GT20
High Thermal Conductivity
Glassfiber Reinforcement
Features
Smooth surface & low thermal contact resistance
Exceptional thermal performance at lower application pressures (20psi~400psi)
Usable over a wide temperture range
Simplified processing and reduced operating costs
Complies with UL standards
Properties
Property
GT20
Unit
Test Method
Colour
Green
Visual
Reinforcement
Fiberglass
Thickness
0.23
(mm)
Op. Temp. Range
-45 to 180
˚C
Density
2.52
g/cm
2
W/mK
ASTM D5470
Hardness
80
Shore A
ASTM D2240
3
ASTM D792
Breakdown Voltage AC
4000
V
ASTM D149
Breakdown Voltage DC
6000
V
ASTM D149
Dielectric Constant
5.7
1000 Hz
ASTM D150
Thermal Impedance
t=0.23mm
˚C in 2/W
20psi
0.60
psi
ASTM D5470
t=0.23mm
50psi
0.43
psi
ASTM D5470
t=0.23mm
100psi
0.35
psi
ASTM D5470
t=0.23mm
200psi
0.32
psi
ASTM D5470
t=0.23mm
400psi
0.30
psi
ASTM D5470
TML
‹ 0.2 %
ASTM E595
Tensile Strength
200
psi
ASTM D412
Elongation
60
ASTM D412
UL Flammability
V-0
UL 94
Limited Warranty
High Thermal Conductivity Glassfiber Reinforcement is guaranteed against detachment, under normal use, for 5 years from the purchase date.
User shall be solely responsible for determining the suitability of TIM for the intended use, and the user assumes all risks and liabilities whatsoever
in connection there with. Neither seller nor manufacturer shall be liable either in tort or in contract for any loss damage, including loss of profits or
revenue arising out of the use or the inability to use a product.
Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
GT20-320-320-0.23-0 价格&库存
很抱歉,暂时无法提供与“GT20-320-320-0.23-0”相匹配的价格&库存,您可以联系我们找货
