mass
Pressure
(V) (V) (A)*1 (W)*1 (min-1)*1
CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
(g)
09225VA-12K-AA-00
3610VL-04W-B20-B00
12
7.0 ~ 13.8
0.18
2.16
3200
54.0
1.53
.20
50
35.5
135
09225VA-12L-AA-00 3610VL-04W-B30-B00
12
7.0 ~ 13.8
0.24
2.88
3600
61.1
1.73
.26
65
38.5
135
09225VA-12M-AA-00 3610VL-04W-B40-B00
12
7.0 ~ 13.8
0.30
3.60
4000
68.1
1.93
.32
80
42.0
135
09225VA-12N-AA-00
3610VL-04W-B50-B00
12
7.0 ~ 13.8
0.40
4.80
4500
77.0
2.18
.39
98
45.0
135
09225VA-12P-AA-00
3610VL-04W-B60-B00
12
7.0 ~ 13.8
0.52
6.24
5000
85.8
2.43
.48
120
48.0
135
09225VA-12Q-AA-00
3610VL-04W-B70-B00
12
7.0 ~ 13.8
0.72
8.64
5600
96.4
2.73
.60
150
51.0
135
09225VA-24K-AA-00
3610VL-05W-B20-B00
24
14.0 ~ 27.6
0.11
2.64
3200
54.0
1.53
.20
50
35.5
135
3610VL-05W-B30-B00
24
14.0 ~ 27.6
0.14
3.36
3600
61.1
1.73
.26
65
38.5
135
09225VA-24M-AA-00 3610VL-05W-B40-B00
24
14.0 ~ 27.6
0.17
4.08
4000
68.1
1.93
.32
80
42.0
135
09225VA-24N-AA-00
3610VL-05W-B50-B00
24
14.0 ~ 27.6
0.22
5.28
4500
77.0
2.18
.39
98
45.0
135
09225VA-24P-AA-00
3610VL-05W-B60-B00
24
14.0 ~ 27.6
0.28
6.72
5000
85.8
2.43
.48
120
48.0
135
09225VA-24Q-AA-00
3610VL-05W-B70-B00
24
14.0 ~ 27.6
0.38
9.12
5600
96.4
2.73
.60
150
51.0
135
09225VA-24L-AA-00
13
LEGACY P/N
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“3610VL-05W-B60-B00”相匹配的价格&库存,您可以联系我们找货
