TS3300
0.6-3VIN, 1.8-3.6VOUT, 3.5µA, High-Efficiency Boost + Output Load Switch
FEATURES
DESCRIPTION
The TS3300 is a 1st-generation power management
product that combines a high-efficiency boost
regulator and an output load switch in one package.
The boost regulator operates from a supply voltage
as low as 0.6V and can deliver at least 75mA at
1.2VBI to 3VBO, an industry first.
Combines Low-power Boost + Output Load
Switch
Boost Regulator
Input Voltage: 0.6V- 3V
Output Voltage: 1.8V- 3.6V
Efficiency: Up to 84%
No-load Input Current: 3.5µA
Delivers >100mA at 1.8VBO from 1.2VBI
Boost Shutdown Control
No External Schottky Diode Required
Anti-Crush Capability
Prevents Input Voltage Collapse when
powered with Weak/High Impedance Power
Sources
Single-Inductor, Discontinuous Conduction
Mode Scheme with Automatic Peak Current
Adjustment
16-Pin, Low-Profile, Thermally-Enhanced
3mm x 3mm TQFN Package
APPLICATIONS
Coin Cell-Powered Portable Equipment
Single Cell Li-ion or Alkaline Powered Equipment
Solar or Mechanical Energy Harvesting
Wireless Microphones
Wireless Remote Sensors
RFID Tags
Blood Glucose Meters
Personal Health-Monitoring Devices
The TS3300 includes an anti-crushTM feature to
prevent the collapse of the input voltage to the boost
regulator when the input is a weak (high impedance)
source. If the input voltage drops below a determined
voltage threshold (settable by a resistor divider), the
boost regulator switching cycles are paused,
effectively limiting the minimum input voltage. AnticrushTM is useful in applications where a buffer
capacitor at the boost’s output can service burst
loads, and the input source exhibits substantial
source impedance (such as an old battery, or at cold
temperatures).
The TS3300 is fully specified over the -40°C to +85°C
temperature range and is available in a low-profile,
thermally-enhanced 16-pin 3x3mm TQFN package
with an exposed back-side paddle. For best
performance, solder the exposed back-side paddle to
PCB ground.
TYPICAL APPLICATION CIRCUIT
Efficiency vs Output Load Current
100
90 1.2VBI to 1.8VBO
EFFICIENCY - %
80
70
60
50
1.2VBI to 3VBO
40
30
L: LPS4018-103ML
0.01
0.1
IBO - mA
10
100
Page 1
© 2014 Silicon Laboratories, Inc. All rights reserved.
TS3300
ABSOLUTE MAXIMUM RATINGS
BI to GND ................................................................. -0.3V to VBO +0.1V
CCP................................................................................ -0.3V to +2.5V
BEN to GND ............................................................... -0.3V to VBI+0.3V
BI FB, BO FB to GND ...............................................-0.3V to VBO+0.3V
SW EN, REG EN, REG FB, REG OUT to GND .... -0.3V to VREGIN+0.3V
BO, REG IN to GND..................................................... -0.3V to +5.75V
LSW to GND ................................................................ -0.3V to +5.75V
Continuous Power Dissipation (TA = +70°C)
16-Pin TQFN (Derate at 17.5mW/°C above +70°C) ..... 1398mW
Operating Temperature Range ................................. -40°C to +85°C
Storage Temperature Range .................................. -65°C to +150°C
Lead Temperature (Soldering, 10s)...................................... +300°C
Electrical and thermal stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These
are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections
of the specifications is not implied. Exposure to any absolute maximum rating conditions for extended periods may affect device reliability and
lifetime.
PACKAGE/ORDERING INFORMATION
ORDER NUMBER
PART
CARRIER QUANTITY
MARKING
TS3300ITQ1633
Tape
& Reel
Tape
& Reel
3000
3300I
TS3300ITQ1633T
Lead-free Program: Silicon Labs supplies only lead-free packaging.
Consult Silicon Labs for products specified with wider operating temperature ranges.
Page 2
TS3300 Rev. 1.0
TS3300
ELECTRICAL CHARACTERISTICS
VBI = 1.2V, VBO = 3V, VBEN = GND, IBO= 20mA, L = 10µH, CBI=CBO = 22µF unless otherwise noted. Values are at TA = -40°C to +85°C unless
otherwise specified. Typical values are at TA=+25°C unless otherwise specified. Please see Note 1.
PARAMETER
Minimum Input Boost
Voltage
Maximum Input Boost
Voltage
Output Boost Voltage
Range
SYMBOL
CONDITIONS
VBI_MIN
IBO = 0mA. TA=25ºC
VBI_MAX
Guaranteed by design
Output Load-Switch
Supply Current
Boost Shutdown Supply
Current
Boost Feedback Voltage
during operation
Anti-Crush Feedback
Voltage
Anti-Crush Feedback
Voltage Hysteresis
Inductor Peak Current
Inductor Valley Current
NMOS
On
Resistance
PMOS
LOAD
SWITCH
Boost Enable Threshold
IQ
IREGIN
ISHUTDOWN
TYP
MAX
UNITS
0.6
0.75
V
3
V
1.8
VBO
@ BO
@ BI
@ BO
@ BI
3.5
0.07
@ BI
10.8
IREGOUT = 0mA, VREG EN = VREGIN
0.4
See Note 2.
No-Load Input Current
MIN
-40°C
很抱歉,暂时无法提供与“TS3300ITQ1633T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+6.145473000+0.74480
- 国内价格 香港价格
- 1+6.820121+0.82656
- 10+6.6561010+0.80669
- 25+6.5311225+0.79154
- 250+6.40165250+0.77585
- 500+6.27347500+0.76031
- 1000+6.145471000+0.74480
