9G0612S1011
9G0612S1011
    SANYODENKI
    FAN60X38MM12VDCRBLSTACH
9G0612S1011 数据手册
DC Fan 60×60×38 mm San Ace 60 9G type (Ribless model depicted) ■ General Specifications ・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 547. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black Yellow Sensor ・ Mass ……………………………………………… 110 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Rated voltage Operating voltage range Rated current Rated input Model no. [V] 9G0612G101 9G0612S101 9G0624G101 9G0624S101 9G0624H101 9G0648G101 9G0648S101 [V] 12 7.0 to 13.8 24 14.0 to 27.6 48 28 to 55.2 Rated speed Max. airflow Max. static pressure [A] [W] [min-1] [m³/min] [CFM] [Pa] 1.54 1.36 0.85 0.7 0.57 0.35 0.29 18.5 16.3 20.4 16.8 13.68 16.8 13.9 11800 10800 11800 10800 9800 11800 10800 1.84 1.7 1.84 1.7 1.54 1.84 1.7 65 60 65 60 54.4 65 60 435 370 435 370 304.6 435 370 [inchH²O] SPL Operating temperature Expected life [dB (A)] [˚C] [h] 58 56 58 56 54 58 56 -20 to +70 40000/60˚C 1.747 1.486 1.747 1.486 1.223 1.747 1.486 The following sensor and control options are available for selection. Available for all models. Without sensor Differs according to the model. Refer to the table on pp. 567 to 568. Lock sensor PWM control ■ Airflow - Static Pressure Characteristics 9G0612G101 9G0612S101 With pulse sensor Operating voltage range Operating voltage range 12 V 7V 0.4 0.8 1.2 1.6 2.0 2.4 (m3/min) 0 92 20 40 60 Airflow 風量 80 (CFM) 450 1.6 400 1.4 350 1.2 300 1.0 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 (inch H2O) (Pa) 13.8 V Static静圧 pressure 13.8 V 1.8 With pulse sensor Operating voltage range (inch H2O) (Pa) 550 500 450 400 350 300 250 200 150 100 50 0 Static静圧 pressure Static静圧 pressure (inch H2O) (Pa) 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 9G0624G101 With pulse sensor 12 V 7V 0.4 0 0.8 20 1.2 40 Airflow 風量 1.6 60 2.0 (m3/min) 80 (CFM) 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 550 500 450 400 350 300 250 200 150 100 50 0 27.6 V 24 V 14 V 0.4 0.8 1.2 1.6 2.0 2.4 (m3/min) 0 20 40 60 Airflow 風量 80 (CFM) 9G0624H101 With pulse sensor Operating voltage range Operating voltage range 400 1.4 350 1.2 300 1.0 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 27.6 V 1.6 400 24 V 14 V 0.4 0 9G0648S101 0.8 20 1.2 40 Airflow 風量 1.6 2.0 60 1.4 350 Static静圧 pressure 1.6 (inch H2O) (Pa) 1.8 450 Static静圧 pressure Static静圧 pressure 450 27.6 V 1.2 300 1.0 250 0.8 200 24 V 0.6 150 14 V 0.4 100 0.2 50 0 0 (m3/min) 80 (CFM) 0.4 0 With pulse sensor Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 1.8 9G0648G101 With pulse sensor DC Fan 60 mm sq. 9G0624S101 DC ■ Airflow - Static Pressure Characteristics 0.8 1.2 1.6 2.0 (m3/min) 10 20 30 40 50 60 70 (CFM) Airflow 風量 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 550 500 450 400 350 300 250 200 150 100 50 0 55.2 V 48 V 28 V 0.4 0.8 1.2 1.6 2.0 2.4 (m3/min) 0 20 40 60 Airflow 風量 80 (CFM) With pulse sensor Operating voltage range Static静圧 pressure (inch H2O) (Pa) 1.8 450 1.6 400 1.4 350 1.2 300 1.0 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 55.2 V 48 V 28 V 0.4 0 0.8 20 1.2 40 Airflow 風量 1.6 2.0 60 ■ Dimensions (unit: mm) +1 60 0 50±0.3 (m3/min) 80 (CFM) (With ribs) 4-ø4.3±0.3 Mounting 取付用穴 hole 38±0.5 (4) (4) Lead wire リード線 AWG24 UL 1007 +1 60 0 50±0.3 +50 300 0 (10) Rotating direction 回転方向 Airflow direction 風吹出方向 93 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 59 50±0.3 29.7 59 29.7 50±0.3 62 .7 4-ø4.5 ■ Options Finger guards page: p. 532 Model no.: 109-139E, 109-139H Resin filter kits Model no.: 109-1003G page: p. 540 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) 94 Resin finger guards page: p. 539
9G0612S1011 价格&库存
很抱歉,暂时无法提供与“9G0612S1011”相匹配的价格&库存,您可以联系我们找货
