2020-48
    XMOS
    THERMAL PAD TO-220 .020" SP2000
2020-48 数据手册
TCDG_Cover_09.09.qxp 9/8/2009 1:43 PM Page 3 Thermal Solutions For Surface Mount Power Applications ThermalClad ® S E L E C T I O N G U I D E TCDG_Cover_09.09.qxp 9/8/2009 September 2009 1:43 PM Page 4 Thermal Clad®: U.S. Patent 4,810,563 and others. All statements, technical information and recommendations herein are based on tests we believe to be reliable, and THE FOLLOWING IS MADE IN LIEU OF ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING THE IMPLIED WARRANTIES OF MARKETABILITY AND FITNESS FOR PURPOSE. Sellers' and manufacturers' only obligation shall be to replace such quantity of the product proved to be defective. Before using, user shall determine the suitability of the product for its intended use, and the user assumes all risks and liability whatsoever in connection therewith. NEITHER SELLER NOR MANUFACTURER SHALL BE LIABLE EITHER IN TORT OR IN CONTRACT FOR ANY LOSS OR DAMAGE, DIRECT, INCIDENTAL, OR CONSEQUENTIAL, INCLUDING LOSS OF PROFITS OR REVENUE ARISING OUT OF THE USE OR THE INABILITY TO USE A PRODUCT. No statement, purchase order or recommendations by seller or purchaser not contained herein shall have any force or effect unless in an agreement signed by the officers of the seller and manufacturer. ISO-9001:2000 Certificate Number, QSR-572 Table of Contents Thermal Clad Thermal Clad Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2-3 Thermal Clad Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4 Thermal Clad Reliability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Dielectrics Selecting Dielectric Materials . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6-7 Dielectric Performance Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .8 Summary Of Key Dielectric Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .9 Using Dielectric Materials In Specialty Applications . . . . . . . . . . . . . . . . . . . . . . . .10-11 Design Considerations Selecting The Base Metal Layer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12-13 Selecting A Circuit Layer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .14-15 Electrical Design Considerations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .16-17 Assembly Recommendations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .18-19 Other Bergquist Thermal Products . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .20-21 Appendix . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .22 Thermal Clad Configurations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .23 1 Thermal Clad® Overview Key Benefits Of Thermal Clad Original Power Board Assembly (Actual) The Bergquist Company is the world leader in the development and manufacture of thermally conductive interface materials.Thermal Clad Insulated Metal Substrate (IMS®) was developed by Bergquist as a thermal management solution for today’s higher watt-density surface mount applications where heat issues are a major concern. Thermal Clad substrates minimize thermal impedance and conduct heat more effectively and efficiently than standard printed wiring boards (PWB's). These substrates are more mechanically robust than thick-film ceramics and direct bond copper constructions that are often used in these applications. Thermal Clad is a cost-effective solution which can eliminate components, allow for simplified designs, smaller devices and an overall less complicated production processes. Additional benefits of Thermal Clad include lower operating temperatures, longer component life and increased durability. (66) Thru-hole FETs (15) High profile capacitors (9) High profile bus bars Total Weight 3.4 lbs (1543.6 g) New Power Board Assembly (Actual) Bergquist Thermal Clad substrates are not limited to use with metal base layers. In one example, power conversion applications can enhance their performance by replacing FR-4 with Thermal Clad dielectrics in multi-layer assemblies. In this application, the thickness of the copper circuit layer can be minimized by the high thermal performance of Thermal Clad. For additional information on this topic, refer to the “Specialty Applications” section on pages 10-11 of this guide. (48) FETs (9) Low profile capacitors (5) Low profile bus bars Total Weight 0.82 lbs (370.6 g) ® Thermal Clad is a complete thermal management system, unlike traditional technology which uses heat sinks, clips and other mounting hardware. Thermal Clad enables low-cost production by eliminating the need for costly manual assembly. Thermal Clad Benefits Traditionally, cooling an FR-4 board Cooling with Thermal Clad can required use of a large heat sink, interface eliminate the need for heat sinks, device material and various hardware (brackets, clips, cooling fans and other hardware. screws or clamps); a configuration requiring An automated assembly method will labor intensive manual assembly. reduce long term costs. Conventional methods measured junction temperature 5W=Tj 43ºC 2 Thermal Clad measured junction temperature 5W=Tj 35ºC • RoHS compliant and halogen-free • Lower component operating temperatures • Reduce printed circuit board size • Increase power density • Extend the life of dies • Reduce the number of interconnects • Improve product thermal and mechanical performance • Combine power and control • Improve product durability • Enable better use of surface mount technology • Reduce heat sinks and other mounting hardware, including thermal interface material • Replace fragile ceramic substrates with greater mechanical durability • Bergquist is your one-stop source from raw materials to finished circuit Improve Durability and Performance Reduce Board Size and Replace Hardware Thermal Clad improves durability because designs can be kept simple while components are kept cool. The low thermal impedance of the Thermal Clad dielectric outperforms other insulators for power components, allowing for cooler operation. Thermal Clad greatly reduces board space while replacing other components including heat sinks. It offers the opportunity to eliminate mica and grease or rubber insulators under power devices by using direct solder mount to Thermal Clad. By eliminating this hardware, heat transfer is improved. Thermal Clad keeps assemblies cool by eliminating thermal interfaces and using thermally efficient solder joints. Voltage breakdown and thermal performance improve in potted assemblies using SMD’s and bare die on Thermal Clad. Thermal Clad can also reduce production costs by enabling automated pick-and-place equipment for SMD’s. Interconnects can be eliminated by using etched traces on the Thermal Clad board. In fact, whole sections of PWB’s are often eliminated. It permits the use of surface mount power and passive devices to reduce real estate. With Thermal Clad, many discrete devices can be replaced at the board level. The Anatomy Of A Thermal Clad Board Thermal Clad is a dielectric (ceramic-polymer blend) coated metal base with a bonded copper circuit layer.This unique material offers superior heat transfer to help cool components while eliminating the problems associated with fragile ceramics. Different than others, Bergquist doesn’t use fiberglass, allowing for better thermal performance. Thermal Clad is a three layer system comprised of the following: t Circuit Layer: This is the printed circuit foil with a thickness of 1oz. to 10oz. (35-350µm) in standard Thermal Clad. t Dielectric Layer: This offers electrical isolation with minimum thermal resistance. Glass carriers degrade thermal performance which is why our dielectrics are glass-free. CML is the one exception because of its prepreg form, a glass carrier is needed for handling purposes. The dielectric layer is the key element of Thermal Clad, and bonds the base metal and circuit metal together. The dielectric has U.L. recognition, simplifying agency acceptance of final assemblies. t Base Layer: This is often aluminum, but other metals such as copper may also be used. The most widely used base material thickness is 0.062" (1.57mm) in aluminum, although many thicknesses are available. In some applications, the base layer of metal may not be needed. See “Specialty Applications” on page 11. Bergquist’s manufacturing facility located in Prescott, Wisconsin features state-of-the-art process capabilities. Process manufacturing uses the latest in technology including environmental clean room control, surface finishing, coating and lamination. Circuit Layer Dielectric Layer Base Layer 3 Thermal Clad Applications 4 Power Conversion Heat-Rail And Forming Solid State Relays/Switches Due to the size constraints and watt-density requirements in DC-DC conversion, Thermal Clad has become the favored choice.Thermal Clad is available in a variety of thermal performances, is compatible with mechanical fasteners and is highly reliable. It can be used in almost every form-factor and fabricated in a wide variety of substrate metals, thicknesses and copper foil weights. The use of Thermal Clad in heat-rail applications has increased significantly and is currently used in automotive, audio, motor control and power conversion applications. Thermal Clad offers many advantages including surface mount assembly, attachment capabilities and excellent thermal performance. The dielectric can be selectively removed and the metal can be formed with three-dimensional features making Thermal Clad a versatile substrate. The implementation of Solid State Relays in many control applications calls for thermally efficient, and mechanically robust substrates. Thermal Clad offers both. The material construction allows mounting configurations not reasonably possible with ceramic substrates. New dielectrics meet the high thermal performance expectations and can even out-perform existing ceramic based designs. Motor Drives LEDs Compact high-reliability motor drives built on Thermal Clad have set the benchmark for watt-density. Dielectric choices provide the electrical isolation necessary to meet operating parameters and safety agency test requirements. With the ability to fabricate in a wide variety of form-factors, implementation into either compact or integrated motor drives is realized. The availability of Thermal Clad HT makes high temperature operation possible. In Power LED applications, light output and long life are directly attributable to how well the LED’s are managed thermally. Thermal Clad is an excellent solution for designers. Because T-Clad is a metal based material, it can be configured for special shapes, bends and thicknesses thus allowing the designer to put LED light engines in virtually any application. Mounting Power LED’s on T-Clad assures the lowest possible operating temperatures and maximum brightness, color and life. Want to maximize the lifecycle and color consistency of your LEDs? This LED-specific solutions guide addresses important factors and recommendations for selecting a thermal management solution ideal for your LED design. Thermal Clad Reliability Thermal Clad Long Term Reliability New materials undergo a rigorous 12 to 18 month qualification program prior to being released to the market. In state-of-the-art laboratories and test facilities, Bergquist performs extensive testing on all their thermal materials for electrical integrity. Bergquist utilizes stringent development procedures.The lab facilities at Bergquist are U.L. cer tified and manufacturing facilities are ISO 9001:2000 certified. Extensive qualification testing consists of mechanical property validation, adhesion, temperature cycling, thermal and electrical stress. To validate long term reliability, electrical testing is performed at selected intervals to 2000 hours where final evaluation is completed. To ensure consistent product performance with manufactured materials, we couple the up-front qualification test with regular audits. Audits include physical, electrical and thermal property tests. Typical Qualification Programs Physical Properties Electrical Properties Other Properties Evaluated Peel Adhesion Pull Strength Sequential Aging Breakdown Voltage DC and AC Sequential Aging Insulation Impedance Temp/Hum/Bias 85C/85%RH/100V 2000 hours Permittivity/Dissipation Temp/Hum/Bias 85°C/85%RH/100V 2000 hours Thermal Shock Sand Bath 300°C/1 minute and 200°C/72 hour post Thermal Stress 230°C/10 min. Thermal Stress 230°C/10 min. Thermal Bias Aging 125°C/100V/2000h Thermal Bias Aging 125°C/100V/2000h Thermal Conductivity Thermal Aging 125°C/2000 hours Thermal Aging 125°C/2000 hours Thermal Bias Aging 125°C/480V/2000h Thermal Bias Aging 125°C/480V/2000h Temp Cycling 500 cycles/-40°C-150°C 350 hours Temp Cycling 500 cycles/-40°C-150°C 350 hours Thermal Bias Aging 175°C/100V/2000h Thermal Bias Aging 175°C/100V/2000h Temp/Hum/Bias 85°C/85%RH/100V 2000 hours Temp/Hum/Bias 85°C/85%RH/100V 2000 hours Chemical Soak Loncoterge - 15 min. Alcohol - 15 min. Chemical Soak Loncoterge - 15 min. Alcohol - 15 min. Dynamic Mechanical Analysis (DMA) – Measures the modulus of materials over a range of temperatures. Chamber Ovens – Over 3000 cubic feet (85 cubic meters) of oven capacity is dedicated to long term thermal bias age testing. The ovens take material to temperatures above Tg. At selected intervals, samples are removed and tested to verify material integrity. Ten Cycle Solder Shock Flammability Thermogravimetric Analyzer (TGA) – Measures the stability of our dielectrics at high temperatures, baking the materials at prescribed temperatures and measuring weight loss. 5 Selecting Dielectric Materials Thermal Conductivity The technology of Thermal Clad resides in the dielectric layer. It is the key element for optimizing performance in your application.The dielectric is a proprietary polymer/ceramic blend that gives Thermal Clad its excellent electrical isolation properties and low thermal impedance. Thermal conductivity is relevant to the application’s thermal performance when the thickness of the dielectric material, interfacial resistance and area are taken into consideration. See “Thermal Impedance” section for more information, as this data will be the most relevant to your application. CML Circuit Material Laminate Standardized Methods For Measuring Thermal Conductivity There are several different test methods for determining a material’s thermal conductivity value. Results can be different depending on the method chosen, so it is important to use similar test methods in material comparisons. See chart at right. Standard test methods include ASTM D5470 and ASTM E1461. ASTM D5470 is a steady state method and is referred to as the guarded hot plate. This method provides an analytically derived value and does not use approximations. ASTM E1461 is a transient method referred to as Laser Flash Diffusivity. In E1461, thermal diffusivity is the test output and thermal conductivity is calculated. Non-Standard In-House Test Methods The adjacent chart shows how vastly different thermal conductivity values can be achieved by using “in-house” or non-standard test methods. For example, when the same dielectric is chosen we can derive a completely different and much higher thermal conductivity value by testing a stack-up or laminate with base layer.We can modify the test further by using different materials for the substrate to obtain even higher results. Although thermal conductivity values are still relative to one another so a comparison can be made, these test methods do not give us an accurate depiction of true thermal performance in the application. Included in the chart is a modeled value for thermal conductivity, a respected model for predicting the effective thermal conductivity of anisotropic particulate composites, but not helpful for determining thermal performance in application. We emphasize using standard test methods such as ASTM D5470 and ASTM E1461, which are universally accepted and repeatable. Note: The hot disk method is not a method we use for comparison because typically this method measures the conductivity of the dielectric alone, which neglects thermal interfacial resistance between layers and carrier holding the dielectric. These values must be understood in order to calculate the actual thermal impedance or thermal performance data. See section regarding thermal impedance on page 7. 6 MP Multi-Purpose HPL High Power Lighting HT High Temperature Higher Thermal Performance The polymer is chosen for its electrical isolation properties, ability to resist thermal aging and high bond strengths. The ceramic filler enhances thermal conductivity and maintains high dielectric strength. The result is a layer of isolation which can maintain these properties even at 0.003" (76µm) thickness. See high power lighting applications for thinner dielectric information. This guide will help you select the best dielectric to suit your needs for watt-density, electrical isolation and operating temperature environment. Lower Thermal Performance Dielectric Layer Standardized Test Methods (W/m-K) Part Number ASTM D54701 ASTM E14612 HT-04503 2.2 1.97 HT-07006 2.2 1.97 MP-06503 1.3 1.17 Method Description 1 - ASTM D5470 Guarded Hot Plate 2 - ASTM E1461 Laser Flash Diffusivity Non-Standard Thermal Conductivity Test Methods and Model (W/m-K) Model1 Guarded Hot Plate Laminate2 Guarded Hot Plate Laminate3 HT-04503 9.0 32.2 36.4 67.6 115 HT-07006 9.0 21.5 23.3 46.0 86.5 MP-06503 4.5 14.0 24.0 34.9 102 Part Number Method Description Laser Flash Laser Flash Laminate2 Laminate3 1 - Bruggeman Model 2 - Tested with 0.062" (1.57mm) 5052 aluminum substrate and 2 oz. (70µm) copper foil 3 - Tested with 0.062"(1.57mm) 1100 copper substrate and 2 oz. (70µm) foil Selecting Dielectric Materials Electrical Isolation - Power Applications High Power Lighting Applications Dielectrics are available in thicknesses from 0.003" (76µm) to 0.009" (229µm), depending on your isolation needs. See “Electrical Design Considerations” on pages 16-17 to help determine which thickness is appropriate for your application. HPL is a dielectric specifically formulated for high power lighting LED applications with demanding thermal performance requirements. This thin dielectric at 0.0015" (38µm) has an ability to withstand high temperatures with a glass transition of 185°C and phenomenal thermal performance of 0.30°C/W. For detailed information, call Bergquist Sales or go online. Breakdown Voltage In Oil with 2" (51mm) Probe ASTM D149 MP HT CML HPL 1.7 1.2 0.7 0.2 .002" (51) .004" (102) .006" (152) .008" (203) .010" (254) .012" (305) .000" (0) .002" (51) .004" (102) .006" (152) .008" (203) .010" (254) .012" (305) .014" (357) Dielectric Thickness Inches (µm) Dielectric Thickness Inches (µm) Thermal Impedance Determines Watt Density Thermal impedance is the only measurement that matters in determining the watt density capability of your application because it measures the temperature drop across the stack-up for each watt of heat flow. Lower thermal impedance results in lower junction temperatures.The lower the thermal impedance, the more efficiently heat travels out of the components. .002" (51) .004" (102) .006" (152) .008" (203) .010" (254) .012" (305) .003" (76) .007" (178) .009" (229) .011" (279) Dielectric Thickness Inches (µm) Dielectric Thickness Inches (µm ) TOTAL IMPEDANCE = .005" (127) Sample Thickness + Thermal Conductivity Interfacial Resistance Lower Thermal Impedance = Lower JunctionTemperatures 7 Dielectric Performance Considerations Storage Modulus This chart graphs the stability of the bond strength between the dielectric and the circuit layer during temperature rise. Although bond strength goes down at higher temperatures, it maintains at least 3 lbs/inch (0.53 N/mm) even at 175°C. This chart depicts the storage modulus of the material over a temperature range. All of our dielectrics are robust, but you will want to choose the one that best suits your operating temperature environment. See “Assembly Recommendations” on pages 18-19 for additional information. Coefficient of Thermal Expansion Dielectric Stability Fractional Dimension Change [µm/m°C] Peel Strength ThermoMechanical Analysis (TMA) measures the dimensional stability of materials during temperature changes, monitoring the Coefficient of Thermal Expansion (CTE). Note: In the application, the CTE of the base material is a dominant contributor to thermal mechanical stress. See pages 12-13 for base layer selection. CTE OF IMS BOARDS - The concerns in exceeding Tg in standard FR-4 materials from a mechanical standpoint should be tempered when using Thermal Clad. The ceramic filler in the polymer matrix of Thermal Clad dielectrics results in considerably lower Z-axis expansion than in traditional FR-4 materials, while the low thickness of the dielectric means significantly less strain on plated-through-hole (PTH) connections due to expansion. 8 Permittivity with 3" (76mm) Cu Electrode Measured at 12 Hz after 1000 Hours at 125°C/480V This charts depicts the stability of the dielectric electrical properties over a range of temperatures. The flatter the line, the more stable. Note the stability of our high temperature dielectric, HT to a temperature of 175°C. Operating Thermal Clad Materials Above Tg Above the Tg of the material, mechanical and electrical properties begin to change. Mechanical changes of note are a reduction of peel strength of the copper foil, an increase in the CTE, and decreasing storage modulus.There is a potential benefit of relieving residual stress on the dielectric interfaces, in solder joints and other interconnects due to CTE mismatches by choosing a dielectric with Tg below the operating temperature. The dielectric material above Tg is in its elastomeric state (much lower storage modulus), allowing some of the stresses to relax. Changes in electrical properties must also be considered in operation above Tg, although they are typically only important at frequencies above 1MHz. Effects to consider are changes in the permitivity, dielectric loss and breakdown strength of the material. Important Note: Many Thermal Clad products have U.L. rating up to 45% higher than their glass transition temperature and are used extensively in applications above rated Tg. Summary Of Key Dielectric Characteristics Applications SINGLE LAYER THERMAL PERFORMANCE DIELECTRIC PERFORMANCE OTHER Thickness1 [.000"/µm] Impedance 2 [°C/W] Impedance 3 [°C in2/W] / [°C cm2/W] HT-04503 3/76 0.45 0.05 / 0.32 2.2 6.0 7 150 140/140 HT-07006 6/152 0.70 0.11/ 0.71 2.2 11.0 7 150 140/140 6 / 1.1 MP-06503 3/76 0.65 0.09 / 0.58 1.3 8.5 6 90 130/140 9 / 1.6 0.16 / 1.03 2.2 20.0 7 150 150/150 6 / 1.1 Part Number Conductivity 4 [W/m-K] Breakdown5 [kVAC] Permittivity6 Glass U.L. [Dielectric Transition7 Index8 Constant] [°C] [°C] Peel Strength9 [lb/in] / [N/mm] 6 / 1.1 MULTI-LAYER HT-09009 9/229 0.90 HT-07006 6/152 0.70 0.11/ 0.71 2.2 11.0 7 150 140/140 6 / 1.1 CML-11006* 6/152 1.10 0.21 / 1.35 1.1 10.0 7 90 130/130 10 / 1.8 0.30 0.02 / 0.13 3.0 2.5 6 185 ** 5 / 0.9 HIGH POWER LIGHTING HPL-03015 Method Description 1.5/38 1 - Optical 2- Internal TO-220 test RD 2018 3 - Calculation from ASTM 5470 4 - Extended ASTM 5470 5 - ASTM D149 6 - ASTM D150 7 - Internal MDSC test RD 2014 8 - U.L. 746 E 9 - ASTM D2861 *CML is available in prepreg form **Pending Note: For applications with an expected voltage over 480 Volts AC, Bergquist recommends a dielectric thickness greater than 0.003" (76µm). Note: Maximum test voltage is a function of material and circuit design.Typical proof test does not represent the maximum. Note: Circuit design is the most important consideration for determining safety agency compliance. Operating Temperatures Thermal Impedance Choose the dielectric that best suits your operating temperature environment. For high temperature applications, such as automotive, HT offers the right solution. All of our dielectrics are U.L. recognized (HPL pending). This drawing represents RD 2018 (at 40W) TO-220 thermal performance (25°C Cold Plate Testing). MATERIAL HT 60 lb Force Temperature of Transistor Base U.L. RTI - ELECTRO / MECHANICAL 140°C / 140°C MP 130°C / 140°C CML 130°C / 130°C TO-220 Greased Interface Circuit Layer (IMS) (TT ºC) Dielectric (IMS) Temperature of IMS Base Metal Base Plate (IMS) Greased Interface (TB ºC) MATERIAL HT* U.L. SOLDER LIMIT RATING 325°C / 60 seconds MP 300°C / 60 seconds CML 260°C / 60 seconds *Covers all soldering options including Eutectic Gold / Tin. 25°C Water In Water Out Water-cooled Heatsink θ ( W) = ºC (TT - TB) 40W 9 Using Thermal Clad Dielectric Material... Two-Layer Systems Using FR-4 Circuits Or Thermal Clad Circuits Bergquist dielectrics are ideal for applications requiring a two-layer solution.Two-layer constructions can provide shielding protection and additional electrical interconnects for higher component density. Bergquist dielectrics will provide superior thermal performance over traditional FR-4 constructions. In addition, thermal vias can maximize thermal capabilities for applications utilizing power components. When vias can not be used, selecting higher performance dielectrics can solve thermal issues independently (see graph, below). Direct Die Application Direct die attach and wirebond are increasingly popular methods of component mounting to Thermal Clad substrates. A key benefit to this structure is lower thermal resistance as compared to conventional surface mount component packages soldered to an IMS substrate. When designing circuits using Chip-On-Board (COB) technology it is important to use the appropriate surface finish to achieve excellent die mounting and wire bond connections. The die attachment is accomplished using SnPb, Pb-free solders, eutectic gold/in solder or an electrical/thermal conductive adhesive, depending on the application requirements to adhere the die to the substrate.The wirebonding performed to make circuit connections is usually either gold or aluminum. ENEPIG (Electroless Nickel/Electroless Palladium/Immersion Gold) is recommended for gold wire and ENIG (Electroless Nickel/ Immersion Gold) for aluminum wire applications. HT dielectrics are U.L. solder rated at 325°C/60 seconds, enabling Eutectic Gold/Tin solders. Close-up view of direct die attachment in an LED application. The Thermal Clad substrate is used to mount the die or module. FR-4 FR-4 HT HT HT The graph depicts the modeled thermal result of various two-layer constructions as a function of device case temperature. The emphasis is the thermal effect of proper vias utilization. DBC Replacement Replace Ceramic Substrates Thermal Clad can replace large-area ceramic substrates. It can also be used as a mechanically durable support for ceramic circuits or directbond copper subassemblies.The copper circuit layer of Thermal Clad has more current carrying capability than thick-film ceramic technology. Thermal Clad has replaced ceramics and DBC in applications due to mechanical robustness and its ability to be fabricated in a wide variety of form-factors. 10 Heavy Copper Applications requiring heavy copper for high current or heat spreading are not limited to single-layer needs. The ability to have internal layers of heavy copper can provide greater application flexibility. Direct access to the internal copper layer to directly attach or mount components provides unique applications capability. Look for opportunities to reduce the copper thickness. In many applications, Bergquist T-Clad thermal performance reduces the need for heavy copper. Bergquist has the ability to laminate heavy copper up to 5 oz. (175µm) on the internal layer utilizing a thicker deposit of HT dielectric. ...In Specialty Applications Ultra Thin Circuits Ultra Thin Circuits (UTC) utilize T-Clad® dielectrics without the typical thick base layer. These circuits are often used for component level packaging where the thick aluminum or copper base is not required for mechanical or thermal mass. The circuit layer is a “stand-alone” ceramic submount replacement where the heat spreading and heat sinking is done in a different location. In addition, UTC can often be used for standard component package mounting. In some cases, the thermal performance and heat dissipation of the UTC is adequate to eliminate the need for heat sinking altogether. The total profile of a UTC can be as thin as 0.009" (0.23mm) and can be built up into multilayer structures.This type of structure is also available with Bond-Ply 450 thermally conductive PSA tape pre-applied to the back. See page 15 for examples of this format. Photographic example of UTC versus a standard 0.062" (1.57mm) aluminum substrate. Active Baseplates Electrical Vias To Baseplate A copper IMS baseplate can be used as an active circuit with the use of blind plated electrical via’s that connects the top circuit layer to the base metal. Copper Foil (Circuit) Bergquist Dielectric Baseplate Copper-Plated Blind Via Selective Dielectric Removal Bergquist has developed a process for selectively removing dielectric to expose the baseplate. This surface can be surface finished like the other circuit pads. We are not limited to geometry or size of the dielectric removal area. Selective removal features can be placed very accurately with respect to the circuits. Pedestal Using a copper base and by selectively removing the dielectric a pedestal can be formed moving the base metal up to be co-planar with adjacent circuits. Electrical vias to baseplate. Dielectric Removal Area Bergquist Dielectric Pedestal Baseplate Pedestal formation through selective dielectric removal. Copper Foil (Circuit) Bergquist Dielectric Dielectric Edge Copper Foil (Circuit) Baseplate Selective dielectric removal. For more detail regarding design and tolerance recommendations for active baseplates, please contact your Bergquist representative for a White Paper. 11 Base Metal Layer Design Considerations t Coefficient Of Thermal Expansion And Heat Spreading t Coefficient Of Thermal Expansion And Solder Joints t Strength, Rigidity And Weight t Electrical t Surface Connections To Base Plate Finish t Costs THERMAL CONDUCTIVITY [W/mK] COEFFICIENT OF THERMAL EXPANSION [ppm/K] DENSITY [g/cc] MODULUS OF RIGIDITY [GPa] YIELD STRENGTH [MPa] Copper 400 17 8.9 44.1 310 Aluminum 5052 150 25 2.7 25.9 215 Aluminum 6061 150 25 2.7 26 230 METAL / ALLOY Coefficient Of Thermal Expansion And Heat Spreading The adjacent graph depicts the CTE of the base material in relationship to the heat spreading capability of the metal. Although Aluminum and Copper are the most popular base layers used in Thermal Clad, other metals and composites have been used in applications where CTE mismatch is a factor. The adjacent table represents standard and non-standard base layers. Coefficient Of Thermal Expansion And Solder Joints Solder joint fatigue can be minimized by selecting the correct base layer to match component expansion. The major concern with thermal expansion is the stress the solder joint experiences in power (or thermal) cycling. Solder joints are not mechanically rigid. Stress induced by heating and cooling may cause the joint to fatigue as it relieves stress. Large devices, extreme temperature differential, badly mismatched materials, or lead-free minimum solder thickness may all place increased cyclic strain on solder joints. Solder joint fatigue is typically first associated with ceramic based components and with device termination. The section on “Assembly Recommendations” (page 18-19) covers these issues in more detail. Extra-Long Circuits Finished circuits up to 25" (635mm) long 12 Base Thickness Surface Finish Copper and aluminum Thermal Clad is normally purchased in one of the standard-gauge thicknesses shown in the table below. Non-standard thicknesses are also available. Aluminum and copper base layers come with a uniform commercial quality brushed surface. Aluminum is also available anodized with choices of clear, black, blue and red colors. Electrical Connections To Base Plate Standard Thermal Clad Panels If a connection to the base plate is desired, copper is the most compatible base layer to use. When using electrical or thermal vias, it is important to match the circuit and base coefficients of thermal TCE expansion as closely as possible. Otherwise, excess plated-hole stress will occur during thermal cycles. Other base layer materials can be used for connection, but will require different connection schemes. Available in: • 18" (457mm) x 24" (610mm) Usable area: 17" (432mm) x 23" (584mm) • 18" (457mm) x 25" (635mm) Usable area: 17" (432mm) x 24" (610mm) • 20" (508mm) x 24" (610mm) Usable area: 19" (483mm) x 23" (584mm) Costs The most cost effective base layers are aluminum and copper because they represent industry standards. Copper is more expensive than aluminum when comparing the like thicknesses, but can be the less expensive option if design considerations allow for a thinner layer. As an example, typically the cost of 0.040" (1.0mm) copper is equal to the cost of 0.125" (3.2mm) aluminum. Aluminum - Thicknesses Inches Millimeters 0.020 0.51 0.032 0.81 0.040 1.02 0.062 1.57 0.080 2.03 0.125 3.18 0.160 4.06 0.190 4.83 Copper - Thicknesses Inches Millimeters 0.020 0.50 0.032 0.81 0.040 1.02 0.060 1.52 0.080 2.03 0.125 3.18 *Standard thicknesses highlighted 13 Selecting A Circuit Layer t Current Carrying Capabilities t Heat Spreading Capabilities t Flatness In Relationship To Thickness Current Carrying Capabilities The circuit layer is the component-mounting layer in Thermal Clad. Current carrying capability is a key consideration because this layer typically serves as a printed circuit, interconnecting the components of the assembly. The advantage of Thermal Clad is that the circuit trace interconnecting components can carry higher currents because of its ability to dissipate heat due to I2R loss in the copper circuitry. 1 oz (35µm) 3 oz (105µm) 6 oz (210µm) 10 oz (350µm) 1" by 0.125" (25mm by 3.2mm) trace on 0.003" (76µm) HT dielectric or 0.006" (152µm) FR-4 dielectric HT 1 oz (35µm) 3 oz (105µm) 6 oz (210µm) 10 oz (350µm) 50 40 1 oz (35µm) 2 oz (70µm) 1" by 0.125" (25mm by 3.2mm) trace on 0.003" (76µm) HT dielectric or 0.006" (152µm) FR-4 dielectric HT 20 1 oz (35µm) 2 oz (70µm) 10 0 10 9 8 7 6 5 4 3 2 1 0 50 100 150 200 250 Temperature rise comparison graph depicts the significant difference between Bergquist Dielectric HT and FR-4. Additional comparison charts regarding all Bergquist Dielectrics are available. Note: No base metal used in calculation. 5 10 15 20 25 Temperature rise comparison graph depicts the significant difference between Bergquist Dielectric HT and FR-4. Additional comparison charts regarding all Bergquist Dielectrics are available. Note: No base metal used in calculation. 14 30 Want a cost effective, optimized circuit design? This Thermal Clad White Paper addresses specific design recommendations including mechanical, circuit, soldermask, fabrication and test options to help optimize your design. Heat Spreading Capability Dielectric thickness and foil thickness both influence heat spreading capability in Thermal Clad. Heat spreading is one of the most powerful advantages derived from IMS. By increasing copper conductor thickness, heat spreading increases and brings junction temperature down. In some cases very heavy copper can be utilized along with bare die to eliminate the need for a standard packaged component. 40 Watt TO-220 soldered to 1" by 1" (25mm x 25mm) Thermal Clad MP Bergquist RD2018 Test Method 1 oz (35µm) circuit foil 3 oz (105µm) circuit foil 6 oz (210µm) circuit foil 10 oz (350µm) circuit foil The following graphs depict both the thermal impedance value and case temperature when relating dielectric and foil thickness. 40 Watt TO-220 soldered to 1" by 1" (25mm x 25mm) Thermal Clad MP Bergquist RD2018 Test Method .002" (51) 1 oz (35µm) circuit foil 3 oz (105µm) circuit foil Thermal Impedance[°C/W] Copper .004" (102) .005" (127) .006" (152) .007" (178) Standard Circuit Layer Thickness MATERIAL .003" (76) .004" (102) Dielectric Thickness Inches (µm ) 6 oz (210µm) circuit foil 10 oz (350µm) circuit foil .002" (51) .003" (76) .005" (127) .006" (152) .007" (178) (Zinc Treatment) Dielectric Thickness Inches (µm) WEIGHT (oz/ft 2) 1 2 3 4 5 6 8 10 REFERENCE THICKNESS inches µm 0.0014 35 0.0028 70 0.0042 105 0.0056 140 0.0070 175 0.0084 210 0.0112 280 0.0140 350 NOTE: Copper foil is NOT measured for thickness as a control method. Instead, it is certified to an area weight requirement per IPC-4562. The nominal thickness given on 1 oz. copper is 0.0014"/35 µm. CAUTION! Values in IPC-4562 (Table 1.1) are not representative of mechanical thickness. Ultra Thin Circuits utilizing Bond-Ply ® 450 PA. See pages 11 and 18 for additional information. 15 Electrical Design Considerations t Proof Testing t Breakdown Voltage t Creepage Distance And Discharge Proof Test The purpose of "Proof Testing" Thermal Clad substrates is to verify that no defects reside in the dielectric material. Because testing requires that voltages be above the onset of partial discharge, we recommend the number of “Proof Tests” be kept at a minimum. The term "Partial Discharge" includes a broad spectrum of life reducing (i.e. material damaging) phenomena such as: 1. 2. 3. 4. Corona discharge Treeing and surface contamination Surface discharges at interfaces, particularly during fault induced voltage reversal Internal discharges in voids or cavities within the dielectric The purpose of the “Proof Test” is to verify that there has been no degradation of the dielectric insulation due to the fabrication process or any material defects. Continued testing at these voltage levels will only take away from the life of the dielectric on the circuit board. It has been repeatedly verified that “Proof Testing” above the inception of partial discharge (700 Vac or 1200 Vac with proper use of soldermask) will detect any and all defects in the dielectric isolation in the Thermal Clad circuit board. Any micro-fractures, delaminations or micro-voids in the dielectric will breakdown or respond as a short during the test. The use of a DC “Proof Test” is recommended, from an operator safety standpoint. The voltage levels typically used are 1500 to 2250 VDC. Due to the capacitive nature of the circuit board construction, it is necessary to control the ramp up of the voltage to avoid nuisance tripping of the failure detect circuits in the tester and to maintain effective control of the test. This is to avoid premature surface arcing or voltage overshoot. There is safety consideration when DC testing, in that the operator must verify the board tested is fully discharged, prior to removing from the test fixture. A more detailed discussion of “Proof Test” is available upon request. Breakdown Voltage “Proof Test” fixture to test multiple number of finished circuit boards at one time. 16 The ASTM definition of dielectric breakdown voltage is: the potential difference at which dielectric failure occurs under prescribed conditions in an electrical insulating material located between two electrodes. This is permanent breakdown and is not recoverable. ASTM goes on to state that the results obtained by this test can seldom be used directly to determine the dielectric behavior of a material in an actual application. This is not a test for “fit for use” in the application, as is the “Proof Test”, which is used for detection of fabrication and material defects to the dielectric insulation. Leakage Current HiPot Testing Creepage Distance And Discharge Due to the variety of dielectric types, thicknesses and board layouts, not all boards test alike. All insulated metal substrates closely resemble a parallel plate capacitor during HiPot testing. Capacitance is equal to: Creepage distance and discharge has to be taken into account because Thermal Clad dielectrics often incorporate a metal base layer. Circuit board designers should consider “Proof Testing” requirements for: conductor-to-conductor and conductor-to-circuit board edge or through holes. The graphs below depict flashover: without soldermask, with soldermask and under oil. C = ∈ A/d where: ∈ = Permittivity (Dielectric Constant) A = Surface Area d = Distance (Dielectric Thickness) Typical Flashover Voltage in Various Media 0.003" (76µm) Dielectric, 25mm circular electrodes The capacitance value changes with different configurations of materials and board layouts. This can be demonstrated where one board fails the test and another passes, but when both are actually tested for dielectric strength and leakage current in a controlled environment, both pass.Therefore, it is very important to properly design the testing and test parameters with the material characteristics in mind.Test set-up and parameters that over-stress or do not consider reactance of the material and its capacitive and resistive components, can lead to false failures and/or test damage of the board. FOR POSITION ONLY Another test characteristic that is generally misunderstood with insulated metal substrates is the leakage and charge current that take place during the test. In most cases, the leakage current value on insulated metal substrates is much smaller than the measurement capability of a typical HiPot tester. What is most misunderstood is the charge current that takes place during the test. Leakage current measurements can only be realized once the board has been brought to the full test voltage (DC voltage) and is held at that voltage during the test. This current value and rate dI/dT is directly related to the capacitance of the board. Therefore, a board that has an effective capacitance higher than another board will have a higher charge current rate than the one with a lower effective capacitance. This does not reflect the leakage current or the voltage withstand of the dielectric insulation instead, it represents the characteristic transient response of the dielectric. Therefore, one is not able to determine comparable leakage current based on the instantaneous charge current. For accurate leakage test data, bring the board up to full DC test voltage and hold. MEASURED CURRENT - CHARGE CURRENT Typical Flashover Voltage in Various Media 0.006" (152µm) Dielectric, 25mm circular electrodes = LEAKAGE CURRENT 17 Assembly Recommendations Solder Assembly Solder joints deserve additional consideration in the design of Thermal Clad assemblies.This section covers solder surface finishes, application and thickness, alloy and flux. Surface Finishes Standard circuit board finishes are available for Thermal Clad circuit boards. • ENIG (Electroless Nickel/Immersion Gold) • OSP (Organic Solderability Protectant) • Immersion silver or tin and lead-free HASL • Standard tin/lead HASL • ENEPIG (Electroless Nickel/Electroless Palladium/Immersion Gold) • Electroless gold Application and Thickness - Solder Paste The typical application technique is metal stencil. Dispensing of solder to specific locations is used for secondary operations or special attachment requirements. No other decision will effect the reliability of the solder joint as much as the thickness of the solder to be used. A minimum of 0.004" (102µm) is recommended (after reflow).This thickness dissipates stress buildup in the joint. Additional information regarding solder joint reliability is offered in the appendix. Note: Additional thickness and/or larger stencil opening may need to be utilized for RoHS compliance applications. Use profile recommended by the component manufacturer. 5 6°C/s max 3°C/s max Ramp-down Ramp-up Stabilization/soak (90-120 s) 3 Now Available T-Clad Bond-Ply 450 PA Wire soldering on Thermal Clad. Standard stars and squares in the most popular LED footprints available through distribution. Contact Bergquist Sales for more information. 18 Thermal Clad with Bond-Ply 450 PA is a thermally conductive adhesive tape that is the first of many pre-applied offerings to come. This material features a release liner on the back side for easy removal and application to a heat sink. T-Clad PA substrate release liners can withstand high temperatures and will maintain adhesion and release characteristics even after exposure to the extreme heat of solder reflow. For a complete data sheet, contact Bergquist Sales. Connection Techniques Connection techniques common throughout the industry are being used successfully on Thermal Clad IMS substrates. Surface mount connectors are manufactured using plastic molding materials with thermal coefficients of expansion that roughly match the characteristics of the baseplate metal. However, the plastic molding compounds do have a different thermal capacity and thermal conductivity that can cause stress in the assembly as it cools after soldering and during any significant temperature excursion. Process-caused thermal mechanical stress is specific to the solder reflow process used. For this reason, designs that capture the metal pin without rigidity are preferred, particularly if the major dimension of the connector is large. Pin Connectors Pin connectors and pin headers are often used in Thermal Clad assembly when an FR-4 panel is attached to a Thermal Clad assembly. The differential coefficient of expansion between the control panel and the base metal will cause stress in the solder joint and dielectric.The most advanced designs incorporate stress relief in the fabrication of the pin. Redundant header pins are often used to achieve high current carrying capacity. Custom Connectors In the example above, the application required a large cable connection to the T-Clad IMS board. Precautions were taken for the best electrical connection with minimized mechanical strain on the etched circuit. This solution addresses both electrical and mechanical fastening. The small holes allow for complete void-free soldering. Also, the insulated shoulder washer prevents shorting to the base plate. These types of connectors are usually custom made and are not commercially available. Wire Bonding – Direct Die Manufacturers such as AutoSplice and Zierick have off the shelf pins ideal for IMS applications. Custom pins and connectors are also available. This Tyco ElectronicsTM SMT thru-board connector provides a way to bring power from the underside of a Thermal Clad IMS board, eliminating issues of dressing wires on the top side of LED boards. Power Connections Wire bonding is par ticularly useful in the design of packages with Chip-On-Board (COB) architecture. This technique uses the surface mount and interconnect capability of Thermal Clad in a highly efficient thermal design. See page 10 for additional information. Close up view of a direct die attachment in a power application. Only a few companies supply spade or threaded fastener connectors for surface mount power connections. In many cases these are lead frame assemblies soldered to the printed circuit pads and bent to accommodate the shell used for encapsulation. Designs incorporating stress relief and a plastic retainer suitable for high amperage are also available. Thru-board connectors will require adherance to fabrication design rules for IMS PWB’s. Edge Connectors When using edge connectors as part of the Thermal Clad printed wiring pattern, it is suggested that interfacing conductors be finished with a hard gold plating over sulfamate nickel plating. A 45° chamfer is recommended when using an edge connector. Remember to maintain the minimum edge to conductor distance to prevent shorting. Flex attachment on Thermal Clad. 19 Solutions For Surface-Mount Applications Hi-Flow® The Hi-Flow family of phase change materials offers an easy-to-apply thermal interface for many surface mount packages. At the phase change temperature, Hi-Flow materials change from a solid and flow with minimal applied pressure.This characteristic optimizes heat transfer by maximizing wet-out of the interface. Hi-Flow is commonly used to replace messy thermal grease. Bergquist phase change materials are specially compounded to prevent pump-out of the interface area, which is often associated with thermal grease.Typical applications for Hi-Flow materials include: • Intel CoreTM Series, Pentium®, PhenomTM, Athlon®, and other high performance CPUs • DC/DC converters • Power modules Hi-Flow materials are manufactured with or without film or foil carriers. Custom shapes and sizes for non-standard applications are also available. Power Device Thermal Clad Hi-Flow High Power Application Hi-Flow with Thermal Clad Heat Spreader Heat Spreader Hi-Flow Processor FR-4 Board High Power Application Hi-Flow without Thermal Clad Sil-Pad® Sil-Pad is the benchmark in thermal interface materials. The Sil-Pad family of materials are thermally conductive and electrically insulating. Available in custom shapes, sheets, and rolls, Sil-Pad materials come in a variety of thicknesses and are frequently used in SMT applications such as: • Interface between thermal vias in a PCB, and a heat sink or casting • Heat sink interface to many surface mount packages Power Device Sil-Pad or Bond-Ply FR-4 Mid Power Application with Bond-Ply or Sil-Pad Intel CoreTM and Pentium® are registered trademarks of Intel Corporation. PhenomTM and Athlon® are registered trademarks of Advanced Micro Devices, Inc. 20 Heat Spreader Where Thermal Solutions Come Together Bond-Ply® and Liqui-Bond® The Bond-Ply family of materials are thermally conductive and electrically isolating. Bond-Ply is available in a pressure sensitive adhesive or laminating format. Liqui-Bond is a high thermal performance liquid silicone adhesive that cures to a solid bonding elastomer. Bond-Ply provides for the mechanical decoupling of bonded materials with mismatched thermal coefficients of expansion.Typical applications include: • Bonding bus bars in a variety of electronic modules and sub assemblies • Attaching a metal-based component to a heat sink • Bonding a heat sink to a variety of ASIC, graphic chip, and CPU packages • Bonding flexible circuits to a rigid heat spreader or thermal plane • Assembly tapes for BGA heat spreader • Attaching PCB assemblies to housings Gap Pad® and Gap Filler The Gap Pad product family offers a line of thermally conductive materials which are highly conformable.Varying degrees of thermal conductivity and compression deflection characteristics are available.Typical applications include: • On top of a semiconductor package such as a QFP or BGA. Often times, several packages with varying heights can use a common heat sink when utilizing Gap Pad. • Between a PCB or substrate and a chassis, frame, or other heat spreader • Areas where heat needs to be transferred to any type of heat spreader • For interfacing pressure sensitive devices • Filling various gaps between heat-generating devices and heat sinks or housings Gap Pads are available in thickness of 0.010" (0.254mm) to 0.250" (6.35mm), and in custom shapes, with or without adhesive. Gap Fillers are available in cartridge or kit form. Gap Pad or Gap Filler Power Device Heat Spreader FR-4 Board Lower Power Application with Gap Pad Top Efficiency In Thermal Materials For Today’s Changing Technology. Contact Bergquist for additional information regarding our Thermal Solutions.We are constantly innovating to offer you the greatest selection of options and flexibility to meet today’s changing technology. 21 Appendix ASTM D 149 Test Methods for Dielectric Breakdown Voltage and Dielectric Strength of Solid Electrical Insulating Materials at Commercial Power Frequencies D 150 Test Methods for AC Loss Characteristics and Permitivity (Dielectric Constant) of Solid Electrical Insulating Materials D 257 Test Methods for DC Conductance or Impedance of Insulating Materials D 374 Test Methods for Thickness of Solid Electrical Insulation D 3165 Test Method for Strength Properties of Adhesives in Shear by Tension Loading of Single-Lap-Joint Laminated Assemblies D 5470 Test Methods for Thermal Transmission Properties of Thin Thermally Conductive Solid Electrical Insulating Materials 60093 Methods of test for volume resistivity and surface resistivity of solid electrical insulating materials 60243-1 Methods of test for electric strength of solid insulating materials Part 1:Tests at power frequencies 60250 Recommended methods for the determination of the permitivity and dielectric dissipation factor of electrical insulating materials at power, audio, and radio frequencies including metre wavelengths 60626-2 Combined flexible materials for electrical insulationPart 2: Methods of test 2221 Generic Standard on Printed Board Design 6012 Qualifications and Performance Specification of Rigid Printed Boards 600 Acceptance of Printed Boards TM-650 Cleanliness (2.3.35 & 2.3.26) TM-650-2.4.22 Bow and Twist TM-650-2.4.8 Peel SM-840C Soldermask Surface Mount ANSI/IPC-SM-782 Surface Mount Land Patterns (configurations and design rules) ISO 4587 Adhesives Determination of tensile lap-shear strength of rigid-to-rigid bonded assemblies IEC IPC 22 Thermal Clad Configurations Custom Circuit Sheet And Roll Format Bergquist Thermal Clad substrates are custom configured to your design parameters at our Prescott,Wisconsin facility. Our field application support personnel in conjunction with our mechanical and process engineers are available to assist you in taking your design from paper to finished product. Engineering is available for the following construction parameters and options. CML (Circuit Material Laminate) is a ceramic filled polymer that forms a strong, thermally conductive bond to metal heat spreaders and is an excellent alternative to pre-preg. • 24" (610mm) Roll Standard (custom sizes are available) • Maximum roll length of 2000' (610m) • Sheets 18"x 24" (457mm x 610mm) and 20" x 24" (508mm x 610mm) • Artwork layout recommendations • Base metal requirements and mechanical configuration • Dielectric thickness • Copper weights (35-350µm / 1-10 oz) • Solder mask layouts • All common circuit finishes • Tooling/singulation options Panel Form Dimensions: • 18" x 24" (457mm x 610mm) 18" x 25" (457mm x 635mm) 20" x 24" (508mm x 610mm) • Foil Thickness: 35-350µm (1-10 oz) Base Plate Metals: • Aluminum 6061-T6, 5052-H34, standards from 0.020" to 0.190" (0.5mm to 4.83mm) • Copper 110 Full-Hard, standard from 0.020" to 0.125" (0.5mm to 3.2mm) U.L. Certifications Directory For information regarding the U.L. recognition status of Bergquist Thermal Clad materials and “Prescott Operations” circuit fabrication, the U.L. website provides the latest information. Using the address: http//www.ul.com select; Online Certifications Directory. Enter one of the following file numbers: U.L. File Number, to the applicable Bergquist file. • In each group there is guide information which will give a further description of the categories listed. • In each group the recognized materials or fabricated circuit board types will be listed. QMTS2.E121882 Polymeric Materials - Filament-wound tubing, Industrial Laminates, Vulcanized Fiber, and Materials for Use in Fabricating Recognized Printed Wiring Boards - Components. ZPMV2.E122713 Wiring, Printed - Component 23 Notes TCDG_Cover_09.09.qxp 9/8/2009 1:42 PM Page 2 DOMESTIC AGENTS For a complete list of Bergquist sales representatives in the U.S. contact The Bergquist Company: 1-800-347-4572. INTERNATIONAL SALES OFFICES CHINA HONG KONG Tel: 86-21-6464-2206 Fax: 86-21-6464-2209 GERMANY Asian Headquarters Tel: 852-2690-9296 Fax: 852-2690-2344 SOUTH KOREA Tel: 82-31-448-0382 Fax: 82-31-448-0383 THE NETHERLANDS Tel: 49-4101-803-230 Fax: 49-4101-803-100 European Headquarters Tel: 31-35-5380684 Fax: 31-35-5380295 INTERNATIONAL AGENTS AUSTRALIA AUSTRIA BELGIUM BRAZIL CANADA CHINA DENMARK FINLAND FRANCE HOLLAND HONG KONG ISRAEL ITALY JAPAN MALAYSIA MEXICO NEW ZEALAND NORWAY Corporate Headquarters and Sales Office: 18930 West 78th Street Chanhassen, MN 55317 PORTUGAL RUSSIA SINGAPORE SPAIN SWEDEN SWITZERLAND TAIWAN THAILAND TURKEY Circuits Manufacturing Facility: 1600 Orrin Road Prescott, WI 54021 Toll Free: (800) 347-4572 • Main: (952) 835-2322 • Fax: (952) 835-0430 • www.bergquistcompany.com Thermal Products • Membrane Switches • Touch Screens TCDG_0909
2020-48 价格&库存
很抱歉,暂时无法提供与“2020-48”相匹配的价格&库存,您可以联系我们找货
