NJM12904
SINGLE SUPPLY DUAL AMPLIFIER
■ PACKAGE OUTLINE
■ GENERAL DESCRIPTION
The NJM12904 is single-supply dual operational amplifier,
which can operate from 2V supply. The features are low
offset voltage, low bias current, and drive TTL or DTL circuit
directly. The package lineup is DIP, DMP and others
compact, which is SON, so that the NJM12904 is suitable
for audio for low voltage operation and any other kind of signal
amplifier.
■ FEATURES
● Operating Voltage
● Input Offset Voltage
● Slew Rate
● Operating Current
● Bipolar Technology
● Package Outline
2
3
(0.7V/µs typ.)
(0.7mA typ.)
DIP8,DMP8,EMP8,
SSOP8,VSP8,SIP8
4
7
B
NJM12904E
NJM12904V
NJM12904R
NJM12904L
(5mV max.)
8
A
NJM12904M
(+2V to +14V)
■ PIN CONFIGURATION
1
NJM12904D
A
B
6
5
NJM12904D/12904M
NJM12904E/12904V/12904R
PIN FUNCTION
1. A OUTPUT
2. A -INPUT
3. A +INPUT
4. GND
5. B +INPUT
6. B -INPUT
7. B OUTPUT
8. V
1 2 3 4 5 6 7 8
NJM12904L
■ EQUIVALENT CIRCUIT (1/2Shown)
V+
- INPUT
+INPUT
OUTPUT
V-
NJM12904
■ ABSOLUTE MAXIMUM RATING
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
V
VID
VIC
Power Dissipation
Operating Temperature Range
Storage Temperature Range
PD
(Ta=25°C)
UNIT
V
V
V
RATINGS
15
14
- 0.3 to +14
(DIP8) 500
(DMP8) 300
(EMP8) 300
(SSOP8) 250
(VSP8) 320
(SIP8) 800
Topr
Tstg
mW
°C
°C
- 40 to +85
- 50 to +125
■ ELECTRICAL CHARACTERISTICS ( V+=5V, Ta=25°C)
PARAMETER
Operating Voltage
Input Offset Current
Input Bias Current
Large Signal Voltage Swing
Maximum Output Voltage Range
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Output Source Current
Output Sink Current
Channel Separation
Operating Current
Slew Rate
Gain Bandwidth Product
SYMBOL
Vopr
VIO
IIO
IB
AV
VOM
VICM
CMR
SVR
ISOURCE
ISINK
CS
ICC
SR
GB
TEST CONDITION
RS=0Ω
RL≥2kΩ
RL=2kΩ
VIN =1V,VIN =0V
VIN =0V,VIN =1V
f=1k to 20kHz
RL=∞
MIN.
2
3.5
0 to 3.5
TYP.
1
5
85
100
40
0.7
0.7
1.5
MAX.
14
5
50
150
1.2
UNIT
V
mV
nA
nA
dB
V
V
dB
dB
mA
mA
dB
mA
V/µs
MHz
NJM12904
■ TYPICAL CHARACTERISTICS
NJM12904 Input Offset Voltage v.s Operating Voltage
NJM12904 Operating Current v.s Operating Voltage
2
3
1.8
2.5
2
Input Offset Voltage Vio (mV)
Operating Current Icc (mA)
1.6
1.4
1.2
1
0.8
0.6
0.4
1.5
1
0.5
-1
-1.5
-2
-2.5
0.2
-3
4
Operating Voltage V+/V- (V)
1.5
6
3.5
5.5
7.5
NJM12904 Maximum Output Voltage Swing
NJM12904 Input Bias Current v.s Operating Voltage
100
6.5
Maximum Output Voltage Swing Vom (V)
90
Input Bias Current Ib (nA)
80
70
60
50
40
30
0.5
-1.5
-3.5
-5.5
-7.5
1.5
2.5
3.5
4.5
5.5
Operating Voltage V+ (V)
6.5
7.5
NJM12904 Input Offset Voltage v.s Input Voltage
3
2.5
2
4.5
1.5
1
0.5
-1
-1.5
-2
-2.5
-3
-1
-0.5
Input Voltage Vin (V)
0.5
1
1
2
3
4
5
6
7
NJM12904
v.s Load Resistance
NJM12904 Maximum Output Voltage Swing v.s Frequency
5
4
4.5
Maximum Output Voltage Swing VOPP (V)
3.5
3
2.5
2
1.5
1
0.5
4
3.5
3
2.5
2
1.5
1
0.5
1000
10000
100000
1
10
Load Resistance RL (Ω)
100
1000
10000
100000
1000000
Frequency f (HZ)
NJM12904 Output Voltage v.s Output Source Current
NJM12904 Output Voltage v.s Output Sink Current
6
5
4.5
4
Output Voltage V+-Vo (V)
Output Voltage Vo (V)
5
4
3
2
1
3.5
3
2.5
2
1.5
1
0.5
0.1
0.1
1
10
Output Sink Current Isink (mA)
100
1
10
Output Source Current Isource(mA)
100
NJM12904
NJM12904 Voltage Gain v.s Operating Voltage
NJM12904 Voltage Gain v.s Frequency
160
140
50
-20
35
-40
30
-60
25
-80
15
-120
10
-140
5
-160
Voltage Gain Av (dB)
120
100
80
RL=2kΩ
60
40
2
3
4
5
6
7
100000
1000000
-180
10000000
NJM12904 Slew Rate(Rise)
V:500mV/div
t::1μs/div
Voltage Vo (mV)
Voltage Vo (mV)
10000
Frequency f (HZ)
NJM12904 Slew Rate(Fall)
Time t (μs)
1000
V:500mV/div
t::1μs/div
Time t (μs)
NJM12904
NJM12904 Operating Current v.s Ambient Temperature
NJM12904 Input Offset Voltage v.s Ambient Temperature
5
1.4
4
3
V+/V-=6V
V+/V-=2.5V
1.2
1
0.8
0.6
V+/V-=1.5V
0.4
2
1
-2
V+/V-=1.5V,2.5V,7V
-3
0.2
-4
-50
-25
50
75
Ambient Temperature Ta (℃)
100
125
-50
-25
50
75
Ambient Teperature Ta (℃)
100
125
NJM12904 Input Bias Current v.s Ambient Temperature
100
8
90
6
Input Bias Current Ib (mA)
80
70
60
50
40
V+/V-=1.5V,2.5V,6V
30
V+/V-=2.5V
V+/V-=2.5V
2
V+/V-=1.5V
-4
-6
10
-25
50
75
100
-8
-50
125
-25
50
75
100
125
NJM12904 Output Source Current v.s Ambient Temperature
100
100
90
90
Output Source Current Isorce (mA)
80
70
60
50
V+=1.5V,2.5V,6V
40
30
80
70
V =1.5V,2.5V,6V
60
50
40
30
50
75
100
125
-50
-25
50
75
100
125
NJM12904
NJM12904 Voltage Gain v.s Ambient Temperature
NJM12904 Common Mode Rejection Ratio
120
Common Mode Rejection Ratio CMR (dB)
120
100
80
V+/V-=2.5V
60
40
-25
50
75
100
125
Supply Voltage Rejection Ratio SVR (dB)
120
100
80
V+/V-=2.5V
60
40
50
75
80
V+/V-=2.5V
60
40
-25
50
75
NJM12904 Supply Voltage Rejection Ratio
100
100
125
100
125
NJM12904
MEMO
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
很抱歉,暂时无法提供与“NJM12904D”相匹配的价格&库存,您可以联系我们找货
