VQ31 Series
Thermal Conductivity Gas Detector Elements
To be read in conjunction with "Introduction to Pellistor Gas
Sensors" and Pellistor Application Note 5 – Thermal
Conductivity Sensors.
BRIDGE CIRCUIT
REFERENCE
ELEMENT
4688B
INTRODUCTION
The VQ31 series devices consist of two matched elements
which are used for the detection of gases in 0 – 100% by
volume concentrations using the recommended bridge circuit
(see below) and the mounting arrangement shown on page 4.
The VQ31M is supplied with braided leads and the VQ31MB has
extended pins for fitting directly to printed circuit boards.
The elements operate on the thermal conductivity principle.
The sensing element is open to the atmosphere under test and
the reference element is supplied sealed in reference air. The
response of the devices is dependent upon the difference
between the thermal conductivity of the atmosphere under
test and the reference air. When the atmosphere under test has
a thermal conductivity higher than the reference air, the sensing
element loses more heat to the surroundings than the reference
element. This increased heat loss causes a cooling of the
sensing element and a subsequent reduction in the resistance
of the sensing element compared to the reference element.
The thermal conductivity of a gas mixture is dependent on
temperature and the individual thermal conductivity of the
constituents of the mixture. The temperature of importance is
the operating temperature of the sensing element (typically a
maximum of 500 8C at the recommended bridge supply
voltage). The sensor can be operated at any bridge voltage up
to and including the recommended bridge supply, with the
sensing element therefore running at temperatures up to and
including the typical maximum. The thermal conductivity of
some of the more common gases relative to air is tabulated on
page 2 at various temperatures. Note that when operating
the sensor in a constant voltage mode the response will
be non-linear to increasing concentrations of a gas.
GENERAL DATA
Electrical
The information given below relates to the
operating in the recommended circuit shown.
Operation (see note 1)
Bridge supply . . . . . . . . . . .
Bridge power consumption:
at 3.5 V . . . . . . . . . . . . .
at 2.0 V . . . . . . . . . . . . .
Typical response to methane in air (see note 2):
Response time . . . . . . . . . . .
2V
27O
SENSING
ELEMENT
OUTPUT
MARKING
Each element is identified by a unique serial number written on
the can of both the sensing and reference elements. The serial
number is written in red on the sensing element and black on
the reference element. In addition, the sensing element carries
a red circular label on the base identifying the device type.
NOTES
1. Operation may be under either direct flow or diffusion
conditions in appropriate mountings (see page 4).
2. With open-circuit conditions at the bridge output.
3. The response time is a function of the type of mounting
used.
ORDERING INFORMATION
Order Code
Description
VQ31
Flexi-leg sensor with open compensator can.
This device needs to have the compensator
mounted in a sealed chamber filled with air or
nitrogen.
VQ31B
PCB legged sensor with open compensator
can. This device needs to have the
compensator mounted in a sealed chamber
filled with air or nitrogen.
VQ31M
Flexi-leg sensor with sealed compensator
can.
VQ31MB
PCB legged sensor with sealed compensator
can.
VQ31 series
. continuous
2.0 to 3.5 V
0.35 W max
0.28
W
2.5
mV/%
1.0
mV/%
. see note 3
Mechanical
Mounting .
Outlines .
Shock test
Vibration test
27O
1 kO
ZERO SET
. . . . . . . . . . see page 4
. . . . . . . . . . see page 3
. . . . 250 g, 5 blows in each plane
20 g, 24 cycles from 100 to 3200 Hz
SGX Sensortech(IS) Ltd Registered in England No.08067077
A1A-VQ31_Ser Issue 6, March 2007
THERMAL CONDUCTIVITY OF GASES (Relative to air)
Element temperature
Air
Nitrogen
Oxygen
Argon
Carbon dioxide
Water vapour
Methane
Ethane
Propane
Carbon monoxide
Ethylene
Acetylene
Hydrogen
Helium
Ammonia
0 8C
100 8C
200 8C
300 8C
400 8C
500 8C
600 8C
1.000
0.996
0.987
0.686
0.621
0.969
1.244
0.742
0.619
0.961
0.703
0.886
7.371
5.972
1.082
1.000
0.993
1.026
0.687
0.745
1.076
1.500
1.027
0.874
0.962
0.970
1.040
6.918
5.681
1.295
1.000
0.997
1.049
0.682
0.832
1.192
1.723
1.271
1.092
0.970
1.195
1.155
6.692
5.492
1.493
1.000
0.999
1.062
0.674
0.893
1.303
1.911
1.474
1.271
0.975
1.378
1.240
6.548
5.338
1.670
1.000
0.998
1.065
0.663
0.933
1.404
2.066
1.638
1.415
0.976
1.524
1.301
6.435
5.197
1.824
1.000
0.994
1.062
0.650
0.959
1.493
2.192
1.769
1.529
0.974
1.637
1.344
6.336
5.062
1.955
1.000
0.988
1.056
0.636
0.975
1.574
2.296
1.874
1.619
0.970
1.727
1.376
6.252
4.939
2.069
TYPICAL BRIDGE OUTPUT FOR METHANE-IN-AIR MIXTURES
300
6590A
3.5 V INPUT
200
OUTPUT VOLTAGE (mV)
100
2 V INPUT
60
80
100
METHANE CONCENTRATION (% VOLUME)
OUTLINE OF VQ31M (All dimensions without limits are nominal)
2311B
F
D
E
1B
C
1G
1A
J O-RING
INSULATOR
METAL
FLANGE
Ref
Millimetres
A
B
C
D
E
F
G
H
J
11.05 + 0.25
6.10 + 0.25
3.56 + 0.13
63.5 min
1.0
8.2 max
9.53
1.5
* sensing element 6.25 + 0.50
reference element 7.75 + 0.38
H
SEE NOTE
Note No bends may be made in this length.
OUTLINE OF VQ31MB (All dimensions without limits are nominal)
7218
F
D
E
1B
C
1A
1G
INSULATOR
METAL
FLANGE
H O-RING
Ref
Millimetres
A
B
C
D
E
F
G
H
11.05 + 0.25
6.10 + 0.25
3.56 + 0.13
40.0 min
1.0
8.2 max
1.5
RECOMMENDED MOUNTING ARRANGEMENTS
4689A
SENSING ELEMENT
EXPOSED TO GAS UNDER TEST
REFERENCE ELEMENT
SEALED OFF FROM GAS UNDER TEST
LEAKPROOF
JOINTS
AA
AB
Ref
Millimetres
AA
AB
AC
AD
AE
9.53 + 0.13
8.33 + 0.13
8.20 min
9.53 + 0.13
8.20 min
1AC
60 MESH STAINLESS
STEEL GAUZE
FLOW RATE 500 cm3/min
AD
1AE
FILTER PAPER AND 60 MESH
STAINLESS STEEL GAUZE
很抱歉,暂时无法提供与“VQ31MB”相匹配的价格&库存,您可以联系我们找货
