74ALVC245D,112
74ALVC245D,112
    NEXPERIA(安世)
    SOIC20_300MIL
    IC TXRX NON-INVERT 3.6V 20SO
74ALVC245D,112 数据手册
74ALVC245 Octal bus transceiver; 3-state Rev. 3 — 30 April 2021 Product data sheet 1. General description The 74ALVC245 is an octal transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The 74ALVC245 features an output enable input (OE) for easy cascading and send/receive input (DIR) for direction control. OE controls the outputs, so that the buses are effectively isolated. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 1.65 V to 3.6 V Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.5 V) • JESD8B (2.7 V to 3.6 V) 3.6 V tolerant inputs/outputs CMOS low-power consumption Direct interface with TTL levels (2.7 V to 3.6 V) Power-down mode Latch-up performance exceeds 250 mA ESD protection: • HBM JESD22-A114E exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ALVC245D -40 °C to +85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74ALVC245PW -40 °C to +85 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74ALVC245BQ -40 °C to +85 °C DHVQFN20 plastic dual in-line compatible thermal enhanced SOT764-1 very thin quad flat package; no leads; 20 terminals; body 2.5 × 4.5 × 0.85 mm 74ALVC245 Nexperia Octal bus transceiver; 3-state 4. Functional diagram 1 DIR OE 2 A0 B0 3 19 3EN1 3EN2 1 14 A5 13 A6 B6 9 G3 2 B5 8 15 A4 B4 7 1 16 A3 B3 6 17 A2 B2 5 18 A1 B1 4 19 12 A7 B7 11 3 17 4 16 5 15 6 14 7 13 8 12 9 Logic symbol 74ALVC245 Product data sheet 11 mna175 mna174 Fig. 1. 18 2 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 2 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 5. Pinning information 5.1. Pinning 1 DIR 20 VCC 74ALVC245 terminal 1 index area 74ALVC245 2 19 OE A1 3 18 B0 A2 4 17 B1 A3 5 16 B2 DIR 1 20 VCC A4 6 15 B3 A0 2 19 OE A1 3 18 B0 A5 7 14 B4 A2 4 17 B1 A6 8 A3 5 16 B2 A7 9 A4 6 15 B3 A5 7 14 B4 A6 8 13 B5 A7 9 12 B6 GND 10 GND(1) 13 B5 B7 11 GND 10 12 B6 aaa-032610 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 11 B7 aaa-032609 Fig. 3. A0 Pin configuration SOT163-1 (SO20), SOT360-1 (TSSOP20) Fig. 4. Pin configuration SOT764-1 (DHVQFN20) 5.2. Pin description Table 2. Pin description Symbol Pin Description DIR 1 direction control A0, A1, A2, A3, A4, A5, A6, A7 2, 3, 4, 5, 6, 7, 8, 9 data input/output B0, B1, B2, B3, B4, B5, B6, B7 18, 17, 16, 15, 14, 13, 12, 11 data input/output GND 10 ground (0 V) OE 19 output enable input (active LOW) VCC 20 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Input/output OE DIR An Bn L L A=B input L H input B=A H X Z Z 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 3 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +4.6 V -0.5 +4.6 V VCC supply voltage VI input voltage IIK input clamping current VI < 0 V IOK output clamping current VO > VCC or VO < 0 V VO output voltage output HIGH or LOW state [2] -0.5 output 3-state [2] -0.5 +4.6 V -0.5 +4.6 V [1] power-down mode; VCC = 0 V - mA - ±50 mA VCC + 0.5 V IO output current - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW Table 5. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC supply voltage 1.65 3.6 V VI input voltage 0 3.6 V VO output voltage output HIGH or LOW state 0 VCC V output 3-state 0 3.6 V power-down mode; VCC = 0 V 0 3.6 V -40 +85 °C VCC = 1.65 V to 2.7 V - 20 ns/V VCC = 2.7 V to 3.6 V - 10 ns/V [1] [2] VO = 0 V to VCC -50 Tamb = -40 °C to +85 °C The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. 8. Recommended operating conditions Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 4 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage VIL LOW-level input voltage VOH HIGH-level output voltage Conditions -40 °C to +85 °C Min Typ [1] Max 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC - 0.2 - - V IO = 6 mA; VCC = 1.65 V 1.25 - - V IO = 12 mA; VCC = 2.3 V 1.8 - - V IO = 18 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 2.2 - - V IO = 18 mA; VCC = 3.0 V 2.4 - - V IO = 24 mA; VCC = 3.0 V 2.2 - - V IO = -100 μA; VCC = 1.65 V to 3.6 V - - 0.2 V IO = -6 mA; VCC = 1.65 V - - 0.3 V IO = -12 mA; VCC = 2.3 V - - 0.4 V IO = -18 mA; VCC = 2.3 V - - 0.6 V IO = -12 mA; VCC = 2.7 V - - 0.4 V IO = -18 mA; VCC = 3.0 V - - 0.4 V VCC = 1.65 V to 1.95 V LOW-level output voltage 0.35 × VCC V VI = VIH or VIL IO = 100 μA; VCC = 1.65 V to 3.6 V VOL Unit VI = VIH or VIL IO = -24 mA; VCC = 3.0 V - - 0.55 V - ±0.1 ±10.0 μA VI = VCC or GND; VCC = 3.6 V - ±0.1 ±5.0 μA power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - ±0.1 ±10.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 3.6 V - 0.2 10 μA ΔICC additional supply current per input pin; VCC = 3.0 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 5 750 μA CI input capacitance - 3.5 - pF CI/O input/output capacitance - 3.5 - pF IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 3.6 V II input leakage current IOFF [1] [2] [2] All typical values are measured at VCC = 3.3 V and Tamb = 25 °C. For transceivers, the parameter IOZ includes the input leakage current. 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 5 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7. Symbol Parameter tpd propagation delay ten enable time tdis disable time CPD [1] [2] [3] power dissipation capacitance Conditions -40 °C to +85 °C Unit Min Typ [1] Max VCC = 1.65 V to 1.95 V 1.0 2.7 6.0 ns VCC = 2.3 V to 2.7 V 1.0 2.1 3.5 ns VCC = 2.7 V 1.0 3.0 3.6 ns VCC = 3.0 V to 3.6 V 1.0 2.3 3.4 ns VCC = 1.65 V to 1.95 V 1.0 4.0 8.6 ns VCC = 2.3 V to 2.7 V 1.0 3.0 6.0 ns VCC = 2.7 V 1.0 2.6 6.3 ns VCC = 3.0 V to 3.6 V 1.0 2.9 5.5 ns VCC = 1.65 V to 1.95 V 1.0 4.4 8.0 ns VCC = 2.3 V to 2.7 V 1.0 2.3 4.8 ns VCC = 2.7 V 1.0 3.3 5.3 ns VCC = 3.0 V to 3.6 V 1.0 3.2 5.5 ns outputs enabled - 25 - pF outputs disabled - 1 - pF An to Bn; Bn to An; see Fig. 5 OE to An; OE to Bn; see Fig. 6 OE to An; OE to Bn; see Fig. 6 per buffer; VI = GND to VCC; VCC = 3.3 V [2] [2] [2] [3] All typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V and 3.3 V. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 6 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 10.1. Waveforms and test circuit VI An, Bn input VM VM GND tPLH tPHL VOH VM Bn, An output VM VOL mna176 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 5. Propagation delay input (An, Bn) to output (Bn, An) VI OE input VM GND t PLZ t PZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL t PHZ VOH t PZH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled mna367 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Enable and disable times Table 8. Measurement points Supply voltage Input Output VCC VI VM VM VX VY 1.65 V to 1.95 V VCC 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V VCC 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 7 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistor Fig. 7. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 6V GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 6V GND 74ALVC245 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 8 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 11. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 9 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 Fig. 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Package outline SOT360-1 (TSSOP20) 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 10 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm B D SOT764-1 A A A1 E c detail X terminal 1 index area terminal 1 index area e1 C e b 2 9 v w C A B C y1 C y L 1 10 Eh e 20 11 19 12 X Dh 0 2.5 5 mm scale Dimensions (mm are the original dimensions) Unit mm A(1) A1 b max 1.00 0.05 0.30 nom 0.90 0.02 0.25 min 0.80 0.00 0.18 c D(1) Dh E(1) Eh e e1 L v 0.2 4.6 4.5 4.4 3.15 3.00 2.85 2.6 2.5 2.4 1.15 1.00 0.85 0.5 3.5 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT764-1 --- MO-241 --- sot764-1_po European projection Issue date 03-01-27 14-12-12 Fig. 10. Package outline SOT764-1 (DHVQFN20) 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 11 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVC245 v.3 20210430 Product data sheet - Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 2: Reference to JESD36 removed. Section 7: Derating values for Ptot total power dissipation removed (errata). Package outline drawing SOT764-1 (DHVQFN20) updated. 74ALVC245 v.2 20080107 Modifications: • • • • • 74ALVC245 v.1 74ALVC245 Product data sheet 74ALVC245 v.2 Product data sheet 74ALVC245 v.1 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Section 3: DHVQFN20 package added. Section 7: derating values added for DHVQFN20 package. Section 11: outline drawing added for DHVQFN20 package. 20030710 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 - © Nexperia B.V. 2021. All rights reserved 12 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74ALVC245 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 13 / 14 74ALVC245 Nexperia Octal bus transceiver; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 7 11. Package outline.......................................................... 9 12. Abbreviations............................................................ 12 13. Revision history........................................................12 14. Legal information......................................................13 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 April 2021 74ALVC245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 14 / 14
74ALVC245D,112 价格&库存
很抱歉,暂时无法提供与“74ALVC245D,112”相匹配的价格&库存,您可以联系我们找货
