109P0812A202
109P0812A202
    SANYODENKI
    FAN80X32MM12VDC
109P0812A202 数据手册
DC Fan 80×80×32 mm San Ace 80 9P type ■ General Specifications ・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 529. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black or Blue Yellow Sensor ・ Mass ……………………………………………… 150 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Rated voltage Operating voltage range Rated current Rated input Model no. [V] 109P0812A201 109P0812H201 109P0812M201 109P0824A201 109P0824H201 109P0824M201 109P0848H201 12 48 Max. airflow Max. static pressure [A] [W] [min-1] [m³/min] [CFM] [Pa] 6 to 13.2 0.56 0.16 0.07 0.29 0.09 0.04 0.06 6.72 1.92 0.84 6.96 2.16 0.96 2.88 4600 3150 2000 4600 3150 2000 3350 1.52 1.05 0.65 1.52 1.05 0.65 1.1 53.7 37.1 23.0 53.7 37.1 23.0 38.9 91.1 43.1 18.6 91.1 43.1 18.6 50.9 10.2 to 13.8 12 to 26.4 24 Rated speed [V] 20.4 to 27.6 43 to 53 SPL [inchH²O] Operating temperature Expected life [dB (A)] [˚C] [h] 45 33 21 45 33 21 35 -20 to +55 40000 (+55˚C) 40000/60˚C 60000/60˚C 0.366 0.173 0.075 0.366 0.173 0.075 0.204 -20 to +70 -20 to +60 40000/60˚C -20 to +70 60000/60˚C 40000/60˚C Other sensor specifications are available as options. Refer to the index (pp. 544 to 545). ■ Airflow - Static Pressure Characteristics 109P0812H201 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 120 60 Static静圧 pressure 0.4 0.3 0.25 13.2 V 100 Static静圧 pressure 0.5 12 V 80 60 0.2 0.1 0 6V 40 20 0 0.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 風量 Airflow 126 109P0812M201 With pulse sensor (CFM) 0.20 0.15 (inch H2O) (Pa) 0.12 13.8 V 50 12 V 40 10.2 V 30 0.10 0.05 0 With pulse sensor Operating voltage range Static静圧 pressure 109P0812A201 20 30 0.10 0.08 13.8 V 20 12 V 0.06 0.04 10.2 V 10 0.02 10 0 0.5 0 10 20 1.0 30 風量 Airflow 40 1.5 (m3/min) 50 (CFM) 0 0 0.5 0 10 20 Airflow 風量 1.0 30 (m3/min) 40 (CFM) Operating voltage range Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 120 60 Static静圧 pressure 0.4 0.3 0.25 26.4 V 100 Static静圧 pressure 0.5 24 V 80 60 0.2 0.1 0 12 V 40 20 0 0.5 1.0 1.5 風量 Airflow 0.20 0.15 0.05 Operating voltage range 0.12 27.6 V 24 V 40 20.4 V 30 0.10 20 30 0.10 0.08 27.6 V 20 24 V 0.06 0.04 20.4 V 10 0.02 10 0 0.5 0 (CFM) With pulse sensor (inch H2O) (Pa) 50 0 2.0 (m3/min) 0 10 20 30 40 50 60 70 109P0848H201 109P0824M201 With pulse sensor DC Fan 80 mm sq. 109P0824H201 With pulse sensor Static静圧 pressure 109P0824A201 DC ■ Airflow - Static Pressure Characteristics 10 20 1.0 30 風量 Airflow 40 1.5 (m3/min) 50 (CFM) 0 0 0.5 0 10 20 Airflow 風量 1.0 30 (m3/min) 40 (CFM) With pulse sensor Operating voltage range (inch H2O) (Pa) 70 Static静圧 pressure 0.25 60 0.20 50 0.15 40 0.10 0.05 0 53 V 48 V 43 V 30 20 10 0 0.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 Airflow 風量 ■ Dimensions (unit: mm) (CFM) (With ribs) 80±0.5 71.5±0.3 32±0.5 4-ø4.3±0.3 Mounting 取付用穴 hole (4) (4) 71.5±0.3 80±0.5 Lead wire リー ド線 AWG24 UL 1007 +30 300 0 (10) Rotating direction 回転方向 Airflow direction 風吹出方向 127 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side Outlet side 71.5±0.3 4-ø4.5 5 9. 4 ø8 78 71.5±0.3 ø8 78 4-ø4.5 78 71.5±0.3 71.5±0.3 78 ■ Options Finger guards page: p. 513 Model no.: 109-049C, 109-049E, 109-049H Resin filter kits Model no.: 109-1002G page: p. 521 Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI), 109-1002F30 (30PPI), 109-1002F40 (40PPI) 128 Resin finger guards page: p. 520
109P0812A202 价格&库存
很抱歉,暂时无法提供与“109P0812A202”相匹配的价格&库存,您可以联系我们找货
