127×127×38 mm
San Ace 127 9P type
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Sensor
Yellow
· Mass………………………………………… 350 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
SPL
Operating temperature
Expected life
[V]
[V]
[A]
[W]
[min-1]
[m3/min]
[CFM]
[Pa]
[inchH2O]
[dB (A)]
[˚C]
[h]
1.3
0.82
0.55
0.41
0.3
0.2
15.6
9.84
13.2
9.84
14.4
9.6
3300
2950
3300
2950
3300
2950
4.2
3.8
4.2
3.8
4.2
3.8
148
134
148
134
148
134
117.6
98
117.6
98
117.6
98
0.472
0.394
0.472
0.394
0.472
0.394
47
45
47
45
47
45
-20 to +60
40000/60˚C
(70000/40˚C)
109P1312S101
109P1312H101
109P1324S101
109P1324H101
109P1348S101
109P1348H101
12
10.2 to 13.8
24
20.4 to 27.6
48
40.8 to 55.2
Max. airflow
Max. static pressure
Note: Sensor and control options are available for selection. Refer to the table on p. 622.
■ Airflow - Static Pressure Characteristics
109P1312S101
109P1312H101
With pulse sensor
13.8 V
0.5
0.4
12 V
100
10.2 V
0.3
0.2
0.4
50
0.1
2
3
4
5
(m3/min)
0 20 40 60 80 100 120 140 160 180 (CFM)
Airflow
192
CATALOG No. C1111B002 '21.9.IT
0.3
0.2
0.1
(inch H2O) (Pa)
120
0.6
100
12 V
80
10.2 V
60
150
27.6 V
0.5
13.8 V
Static pressure
0.5
With pulse sensor
(inch H2O) (Pa)
150
Static pressure
0.6
109P1324S101
With pulse sensor
(inch H2O) (Pa)
Static pressure
DC
DC Fan 127 mm sq.
DC Fan
40
24 V
100
20.4 V
0.3
0.2
50
0.1
50
3
100
Airflow
4
150
5
(m3/min)
200 (CFM)
2
3
4
5
(m3/min)
Airflow
109P1348S101
With pulse sensor
(inch H2O) (Pa)
0.3
0.2
0.1
(inch H2O) (Pa)
100
27.6 V
80
24 V
55.2 V
0.5
20.4 V
60
0.5
150
40
48 V
100
40.8 V
0.3
0.2
0.4
Static pressure
Static pressure
0.4
0.6
50
0.1
50
3
100
Airflow
4
5
150
■ Dimensions (unit: mm)
(m3/min)
2
3
4
5
0.3
0.2
0.1
(m3/min)
200 (CFM)
With pulse sensor
(inch H2O) (Pa)
120
Static pressure
0.5
109P1348H101
With pulse sensor
DC Fan 127 mm sq.
109P1324H101
DC
120
100
55.2 V
48 V
80
40.8 V
60
40
Airflow
2
50
3
100
Airflow
4
150
5
(m3/min)
200 (CFM)
(With ribs)
4-ø4.3±0.3
Mounting hole
(10)
127±0.8
113.3±0.3
+30
300 0
Lead wire
AWG24
UL 1007
(6)
113.3±0.3
127±0.8
(6)
38±0.5
Airflow direction
Rotating direction
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Outlet side
Inlet side
113.3±0.3
113.3±0.3
4-ø4.3
5
123
113.3±0.3
2
ø1
113.3±0.3
7.
4
2
ø1
4-ø4.3
123
■ Options
Finger guards
page: p. 585
Model no.: 109-722, 109-722H, 109-723
193
很抱歉,暂时无法提供与“109P1312H1011”相匹配的价格&库存,您可以联系我们找货
