FBA06T (60mm Thin)
60
15
50
Panaflo
FLOW
4-ø4
ROTATION
CUT OUT
58
58
50
ø6
5
50
Inlet/Outlet
4-ø4.2
Features
• Operating Temperature: -10°C — +70°C (65% RH)
• Aerodynamic blade and venturi design
• Storage Temperature: -40°C — +75°C (65% RH)
• Locked rotor protection and auto-start function
• Bearing Type: Hydro Wave
• Lower circuit noise by new IC
• Optional third lead wire signal (Locked rotor alarm sensor)
Basic Data (nominal at room temperature)
10
3
50
60
3
Rated
Voltage
(V)
Operating
Voltage
(V)
Rated
Current
(mA)
Rated
Input
(W)
Nominal
Speed
(r/min)
Maximum
Air Flow
FBA06T12L
12
7 — 13.8
88
1.06
3200
0.34
12.0
2.80
27.5
24.0
FBA06T12H
12
7 — 13.8
145
1.74
4200
0.47
16.6
4.75
46.6
32.0
FBA06T24L
24
14 — 27.6
56
1.34
3200
0.34
12.0
2.80
27.5
24.0
FBA06T24H
24
14 — 27.6
83
1.99
4200
0.47
16.6
4.75
46.6
32.0
(m3/min)
(CFM)
Maximum
Air Pressure
(mmH2O)
(Pa)
Noise
(dB-A)
FBA06T (60mm Thin)
3
6
(r/min)
60
FBA06T12L / FBA06T24L
6000
4
12V (24V)
4000
10.2V (20.4V)
0.2
0.4
0.6
N
7V (14V)
(m3/min)
10
300
+ (red)
- (black)
40
P
Air Pressure
13.8V (27.6V)
Nominal Speed
(mmH20)
Panaflo®
(Pa)
Characteristics
Q
(CFM)
Air Flow
(r/min)
6000
Air Pressure
12V (24V)
40
4
10.2V (20.4V)
7V (14V)
0.2
0.4
Q
0.6
Weight
50 grams ( 1.76 ounces)
Case Quantity
100 per box
13.8V (27.6V)
4000
Nominal Speed
6
2000
N
Size
60.0 x 60.0 x 15.0
(2.36 x 2.36 x 0.59)
60
FBA06T12H / FBA06T24H
P
Lead Wire
All lead wires are 325 mm. in
length ± 15 mm. Housing and
Fan Blade: Plastic
(PET, PBT, ABS)
(mmH20)
All dimensions in mm.
(Pa)
strip and tin
(m3/min)
(CFM)
Air Flow
P— Q
N— Q
Conversion Factors
1 mm H2O = 9.8 PA
1 m3/min = 35.313 CFM
13
很抱歉,暂时无法提供与“FBA06T12H”相匹配的价格&库存,您可以联系我们找货
