VQ22
Combustible Gas Detector Elements
To be read in conjunction with "Introduction to Pellistor Gas
Sensors" and Pellistor Application Notes 1, 2, 3, 4, 6 and 7.
MARKING
Each element is identified by a unique serial number written on
the can of both the detector and compensator. The serial
number is written in red on the detector and black on the
compensator. In addition, the detector carries a red circular
label on the base identifying the device type.
INTRODUCTION
The VQ22 is an improved poison-resistant sensor consisting of
two matched elements which are used for the detection of
combustible gases, particularly methane in air mixtures in
concentrations from 0.1% upwards. There is no interference
from water vapour or carbon dioxide. Using the recommended
bridge circuit below and the mounting arrangement shown on
page 3, the minimum sensitivity is 10 mV/% methane.
The VQ22 has been designed for use in atmospheres where
traces of silicone and other poisoning agents may be present.
NOTES
1. Operation may be under either direct flow or diffusion
conditions in appropriate mountings (see page 3).
2. With open-circuit conditions at the bridge output.
3. The response time is a function of the type of mounting
used.
4. If the VQ22 is exposed to greater than 5% methane
concentration, the calibration of the instrument should be
checked.
5. The elements are supplied as a matched pair with a
trimming resistor R of the correct value which is supplied
where necessary. The trimming resistor is to be connected
across the compensator element as shown below.
6. The resistance to poisoning by silicone compounds is partly
dependent upon the type of housing within which the
elements are mounted.
7. The response to certain of the heavy flammable vapours,
especially aromatic substances with side chains, may be
lower than that calculated from the conversion (K) factors
listed in the preamble.
GENERAL DATA
Electrical
The information given below relates to the VQ22 operating in
the recommended circuit shown.
Operation (see note 1)
. . . . . . . . . continuous
Bridge supply . . . . . . . . . . . 2.0 + 0.1 V
Bridge power consumption . . . . . . . 0.48 W max
Typical average sensor current . . . . . 175
mA
Minimum sensitivity (see note 2) . . . 10 mV/% methane
Linearity . . . . . . . . . linear up to 5% methane
Response time to register 1 1/4% in a 2 1/2%
concentration (see notes 2 and 3) . . . . 2
seconds
Maximum methane concentration
(see note 4) . . . . . . . . . . . 5
Mechanical
Mounting . . . . . . . . . . . . . . see page 3
Outline . . . . . . . . . . . . . . . see page 2
BRIDGE CIRCUIT
COMPENSATOR
(BLACK SLEEVE)
2309C
R
27O
2V
SEE
NOTE 5
1 kO
ZERO SET
27O
DETECTOR
(RED SLEEVE)
OUTPUT
SGX Sensortech(IS) Ltd Registered in England No.08067077
A1A-VQ22 Issue 5, March 2007
TYPICAL RESPONSE OF VQ22 TO 20% L.E.L. OF VARIOUS GASES AND VAPOURS
(RELATIVE TO METHANE) AS THE BRIDGE SUPPLY VOLTAGE IS VARIED
100
5519A
Methane
80
RELATIVE RESPONSE TO METHANE (%)
60
40
Propane
n-Hexane
n-Octane
1.4
2.2
1.8
2.6
3.0
BRIDGE SUPPLY VOLTAGE (V)
OUTLINE (All dimensions without limits are nominal)
2311B
E
1B
Ref
Millimetres
A
B
C
D
E
F
G
H
J
11.05 + 0.25
6.10 + 0.25
3.56 + 0.13
63.50 min
1.02
7.37 + 0.51
8.20 max
9.53
1.52
F
D
C
1G
1A
J O-RING
INSULATOR
METAL
FLANGE
H
SEE NOTE
Note No bends may be made in this length.
RECOMMENDED MOUNTING ARRANGEMENTS
2310C
AA
LEAKPROOF
JOINT
AB
60 MESH STAINLESS
STEEL GAUZE
1AD
Ref
Millimetres
AA
AB
AC
AD
AE
AF
AG
19.05 max
9.53 + 0.13
8.33 + 0.13
8.20 min
19.05 max
9.53 + 0.13
8.20 min
AC
3
FLOW RATE 500 cm /min
AE
AF
FILTER PAPER AND
60 MESH STAINLESS
STEEL GAUZE
1AG
很抱歉,暂时无法提供与“VQ22TB”相匹配的价格&库存,您可以联系我们找货
