FBA08T (80mm Thin)
15
80
3
80
Panaflo
4-ø4.5
FLOW
ROTATION
CUT OUT
78
71.5
ø
ø8 84 I
9 O nle
utl t
et
78
71.5
Inlet/Outlet
4-ø4.7
Features
• Operating Temperature: -10°C — +70°C (65% RH)
• Aerodynamic blade and venturi design
• Storage Temperature: -40°C — +75°C (65% RH)
• Locked rotor protection and auto-start function
• Bearing Type: Hydro Wave
• Lower circuit noise by new IC
• Optional third wire lead signal (Locked rotor alarm sensor)
Basic Data (nominal at room temperature)
14
3
71.5
71.5
Rated
Voltage
(V)
Operating
Voltage
(V)
Rated
Current
(mA)
Rated
Input
(W)
Nominal
Speed
(r/min)
Maximum
Air Flow
FBA08T12L
12
7 — 13.8
79
0.95
2000
0.62
21.9
1.55
15.2
23.0
FBA08T12H
12
7 — 13.8
200
2.40
3100
0.95
33.5
3.20
31.4
34.0
FBA08T24L
24
14 — 27.6
47
1.13
2000
0.62
21.9
1.55
15.2
23.0
FBA08T24H
24
14 — 27.6
110
2.64
3100
0.95
33.5
3.20
31.4
34.0
(m3/min)
(CFM)
Maximum
Air Pressure
(mmH2O)
(Pa)
Noise
(dB-A)
FBA08T (80mm Thin)
3.0
15
1.5
10.2V (20.4V)
7V (14V)
1.0
1.5
50
25
(mmH20)
Lead Wire
All lead wires are 325 mm
in length ± 15 mm.
45
4.5
(m3/min)
(CFM)
Air Flow
FBA08T12H/FBA08T24H
13.8V (27.6V)
(r/min)
(Pa)
6.0
3000
3.0
15
1.5
10.2V (20.4V)
7V (14V)
2000
1000
N
30
P
Air Pressure
12V (24V)
1.0
1.5
50
25
Q
Case Quantity
100 per box
1000
N
0.5
Q
60
Weight
70 grams (2.47 ounces)
2000
Nominal Speed
All dimensions in mm.
Size
80.0 x 80.0 x 15.0
(3.15 x 3.15 x 0.59)
3000
12V (24V)
strip and tin
Housing and Fan Blade:
Plastic (PET, PBT, ABS)
(r/min)
30
13.8V (27.6V)
Nominal Speed
(mmH20)
4.5
10
300
+ (red)
- (black)
45
FBA08T12L/FBA08T24L
P
Air Pressure
Panaflo®
(Pa)
Characteristics
(m3/min)
(CFM)
Air Flow
P— Q
N— Q
Conversion Factors
1 mm H2O = 9.8 PA
1 m3/min = 35.313 CFM
15
很抱歉,暂时无法提供与“FBA08T24L”相匹配的价格&库存,您可以联系我们找货
