9LB1412M5D01
9LB1412M5D01
    SANYODENKI
    FAN140X51MM12VDCRBLSLOCK
9LB1412M5D01 数据手册
Long Life Fan 140×140×51 mm San Ace 140L 9LB type Models 9LB1424B501, 9LB1448F501 are not certified. ■ General Specifications ・ Material ………………………………………… Frame: Aluminum, Impeller: Plastic (Flammability: UL 94V-1) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 529. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black or Blue Sensor Yellow ・ Mass ……………………………………………… 610 g ■ Specifications The models listed below have pulse sensors. Model no. Rated voltage Operating voltage range Rated current Rated input [V] 9LB1412S501 9LB1412H501 9LB1412M501 9LB1424S501 9LB1424B501 9LB1424H501 9LB1424M501 9LB1448S501 9LB1448H501 9LB1448F501 9LB1448M501 [V] 12 10.2 to 13.8 24 20.4 to 27.6 48 40.8 to 55.2 Rated speed Max. airflow [A] [W] [min-1] [m³/min] 2.7 1.25 0.46 1.38 0.97 0.6 0.22 0.71 0.27 0.18 0.12 32.4 15.0 5.52 33.12 23.3 14.4 5.28 34.08 12.96 8.6 5.76 4200 3100 2050 4200 3700 3100 2050 4200 3100 2550 2050 8.1 5.9 3.9 8.1 7.1 5.9 3.9 8.1 5.9 4.8 3.9 Max. static pressure [CFM] [Pa] 286.2 208.5 138 286.2 251 208.5 138 286.2 208.5 169 138 240 130 63 240 186 130 63 240 130 91 63 SPL [inchH²O] Operating temperature Expected life [dB (A)] 0.96 0.52 0.25 0.96 0.75 0.52 0.25 0.96 0.52 0.37 0.25 [˚C] [h] 60000/60˚C 57 49 39 57 55 49 39 57 49 44 39 100000/60˚C 60000/60˚C -20 to +70 100000/60˚C 60000/60˚C 100000/60˚C Other sensor specifications are available as options. Refer to the index (p. 556). ■ Airflow - Static Pressure Characteristics 9LB1412S501 9LB1412H501 With pulse sensor Operating voltage range (inch H2O) (Pa) 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 0.8 12 V 10.2 V 1 2 3 4 5 6 7 8 9 10 風量 Airflow 200 0.4 100 13.8 V (m3/min) 0 50 100 150 200 250 300 350 (CFM) 386 (inch H2O) (Pa) (inch H2O) (Pa) 13.8 V With pulse sensor Operating voltage range 0.6 0.4 150 12 V 10.2 V 100 0.2 50 0 0 Static静圧 pressure Static静圧 pressure 1.0 300 Static静圧 pressure 1.2 9LB1412M501 With pulse sensor Operating voltage range 1 2 3 4 5 6 7 8 (m3/min) 0 50 100 150 200 250 風量 Airflow (CFM) 0.3 13.8 V 80 12 V 60 10.2 V 0.2 40 0.1 0 20 0 1 0 2 50 3 100 Airflow 風量 4 150 5 (m3/min) (CFM) ■ Airflow - Static Pressure Characteristics 9LB1424B501 Operating voltage range Operating voltage range 0.8 200 0.6 150 0.4 100 0.2 50 0 0 24 V 20.4 V 1 2 3 4 5 6 7 8 9 10 (m3/min) 0.8 200 0.6 150 0.4 100 0.2 50 0 0 風量 Airflow 80 Static静圧 pressure Static静圧 pressure 27.6 V 24 V 60 20.4 V 40 0 20 0 1 0 9LB1448F501 2 50 3 4 100 Airflow 風量 5 (m3/min) 150 100 0.2 50 0 0 300 1.0 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 20.4 V 1 2 3 4 5 6 7 8 (m3/min) 0 Airflow 風量 9LB1448H501 With pulse sensor 50 100 150 200 250 風量 Airflow (CFM) With pulse sensor Operating voltage range (inch H2O) (Pa) 0.8 55.2 V 200 55.2 V 48 V 40.8 V 1 2 3 4 5 6 7 8 9 10 (m3/min) 0 50 100 150 200 250 300 350 (CFM) 風量 Airflow 0.4 55.2 V 100 Static静圧 pressure Static静圧 pressure 0.4 24 V 0.6 150 0.4 100 0.2 50 0 0 48 V 40.8 V 1 2 3 4 5 6 7 8 (m3/min) 0 50 100 150 200 250 風量 Airflow (CFM) With pulse sensor (inch H2O) (Pa) 48 V 0.3 40.8 V 50 0.1 0 150 Operating voltage range 150 0.5 0.2 0.6 50 100 150 200 250 300 (CFM) 9LB1448M501 With pulse sensor (inch H2O) (Pa) 0.4 1.2 (CFM) Operating voltage range 0.6 (m3/min) (inch H2O) (Pa) 100 0.2 0.1 1 2 3 4 5 6 7 8 Operating voltage range (inch H2O) (Pa) 0.3 20.4 V 9LB1448S501 With pulse sensor Operating voltage range 0.4 200 27.6 V 24 V 0 0 50 100 150 200 250 300 350 (CFM) 9LB1424M501 0.8 27.6 V Static静圧 pressure 250 27.6 V (inch H2O) (Pa) 250 Static静圧 pressure 1.0 1.0 Static 静圧 pressure Static静圧 pressure 300 With pulse sensor Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 1.2 9LB1424H501 With pulse sensor DC With pulse sensor Long Life Fan 140 mm sq. 9LB1424S501 0 1 0 2 50 3 100 4 150 Airflow 風量 5 6 (m3/min) 200 (CFM) 0.3 100 55.2 V 80 48 V 60 40.8 V 0.2 40 0.1 0 20 0 1 0 2 50 3 100 Airflow 風量 4 150 5 (m3/min) (CFM) 387 ■ Dimensions (unit: mm) 8-ø4.3±0.3 Mounting 取付用穴 hole 124.5±0.5 140±0.8 +30 300 0 (10) Lead wire リード線 AWG24 UL 1007 AWG22 UL 1430 (Model no.: 9LB1412S501 only) (型番:9LB1412S501のみ) 124.5±0.5 140±0.8 4±0.2 4±0.2 6±0.4 6±0.4 51±0.8 Rotating direction 回転方向 Airflow direction 風吹出方向 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Outlet side Inlet side 124.5±0.3 ■ Options Model no.: 109-719, 109-719H 388 page: p. 514 124.5±0.3 ø1 124.5±0.3 ø1 138 138 138 138 Finger guards 4-ø4.5 52 4-ø4.5 47 124.5±0.3
9LB1412M5D01 价格&库存
很抱歉,暂时无法提供与“9LB1412M5D01”相匹配的价格&库存,您可以联系我们找货
