IQS263-0-MSR
IQS263-0-MSR
    AZOTEQ
    3 CH. CAPACITVE SENSOR FOR SCROL
IQS263-0-MSR 数据手册
IQ Switch® ProxSense® Series ProxSense® IQS263 Datasheet 3 Channel Capacitive Touch and Proximity Controller with 8-bit Resolution Slider or Scroll Wheel The IQS263 ProxSense® IC is a 3-channel projected (or self) capacitive proximity and touch controller with best in class sensitivity, signal to noise ratio and power consumption. Other features include automatic tuning for sense electrodes, internal reference capacitor and internal regulator to reduce total system cost. Main Features                  3 Self or Mutual Channel Capacitive Controller Configurable 8-bit 2/3 channel slider or 3 channel scroll wheel Up to 80Hz report rate On chip Movement Detection algorithm SAR compliance in mobile devices according to the IEC 62209-2 ed1.0 standard and the FCC standard (KDB 616217 – D04 SAR for laptop and tablets v01) RoHS2 Left and right flick gesture recognition Compliant Automatic adjustment for optimal performance (ATI) User selectable Proximity and Touch thresholds Long proximity range Automatic drift compensation Fast I2C Interface Event mode or Streaming modes IQS263 MSOP10 / DFN 10 Hibernation mode Representations only, not actual markings Low Power, suitable for battery applications Supply voltage: 1.8V to 3.6V 128 (area between E and A) the following calculation needs to be made: Coordinate = (Coordinate - 128)/2 + 128. When applying this calculation, the coordinates will map as shown in Table 7.4. Table 7.4 Wrap around slider or wheel coordinate mapping with MCU adjustment. Positions Coordinates A A to B B B to C C C to D D D to E E E to F F F to A Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 0 1 - 31 32 33 – 63 64 65 – 96 96 97 – 127 128 129 – 159 160 161 – 192 IQS263 Datasheet V1.12 Page 20 of 50 September 2017 IQ Switch® ProxSense® Series 8 ProxSense® Module The IQS263 contains a ProxSense® module that uses patented technology to provide detection of proximity and touch conditions on numerous sensing lines. The ProxSense® module is a combination of hardware and software, based on the principles of charge transfer measurements. 8.1 Charge Transfer Concept On ProxSense® devices like the IQS263, capacitance measurements are taken with a charge transfer process that is periodically initiated. For projected capacitive sensing, the device measures the capacitance between 2 electrodes referred to as the transmitter (CTX) and receiver (CRX). The measuring process is referred to as a charge transfer cycle and consists of the following:  Discharging of an internal sampling capacitor (Cs) and the electrode capacitors (mutual: CTX & CRX) on a channel.  charging of CTX’s connected to the channel  and then a series of charge transfers from the CRX’s to the internal sampling capacitors (Cs), until the trip voltage is reached. The number of charge transfers required to reach the trip voltage on a channel is referred to as the Current Samples (CS) or Count value (Counts). The device continuously repeats charge transfers on the sense electrodes connected to the CRX pins. For each channel a Long Term Average (LTA) is calculated (12 bit unsigned integer values). The count (CS) values (12 bit unsigned Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. integer values) are processed and compared to the LTA to detect Touch and Proximity events. Please note: Attaching scope probes to the CTX/CRX pins will influence the capacitance of the sense electrodes and therefore the related CS values of those channels. This will have an instant effect on the CS measurements. 8.2 Rate of Charge Cycles The IQS263 samples all its active channels (up to 3 + channel 0 for proximity) in 4 timeslots. The charge sequence (as measured on the receive electrodes) is shown in Figure 8.1, where CH0, the Proximity channel, charges first, followed by all other active channels. There is only a communication window after all active channels have been charged. The charging of CH0 comprises the simultaneous charging of the three receive electrodes (CRX0, CRX1 and CRX2) in conjunction with the transmit electrode, thus realising a distributed load mutual capacitive sense electrode. In self-capacitive mode, CH0 is also a distributed channel charging all 3 CX channels together. 8.2.1 Boost Power rate With the IQS263 zoomed to Boost Power (BP) mode, the active channels are charged at a fixed sampling period (tSAMPLE) per channel (if Turbo Mode is not enabled). This is done to ensure regular samples for processing of results, and fix timings for the halt times. It is calculated as each channel having a time tSAMPLE = charge/conversion time (tSENSE) + computation time (tPROCESS) of approximately tSAMPLE = 1.6ms. Thus the time between consecutive samples on a specific channel (Scan Period) will depend on the number of enabled channels and the length of communication between the IQS263 Datasheet V1.12 Page 21 of 50 September 2017 IQ Switch® ProxSense® Series IQS263 and the host MCU. Communication will always happen after processing of channel 0. Due to processing and charging happening in parallel, the first active channel (default channel 1) will charge while channel 0 is processed. Therefore, communication windows will always be after the first active channel has completed conversions. The IQS263 does check for MCU requesting a communication window after ever channel completed charging. sense process Scan Period CH1 CH0 Prox CH2 CH3 CH0 CH1 CH2 tcomms RDY Figure 8.1 Table 8.1 IQS263 Charge Sequence timing diagram in Boost Power mode. Typical Timings Typical timings of IQS263 tsense 840 µs tprocess 3.9 ms tcomms 2 ms Scan Period1 22 ms Typical timings of the charge sequence shown above are listed in Table 8.1. These timings are only as reference, as they will differ with each application, depending on the setup of the IQS263. For example, the sense (or charge time) is affected by the target counts and charge transfer frequency, while process time is dependent on the turbo mode activation, ATI checking for counts within the allowed band, filter settings and slider calculations. Communication time is affected by the MCU clock speed and the amount of data read (as well as the sequence thereof). Communication time and the number of active channels will influence the Scan Period. 1 All channels active and status byte read during communication window. Self capacitive mode, all other settings default. Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 22 of 50 September 2017 IQ Switch® ProxSense® Series 8.2.2 Low Power rate reduce the conversion time (tSENSE) and increase the touch report rate. A wide range of low current consumption charging modes is available on the IQS263.  In any Low Power (LP) mode, there will be an applicable low power time (tLP). With the detection of an undebounced proximity event the IC will zoom to BP mode, allowing a very fast reaction time for further possible touch events. During any LP mode, only channel 0 is charged every tLP. The LP charge timing is illustrated in Figure 6.1. If a low power rate is selected and charging is not in the zoomed state (BP mode), the low power active bit (Register 0x01) will be set. Please refer to Section 6.12. 8.3 Touch report Rate During Boost Power (BP) mode, the touch report rate of the IQS263 device depends on the charge transfer frequency, the number of channels enabled and the length of communications performed by the host MCU or master device. Several factors may influence the touch report rate:  Enabled channels: Disabling channels that are not used will not only increase the touch report rate, but will also reduce the device’s current consumption.  Turbo Mode: See Section 6.5.6  Target Values: Lower target values requires shorter charge transfer times (tSENSE), thus reducing the SCAN PERIOD and increasing the touch report rate.  ACF: Disabling the AC filter and wheel/slider position calculations will reduce the processing time (tPROCESS) and yield a faster report rate. 8.4 Long Term Average The Long-term Average (LTA) filter can be seen as the baseline or reference value. The LTA is calculated to continuously adapt to any environmental drift. The LTA filter is calculated from the CS value for each channel. The LTA filter allows the device to adapt to environmental (slow moving) changes/drift. Actuation (Touch or Prox) decisions are made by comparing the CS value with the LTA reference value. 8.5 Determine Touch or Prox An event is determined by comparing the CS value with the LTA. Since the CS reacts differently when comparing the self- with the mutual capacitance technology, the user should consider only the conditions for the technology used. An event is recorded if:  Self: CS < LTA – Threshold  Projected: CS > LTA + Threshold Threshold can be either a Proximity or Touch threshold, depending on the current channel being processed. Note that a proximity condition will be forced enabled if there is a touch condition on any channel. Please refer to Section 6.7 and 6.8 for proximity and touch threshold selections. Charge Transfer Speed: Increasing the charge transfer frequency will Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 23 of 50 September 2017 IQ Switch® ProxSense® Series 8.6 ATI The Automatic Tuning Implementation (ATI) is a sophisticated technology implemented on the new ProxSense® series devices. It allows for optimal performance of the devices for a wide range of sense electrode capacitances, without modification or addition of external components. The ATI allows the tuning of two parameters, an ATI Multiplier and an ATI Compensation, to adjust the Count values for an attached sense electrode. ATI allows the designer to optimize a specific design by adjusting the sensitivity and stability of each channel through the adjustment of the ATI parameters. The IQS263 has a full ATI function. The full-ATI function is default enabled, but can be disabled by setting the ATI_OFF bit, or changed to partial or alternative ATI by setting the ATI_Partial and ATI_ALT. The ATI_Busy bit will be set while an ATI event is busy. For more information regarding the ATI algorithm, please contact Azoteq at: ProxSenseSupport@azoteq.com noted that a higher sensitivity will yield a higher noise susceptibility. 8.6.2 ATI Target The target value is reached by adjusting the COMPENSATION bits for each channel (ATI target limited to 2048 counts). The target value is written into the respective channel’s TARGET registers. The value written into these registers multiplied by 8 will yield the new target value. (Please refer to Section 6.14) 8.6.3 ATI Base (Multiplier) The following parameters will influence the base value:  Cs_SIZE1: Size of sampling capacitor.  PROJ_BIAS bits: Adjusts the biasing of some analogue parameters in the mutual capacitive operated IC. (Only applicable in mutual capacitance mode.)  Charge Transfer Frequency  MULTIPLIER bits. The base value used for the ATI function can be implemented in 2 ways: 1. ATI_PARTIAL = 0. ATI automatically adjusts MULTIPLIER bits to reach a selected base value2. Please refer to Section 6.13 for available base values. 8.6.1 ATI Sensitivity On the IQS263 device, the user can specify the BASE value (Section 6.13) and the TARGET value (Section 6.14) for the proximity channel (CH0) and touch channels (CH1-CH3). 2. ATI_PARTIAL = 1. The designer can specify the multiplier settings. These settings will give a custom base value from where the compensation bits will be automatically implemented to reach the required target value. The base value is A rough estimation of sensitivity can be calculated as: 𝑆𝑒𝑛𝑠𝑖𝑡𝑖𝑣𝑖𝑡𝑦 ∝ 𝑇𝐴𝑅𝐺𝐸𝑇 𝐵𝐴𝑆𝐸 As can be seen from this equation, the sensitivity can be increased by either increasing the Target value or decreasing the Base value. It should, however, be Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 1 Changing CS_SIZE if ATI_OFF = 0 will change CS 2 ATI function will use user selected CS_SIZE and PROJ_BIAS (if applicable) and will only adjust the MULTIPLIER bits to reach the base values. IQS263 Datasheet V1.12 Page 24 of 50 September 2017 IQ Switch® ProxSense® Series determined by two sets of multiplier bits. Sensitivity Multipliers which will also scale the compensation to normalise the sensitivity and Compensation Multipliers to adjust the gain. 8.6.4 Re-ATI An automatic re-ATI event will occur if the counts are outside its re-ATI limits. The reATI limit or ATI boundary is calculated as the target value divided by 8. For example: - Target = 512, Re-ATI will occur if CS is outside 512±64. Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. A re-ATI event can also be issued by the host MCU by setting the REDO_ATI bit. The REDO_ATI bit will clear automatically after the ATI event was started. Note: Re-ATI will automatically clear all proximity, touch and halt status bits. 8.6.5 ATI ERROR The ATI error bit (read only) indicates to the user that the ATI targets where not reached. Adjustments of the base values or ATI BANDs are required. IQS263 Datasheet V1.12 Page 25 of 50 September 2017 IQ Switch® ProxSense® Series 9 Communication The IQS263 device interfaces to a master controller via a 3-wire (SDA, SCL and RDY) serial interface bus that is I2CTM compatible, with a maximum communication speed of 400kbit/s. 9.1 Control Byte The Control byte indicates the 7-bit device address (44H default) and the Read/Write indicator bit. The structure of the control byte is shown in Figure 9.1. 7 bit address MSB 1 0 0 0 I2C Group Figure 9.1 1 0 0 R/W LSB Sub- addresses IQS263 Control Byte. 2 The I C device has a 7 bit Slave Address (default 0x44H) in the control byte as shown in Figure 9.1. To confirm the address, the software compares the received address with the device address. Sub-address values can be set by OTP programming options. 9.2 I2C Read To read from the device a current address read can be performed. This assumes that the address-command is already setup as desired. Current Address Read Start Control Byte S Data n ACK Data n+1 NACK ACK Figure 9.2 Stop S Current Address Read. If the address-command must first be specified, then a random read must be performed. In this case a WRITE is initially performed to setup the address-command, and then a repeated start is used to initiate the READ section. Start Control Byte S Adr + WRITE Random Read Addresscommand ACK ACK Figure 9.3 Start Control Byte S Adr + READ Data n Stop NACK ACK S Random Read. 9.3 I2C Write To write settings to the device a Data Write is performed. Here the Address-Command is always required, followed by the relevant data bytes to write to the device. DATA WRITE Start Control Byte S Adr + WRITE AddressCommand ACK Figure 9.4 Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. Data n ACK Data n+1 ACK Stop ACK S I2C Write. IQS263 Datasheet V1.12 Page 26 of 50 September 2017 IQ Switch® ProxSense® Series 9.4 End of Communication Session / Window Similar to other Azoteq I2C devices, to end the I2C communication session, a STOP command is given. When sending numerous read and write commands in one communication cycle, a repeated start command must be used to stack them together (since a STOP will jump out of the communication window, which is not desired). The STOP will then end the communication, and the IQS263 will return to process a new set of data. Once this is obtained, the communication window will again become available (RDY set LOW). 9.5 I2C Sub-address The IQS263 has four available sub addresses, 44H (default) to 47H, which allows up to four devices on a single I2C bus. 9.5.1 Internal sub-address selection Selecting the sub-address via OTP bits allows the user 4 different options: Table 9.1 I2C sub-address selection FG25 FG26 Device Address 0 0 1 1 0 1 0 1 0x44 0x45 0x46 0x47 9.6 RDY Hand-Shake Routine The master or host MCU has the capability to request a communication window at any time, by pulling the RDY line low. The communication window will open directly following the current conversion cycle. For more details please refer to the communication interface guide. 9.7 I2C Specific Commands 9.7.1 Show Reset After start-up, and after every reset event, the “Show Reset” flag will be set in the System Flags register (0x01H; byte 0). The “Show Reset” bit can be read to determine whether a reset has occurred on the device (it is recommended to be continuously monitored). This bit will be set ’1’ after a reset. The SHOW_RESET bit will be cleared (set to ’0’) by writing a ’0’ into the “Show Reset” Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. bit. A reset will typically take place if a timeout during communication occurs. 9.7.2 I2C Timeout If no communication is initiated from the master/host MCU within the first tCOMMS (tCOMMS = 5.12ms default) of the RDY line indicating that data is available (i.e. RDY = low), the device will resume with the next cycle of charge transfers and the data from the previous conversions will be lost. The timeout time is adjustable in steps of 1.28ms in the Thresholds register (0x0A; byte 7). There is also a timeout (tI2C) that cannot be disabled, for when communication has started but not been completed, for example when the bus is being held by another device. tI2C = 150ms. 9.8 I2C I/O Characteristics The IQS263 requires the input voltages given in Table 9.2, for detecting high (“1”) and low (“0”) input conditions on the I2C communication lines (SDA, SCL and RDY). IQS263 I2C Input voltage Table 9.2 Input Voltage (V) VinLOW VinHIGH 0.3*VDDHI 0.7*VDDHI Table 9.3 provides the output voltage levels of the IQS263 device during I2C communication. Table 9.3 IQS263 I2C Output voltage Output Voltage (V) VoutLOW VoutHIGH IQS263 Datasheet V1.12 GND +0.2 (max.) VDDHI – 0.2 (min.) Page 27 of 50 September 2017 IQ Switch® ProxSense® Series 10 Communication Command/Address Structure 10.1 Registers & Memory map Table 10.1 IQS263 Registers Address Description Access Section 0x00H Device Information R 10.2.1 0x01H System Flags R/W 10.2.2 0x02H Coordinates R 10.2.3 0x03H Touch Bytes R 10.2.4 0x04H Counts R 10.2.5 0x05H LTA R 10.2.6 0x06H Deltas R 10.2.7 0x07H Multipliers R/W 10.2.8 0x08H Compensation R/W 10.2.9 0x09H ProxSettings R/W 10.2.10 0x0AH Thresholds R/W 10.2.11 0x0BH Timings & Targets R/W 10.2.12 0x0CH Gesture Timers R/W 10.2.13 0x0DH Active Channels R/W 10.2.14 10.2 Registers Descriptions 10.2.1 Device Information 0x00H Information regarding the device type and version is recorded here. Any other information specific to the device version can be stored here. Each Azoteq ROM has a unique Productand Version number. Product Number (PROD_NUM) Access Bit R Value Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 7 6 5 4 3 2 1 0 0x3C IQS263 Datasheet V1.12 Page 28 of 50 September 2017 IQ Switch® ProxSense® Series Version Number (VERSION_NUM) Access Bit R Value 7 6 5 4 3 2 1 0 0x00 10.2.2 System Flags 0x01H System Flags (SYSFLAGS0) Access Bit R/W Name 7 Show Reset 6 5 4 Move ment ATI Error 3 Proj Filter Mode Halt 2 ATI Busy 1 0 Ind LP Halt Active Events Access Bit R Name 7 6 Flick Flick Left Right 5 Tap 4 Move ment 3 ATI Event 2 1 Slide Touch Prox Event Event Event 0 10.2.3 Wheel Coordinates 0x02H Wheel 1 Low Access Bit R Name 7 6 5 4 3 2 1 0 1 0 1 0 Wheel 1 Coordinate Low byte first Relative Coordinate Low Access Bit R Name 7 6 5 4 3 2 Relative Coordinate Low byte first Relative Coordinate High Access Bit R Name Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 7 6 5 4 3 2 Relative coordinate High byte IQS263 Datasheet V1.12 Page 29 of 50 September 2017 IQ Switch® ProxSense® Series 10.2.4 Touch Bytes 0x03H Touch Byte 0 Access Bit R Name 7 6 5 4 3 2 1 0 CH3 CH2 CH1 CH0 3 2 1 0 CH3 CH2 CH1 CH0 1 Halt Byte 1 Access Bit R Name 7 6 5 4 2 Bit 0 of the first byte (CH0) will indicate proximity events; the rest of the bits indicate touches as shown. The second byte shows the halt status bits. 10.2.5 Counts 0x04H This register has 10 bytes to store the count values of the low power channel and then CH0 up to CH3 the low byte will always read out first, followed by the high byte, before the moving to the next channel. Low Power Channel Low Access Bit R Name 7 6 5 4 3 2 1 0 1 0 Low Power Channel CS (Counts) Low byte first Byte 0 CH 3 Counts High byte Access Bit R Name 7 6 5 4 3 2 Channel 3 Count value (High byte last) Byte 9 10.2.6 LTA 0x05H This register has 10 bytes to store the LTA values of the low power channel and then CH0 up to CH3 the low byte will always read out first, followed by the high byte, before the moving to the next channel. Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 1 CH0 indicates Proximity, not Touch. 2 CH0 indicates Proximity, not Touch. IQS263 Datasheet V1.12 Page 30 of 50 September 2017 IQ Switch® ProxSense® Series Low Power Channel LTA Low byte Access Bit R Name 7 6 5 4 3 2 1 0 1 0 Low Power Channel LTA value (Low byte first) Byte 0 CH 3 LTA High byte Access Bit R Name 7 6 5 4 3 2 Channel 3, LTA value (High byte last) Byte 9 10.2.7 Deltas 0x06H This register has 8 bytes to store the Delta (the difference between Count and LTA) values of CH0 up to CH3. The low byte will always read out first, followed by the high byte, before the moving to the next channel. Deltas are not available when using the wheel setting. Delta Counts for CH0 Low Access Bit R Name 7 6 5 4 3 2 1 0 1 0 1 0 Delta for CH0 – Low Byte first Byte 0 Delta Counts for CH3 High Access Bit R Name 7 6 5 4 3 2 Delta for CH3 – High Byte last Byte 7 10.2.8 Multipliers 0x07H CH0 Multipliers Access Bit R Name Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 7 6 5 4 Sensitivity Multipliers IQS263 Datasheet V1.12 3 2 Comp Multipliers Page 31 of 50 September 2017 IQ Switch® ProxSense® Series Byte 0 CH1 Multipliers Access Bit R Name 7 6 5 4 3 Sensitivity Multipliers 2 1 0 Comp Multipliers Byte 1 CH2 Multipliers Access Bit R Name 7 6 5 4 3 Sensitivity Multipliers 2 1 0 Comp Multipliers Byte 2 CH3 Multipliers Access Bit R Name 7 6 5 4 3 Sensitivity Multipliers 2 1 0 Comp Multipliers Byte 3 Base Value Access Bit R Name Byte 4 Default 7 6 5 4 3 Channels 1-3 2 1 0 Channel 0 0x44 Base Value Options: 0000 - 74 1000 - 202 0001 - 90 1001 - 218 0010 - 106 1010 - 234 0011 - 122 1011 - 250 0100 - 138 (default) 1100 - 266 0101 - 154 1101 - 282 0110 - 170 1110 - 298 Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 32 of 50 September 2017 IQ Switch® ProxSense® Series 0111 - 186 1111 - 314 10.2.9 Compensation 0x08H CH0 Compensation value Access Bit R/W Name 7 6 5 4 3 2 1 0 2 1 0 Channel 0 Compensation Byte 0 CH 3 Compensation Value Access Bit R/W Name 7 6 5 4 3 Last active channel Compensation Byte 3 10.2.10 ProxSettings 0x09H ProxSettings0 Access Bit R/W Name Byte 0 Default Bit 7: 7 6 5 4 3 2 Reseed Stream ATI ATI ATI Redo OFF Partial Band ATI ATI 1 0 4MHz Force Halt 0x00H 0 = ATI Enable 1 = ATI Disabled Bit 6: 0 = Full ATI 1 = Partial ATI Bit 5: 0 = 1/8 * LTA 1 = 1/4 *LTA Bit 4: 0 = No Action 1 = Redo ATI Bit 3: 0 = No Action 1 = Send Reseed Bit 2: 0 = No communication widows during ATI routine 1 = Communication windows after each charge cycle regardless of ATI busy. Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 33 of 50 September 2017 IQ Switch® ProxSense® Series Bit 1: 0 = 2MHz Oscillator 1 = 4MHz Oscillator Bit 0: 0 = No Action 1 = Forcing all LTAs to stop calculating ProxSettings1 Access Bit R/W Name Byte 1 Default Bit 7: 7 6 WDT Event OFF Mode 5 4 3 LTA Beta 2 1 Slider 0 CF 0x11H 0 = WDT Enable 1 = WDT Disabled Bit 6: 0 = Streaming Mode 1 = Event Mode 00 = 29 Bit 5:4: 01 = 28 (default) 10 = 27 11 = 26 (fastest following) Bit 3:2: 00 = Slider Disabled 01 = 2CH Slider 10 = Wheel (Also used for 3CH wrap around slider) 11 = 3CH Slider Bit 1:0: 00 = Counts Filtering OFF 01 = Beta - 01 10 = Beta - 02 11 = Beta – 03 (largest filter for noise suppression, slowest response) ProxSettings2 Access Bit R/W Name Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 7 6 5 Sleep Force Wake Halt Sleep Release 4 Wheel Filter IQS263 Datasheet V1.12 3 2 Movement 1 0 OUT Page 34 of 50 September 2017 IQ Switch® ProxSense® Series Byte 2 Bit 7: 0x00H Default 0 = Reseed upon Halt timer expiration 1 = Return to LP upon Halt timer expiration Bit 6: 0 = No Action 1 = Send Force Sleep Bit 5: 0 = Wake from LP only in the normal direction (Counts below LTA for Self) 1 = Wake from LP for counts in both direction Bit 4: 0 = Coordinate Filter Enabled 1 = Coordinate Filter Disabled Bit 3:2: 00 = Movement Disabled 01 = Movement on CH0 10 = Movement on CH3 Bit 1:0: 00 = Prox 01 = Sync (ZC input) 10 = Touch on CH1 11 = Movement output ProxSettings3 Access Bit R/W Name Byte 3 Default Bit 7: 7 6 5 4 3 Touch CS Proj Float Debounce Cap Bias Cx ATA 2 1 Turbo Filtered Mode Touches 0 Xfer 0x00H 0 = 2 consecutive samples 1 = 4 Sample Bit 6: 0 = Large Internal CS capacitor 1 = Small Internal CS capacitor Bit 5: 0 = 10uA 1 = 20uA Bit 4: 0 = Grounded 1 = Floating Bit 3: 0 = Normal Touch Thresholds 1 = Automatic adjustment of Touch Thresholds Bit 2: 0 = Turbo Mode Enabled Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 35 of 50 September 2017 IQ Switch® ProxSense® Series 1 = Turbo Mode Disabled Bit 1: 0 = Touch detection on unfiltered counts 1 = Touch detection on filtered counts Bit 0: 0 = Fast Charging 1 = Slower Charging Event Mask Access Bit 7 6 5 4 3 2 1 0 R/W Name Flick Left Flick Right Tap Move ment ATI Slide Touch Prox Byte 4 Default 10.2.11 0xFFH Thresholds 0x0A Proximity Threshold Access Bit 7 6 5 4 3 R/W Name Value Byte 0 Default 4D 2 1 0 2 1 0 2 1 0 2 1 0 Touch Threshold CH1 Access Bit 7 6 5 4 3 R/W Name 1-255 Byte 1 Default 16D Touch Threshold CH3 Access Bit 7 6 5 4 3 R/W Name 1-255 Byte 3 Default 16D Movement Threshold Access Bit R/W Name Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 7 6 5 4 3 1-255 IQS263 Datasheet V1.12 Page 36 of 50 September 2017 IQ Switch® ProxSense® Series Byte 4 3D Default Halt timeout Reseed Block Access Bit 7 R/W Name Byte 5 Default 6 5 4 3 2 1 CH3 CH2 CH1 0 0 Halt Time in Number of Samples Access Bit 7 6 5 4 3 2 R/W Name Value times 50 (FF = Always; 00 = Never) Byte 6 Default 20D 1 0 1 0 I2C Timeout Access Bit R/W Name Value times 1.28ms Byte 7 Default 4D 10.2.12 7 6 5 4 3 2 Timings 0x0BH Low Power Time Access Bit 7 6 5 4 3 2 R/W Name Steps of 16ms (Value times 16ms) Byte 0 Default 0x00H 1 0 1 0 ATI Target for Touch Channels Access Bit R/W Name Steps of 8 (Value times 8) Byte 1 Default 48D Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 7 6 5 4 3 IQS263 Datasheet V1.12 2 Page 37 of 50 September 2017 IQ Switch® ProxSense® Series ATI Target for Proximity Access Bit R/W Name Steps of 8 (Value times 8) Byte 2 Default 64D 10.2.13 7 6 5 4 3 2 1 0 2 1 0 2 1 0 2 1 0 3 2 1 0 CH3 CH2 CH1 CH0 Gesture Timers 0x0CH Tap Timer Access Bit 7 6 5 4 3 R/W Name Tap Timer Limit Byte 0 Default 5D Flick Timer Access Bit 7 6 5 4 3 R/W Name Flick Timer Limit Byte 1 Default 20D Flick Threshold Access Bit R/W Name Flick Threshold Value Byte 2 Default 50D 10.2.14 7 6 5 4 3 Active Channels 0x0DH Active Chan 0 Access Bit R/W Name Byte 0 Default Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 7 6 5 4 0x0FH IQS263 Datasheet V1.12 Page 38 of 50 September 2017 IQ Switch® ProxSense® Series 11 Specifications 11.1 Absolute Maximum Specifications The following absolute maximum parameters are specified for the device: Exceeding these maximum specifications may cause damage to the device.  Operating temperature -20°C to 85°C  Supply Voltage (VDDHI – GND) 3.6V  Maximum pin voltage  Maximum continuous current (for specific Pins) VDDHI + 0.5V (may not exceed VDDHI max) 10mA  Minimum pin voltage GND - 0.5V  Minimum power-on slope 100V/s  ESD protection ±8kV (Human body model) Table 11.1 IQS263 Self Capacitive General Operating Conditions1 DESCRIPTION Conditions Supply voltage MIN TYP MAX UNIT VDDHI 1.8 3.3V 3.6 V 1.62 1.7 1.79 V Internal regulator output 1.8 ≤ VDDHI≤ 3.6 VREG Streaming mode* 3.3V 80Hz 180 Event Mode 80Hz 90 150 μA Low Power Setting 8** 128ms 4 6.5 μA Low Power Setting 16** 256ms 3 4 μA Table 11.2 μA IQS263 Projected Capacitive General Operating Conditions DESCRIPTION Conditions Supply voltage * PARAMETER PARAMETER MIN TYP MAX UNIT VDDHI 1.8 3.3V 3.6 V 1.79 V Internal regulator output 1.8 ≤ VDDHI≤ 3.6 VREG 1.62 1.7 Streaming mode 3.3V 80Hz - 305 μA Event Mode 80Hz - 230 μA Low Power Setting 8** 128ms - 5 11 μA Low Power Setting 16** 256ms - 4 6 μA Current consumption for streaming mode will differ with number of bytes read, speed and pull up resistor values ** LP interval period = Low power value x 16ms 1 Current values shown in this datasheet, does not include dissipation through I2C pull up resistors unless streaming mode is indicated. Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 39 of 50 September 2017 IQ Switch® ProxSense® Series Table 11.3 Start-up and shut-down slope Characteristics DESCRIPTION Power On Reset Brown Out Detect Table 11.4 Conditions PARAMETER VDDHI Slope ≥ 100V/s POR @25°C VDDHI Slope ≥ 100V/s BOD @25°C MAX UNIT 1.6 V 1.05 V Electrode Specifications – Self Capacitance DESCRIPTION Conditions PARAMETER MAX UNIT CP 120 pF RS 10 kΩ Parasitic Capacitance CX to GND Series Resistor Table 11.5 MIN CP = 120pF Electrode Specifications – Mutual Capacitance DESCRIPTION Conditions PARAMETER MIN MAX UNIT Parasitic Capacitance Tx to GND CT 100 pF Parasitic Capacitance Rx to GND CR 100 pF Mutual Capacitance CM 10 pF Series Resistor RTX 10 kΩ RRX 1 kΩ Series Resistor Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. CM = 1pF IQS263 Datasheet V1.12 0.1 Page 40 of 50 September 2017 IQ Switch® ProxSense® Series Table 11.6 ATI Times Turbo Mode Off Oscillator 2MHZ Target value 4MHZ Low High Low High Channels active 1 3 1 3 1 3 1 3 Typical time [ms] 625 625 630 630 310 300 313 305 850 (34 cycles @25ms per cycle) Worst case Turbo Mode On Oscillator 2MHZ Target value 4MHZ Low High Low High Channels active 1 3 1 3 1 3 1 3 Typical time [ms] 200 350 240 420 105 175 120 205 Worst case 500 - 600 (34 cycles estimate) ATI Error / Failure Worst case Including re-tries Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 4.7 seconds (189 cycles @25ms per cycle) Something is wrong with settings or electrode(s) IQS263 Datasheet V1.12 Page 41 of 50 September 2017 IQ Switch® ProxSense® Series 12 Packaging Information 12.1 MSOP-10 Figure 12.1 MSOP-10 Package Dimensions. Table 12.1 MSOP-10 Package Dimensions. DIMENSION MIN MAX Unit A 2.90 3.10 mm B 2.90 3.10 mm H 0.775 1.05 mm K 0.025 0.10 mm L 4.75 5.05 mm T 0.40 0.80 mm Pitch W Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. 0.5 0.17 mm 0.27 mm IQS263 Datasheet V1.12 Page 42 of 50 September 2017 IQ Switch® ProxSense® Series Figure 12.2 MSOP-10 Footprint. Table 12.2 Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. MSOP-10 Footprint Dimensions from Figure 12.2. Dimension [mm] Pitch 0.50 C 4.40 Y 1.45 X 0.30 IQS263 Datasheet V1.12 Page 43 of 50 September 2017 IQ Switch® ProxSense® Series 12.2 DFN10 Table 12.3 DFN-10 Package dimensions (bottom) 3 ±0.1 B 0.5 C 0.25 D n/a F 3 ±0.1 L 0.4 P 2.4 Q 1.65 Table 12.4 DFN-10 Package dimensions (side) Dimension [mm] G 0.05 H 0.65 I 0.7-0.8 F A L [mm] D B Q Dimension A C P Figure 12.3 DFN-10 Package dimensions (bottom). Note that the saddle need to be connected to GND on the PCB. Figure 12.4 DFN-10 Package dimensions (side) Table 12.5 DFN-10 Landing dimensions Dimension [mm] A 2.4 B 1.65 C 0.8 D 0.5 E 0.3 F 3.2 Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. Figure 12.5 DFN-10 Landing dimensions IQS263 Datasheet V1.12 Page 44 of 50 September 2017 IQ Switch® ProxSense® Series 12.3 Tape and Reel Specification 12.3.1 MSOP10 Figure 12.6 Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. MSOP-10 Tape Specification. Bulk orientation LT. IQS263 Datasheet V1.12 Page 45 of 50 September 2017 IQ Switch® ProxSense® Series 12.3.2 DFN10 (3x3) Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 46 of 50 September 2017 IQ Switch® ProxSense® Series 12.4 Package MSL Moisture Sensitivity Level (MSL) relates to the packaging and handling precautions for some semiconductors. The MSL is an electronic standard for the time period in which a moisture sensitive device can be exposed to ambient room conditions (approximately 30°C/85%RH see J-STD033C for more info) before reflow occur. Table 12.6 MSL Package Level (duration) MSL 1 (Unlimited at ≤30 °C/85% RH) MSOP-10 Reflow profile peak temperature < 260 °C for < 25 seconds Number of Reflow ≤ 3 MSL 1 (Unlimited at ≤30 °C/85% RH) DFN10 (3x3) Reflow profile peak temperature < 260 °C for < 25 seconds Number of Reflow ≤ 3 Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 47 of 50 September 2017 IQ Switch® ProxSense® Series 13 Device Marking 13.1 Top Marking IQS263A x t z PWWYY REVISION DATE CODE TEMPERATURE CONFIGURATION REVISION x = IC Revision Number TEMPERATURE RANGE t = = i c IC CONFIGURATION z = Configuration (Hexadecimal) DATE CODE P = Package House WW = Week YY = Year Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. -20°C to 85°C (Industrial) 0°C to 70°C (Commercial) IQS263 Datasheet V1.12 Page 48 of 50 September 2017 IQ Switch® ProxSense® Series 14 Ordering Information Order quantities will be subject to multiples of a full reel. Contact the official distributor for sample quantities. A list of the distributors can be found under the “Distributors” section of www.azoteq.com. 14.1 MSOP-10 Package IQS263 z ppb BULK PACKAGING IC NAME SUB ADDRESS CONFIGURATION PACKAGE TYPE IC NAME IQS263 = IQS263 CONFIGURATION z = Sub Address Configuration (hexadecimal) 0 = 44H 1 = 45H 2 = 46H 3 = 47H PACKAGE TYPE MS = MSOP-10 BULK PACKAGING R = Reel MSOP - 4000pcs/reel 14.2 DFN Package IQS263A z ppb BULK PACKAGING IC NAME SUB ADDRESS CONFIGURATION PACKAGE TYPE IC NAME IQS263A = IQS263 CONFIGURATION z = Sub Address Configuration (hexadecimal) 0 = 44H 1 = 45H 2 = 46H 3 = 47H PACKAGE TYPE DN = DFN10 (3x3) BULK PACKAGING R = Reel DNF10 (3x3) – 3000pcs/reel Copyright © Azoteq (Pty) Ltd 2017. All rights reserved. IQS263 Datasheet V1.12 Page 49 of 50 September 2017 IQ Switch® ProxSense® Series Azoteq USA Asia South Africa Physical Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC 1 Bergsig Avenue Paarl 7646 South Africa Postal Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC PO Box 3534 Paarl 7620 South Africa Tel +1 512 538 1995 +86 755 8303 5294 ext 808 +27 21 863 0033 Email info@azoteq.com info@azoteq.com info@azoteq.com Visit www.azoteq.com for a list of distributors and worldwide representation. Patents as listed on www.azoteq.com/patents-trademarks/ may relate to the device or usage of the device. Azoteq®, Crystal Driver , IQ Switch®, ProxSense®, ProxFusion®, LightSense™, SwipeSwitch™, and the logo are trademarks of Azoteq. The information in this Datasheet is believed to be accurate at the time of publication. Azoteq uses reasonable effort to maintain the information up-to-date and accurate, but does not warrant the accuracy, completeness or reliability of the information contained herein. All content and information are provided on an “as is” basis only, without any representations or warranties, express or implied, of any kind, including representations about the suitability of these products or informat ion for any purpose. Azoteq disclaims all warranties and conditions with regard to these products and information, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property rights. Azoteq assumes no liability for any damages or injury arising from any use of the information or the product o r caused by, without limitation, failure of performance, error, omission, interruption, defect, delay in operation or transmiss ion, even if Azoteq has been advised of the possibility of such damages. The applications mentioned herein are used solely for the purpose of illustration and Azoteq makes no warranty or representation that such applications will be suitable without further modification, nor recommends the use of its products for application that may present a risk to human life due to malfunction o r otherwise. Azoteq products are not authorized for use as critical components in life support devices or systems. No licenses to patents are granted, implicitly, express or implied, by estoppel or otherwise, under any intellectual property rights. In the event that any of the abovementioned limitations or exclusions does not apply , it is agreed that Azoteq’s total liability for all losses, damages and causes of action (in contract, tort (including without limitation, negligence) or otherwise) will not exceed the amount already paid by the customer for the products. Azoteq reserves the right to alter its products, to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and information, its products, programs and services at any time or to move or discontinue any contents, products, programs or services without pr ior notification. For the most up-to-date information and binding Terms and Conditions please refer to www.azoteq.com. Copyright © Azoteq (Pty) Ltd 2019. All Rights Reserved. info@azoteq.com IQS5xx-B000 Datasheet Revision 2.1 Page 1 of 1 March 2021
IQS263-0-MSR 价格&库存
很抱歉,暂时无法提供与“IQS263-0-MSR”相匹配的价格&库存,您可以联系我们找货
