IQS128-00000-TSR
IQS128-00000-TSR
    AZOTEQ
    1 CH. CAPACITIVE TOUCH SENSOR DY
IQS128-00000-TSR 数据手册
IQ Switch® ProxSense® Series IQS128 Datasheet IQ Switch® - ProxSense® Series Single Channel Capacitive Proximity/Touch Controller The IQS128 ProxSense® IC is a fully integrated capacitive sensor implementing Dynamic Calibration (DYCAL™) technology: intelligent hysteresis to allow for sensor drift even during sensor activation. Features DYCAL™ : Intelligent Hysteresis Internal Capacitor Implementation (ICI) – reference capacitor on-chip Automatic Tuning Implementation (ATI) Automatic adjustment for optimal sensor performance Supply voltage: 2.95V to 5.5V Minimum external components 1-Wire open drain data streaming option Advanced on-chip digital signal processing User selectable (OTP): External synchronisation control or External control over filter operation I/O Sink or Source selection Time-out for stuck key Proximity and Touch sensitivity selections Keys: Dielectric: Touch: Proximity: Material: Thickness: 5mm x 5mm or larger (overlay thickness dependent) Various electrical options (wire / PCB trace / ITO / conductive foil) Various non-metal materials (i.e. glass, plastic, painted surfaces) 6 mm plastic, 10 mm glass for touch. Very thick overlay possible for proximity Human Interface Devices Proximity activated backlighting Any applications where a touch and proximity condition can prevail for an extended period of time with or without a host controller Applications Occupancy sensors SAR qualification for Tablet PC’s On-ear detection for mobile phones 3D glasses Personal Media Players White goods and appliances Minimal power consumption ( VDDPU) Typical use case for the IQS128 is to power the IC with a VDDHI of 3.3V and interface to a 1.8V microprocessor, implying VDDPU of 1.8V. This case requires the following: Table 9.2 Mixed supply level requirements Description Power up Power up (alternative) Power down Power up failure case Requirement tpower_up_1v8 ≥ tpower_up_3v3 While tpower_up_3v3 force OUT pin 0V with MCU VDDHI = 0V and VDDPU = 1.8V; tpower_up_3v3 ≥ tpower_up_1v8 IQS128 VDDHI CX RCX Sense Electrode CTRL RCTRL CTRL Input OUT VSS VREG GND CVREG GND Figure 9.1 Schematic with recommended CTRL input pin use Copyright © Azoteq (Pty) Ltd 2017 All rights reserved IQS128 Datasheet v3.2 Check for latest datasheet Page 15 of 23 August 2017 IQ Switch® ProxSense® Series 10 Electrical Specifications 10.1 Absolute Maximum Specifications Exceeding these maximum specifications may cause damage to the device. Operating temperature Supply Voltage (VDDHI – VSS)2 Maximum pin voltage (OUT, CTRL) Pin voltage (Cx) Minimum pin voltage (VDDHI, VREG, OUT, CTRL, Cx) Minimum power-on slope ESD protection (VDDHI, VREG, VSS, OUT, CTRL, Cx) -40°C to 85°C 6.5V VDDHI + 0.5V 2.5V VSS - 0.5V 100V/s 4kV 10.2 General Characteristics (Measured at 25°C) Standard IQS128 devices are rated for supply voltages between 2.95V and 5.5V. Table 10.1 IQS128 General Operating Conditions DESCRIPTION Supply voltage Internal regulator output Boost Power operating current Standby operating current3 Conditions PARAMETER MIN 2.95 2.35 TYP MAX 5.50 2.65 UNIT V V 2.95 ≤ VDDHI ≤ 5.5 VDDHI VREG 2.95 ≤ VDDHI ≤ 5.5 IIQS128_BP 77 μA 2.95 ≤ VDDHI ≤ 5.5 ISTANDBY 7 μA 2.50 Table 10.2 Start-up and shut-down slope Characteristics DESCRIPTION POR BOD IC D/S D/S Conditions VDDHI Slope ≥ 100V/s PARAMETER POR BOD MIN 1.45 1.30 MAX 1.70 1.40 2 Maximum voltage applied for OTP programming and not intended for operation. 3 CTRL = Input and CTRL = HIGH (Charge halt). Copyright © Azoteq (Pty) Ltd 2017 All rights reserved IQS128 Datasheet v3.2 Check for latest datasheet UNIT V V Page 16 of 23 August 2017 IQ Switch® ProxSense® Series 10.3 Output Characteristics (Measured at 25°C) Table 10.3 OUT Characteristics Symbol Description VOH Output High voltage Symbol Description VOL Output Low voltage ISOURCE (mA) 1 1 1 ISINK (mA) 1 1 1 Conditions MIN TYP MAX UNIT VDDHI = 5.5V VDDHI = 3.3V VDDHI = 2.95V 5.45 3.25 2.85 5.48 3.27 2.9 5.49 3.29 2.95 V Conditions MIN TYP MAX UNIT VDDHI = 5.5V VDDHI = 3.3V VDDHI = 2.95V 0.30 0.20 0.20 0.50 0.33 0.25 - V MAX 1.1 UNIT MHz 10.4 Timing Characteristics Table 10.4 Main Oscillator4 SYMBOL FOSC 4 DESCRIPTION IQS128 Main oscillator Conditions 2.95 ≤ VDDHI ≤ 5.5 MIN 0.9 TYP 1 All timings are derived from the main oscillator. Copyright © Azoteq (Pty) Ltd 2017 All rights reserved IQS128 Datasheet v3.2 Check for latest datasheet Page 17 of 23 August 2017 IQ Switch® ProxSense® Series Table 10.5 General Timing Characteristics for 2.95V ≤ VDDHI ≤ 5.5V SYMBOL tHIGH tLOW FCX DESCRIPTION Output high minimum time Output low minimum time Charge transfer frequency tCHARGE Charge cycle duration tSAMPLE tBP tBP tSTART tINIT tDATA tDYCAL Refer to section 4 Sampling period in BP Sampling period in BP Refer to section 7 Refer to section 7 Refer to section 7 Dynamic Calibration time Halt Operation/Filter Halt time Pulse timing TEXT_HALT TPULSE Conditions MIN 9 9 CS = 1600, fcx = 250kHz tCHARGE - 2 ≤ tSAMPLE tCHARGE ≥ tSAMPLE TYP 250 UNIT ms ms kHz 6.4 ms 9 9 ms ms ms us us us ms 2.95 ≤ VDDHI ≤ 5.5 tCHARGE+2 17 136 136 250 2.95 ≤ VDDHI ≤ 5.5 40 14.4 2.95 ≤ VDDHI ≤ 5.5 25 30 MAX 18.8 ms 35 ms Table 10.6 IQS128 Response Times Power Mode Conditions Boost Power Mode5 Detection Release DYCAL Min* Max Unit 63.7 ms 63.7 ms **Minimum time calculated as causing a proximity detection on the IQS128. Prox debounce is 6 and I/O is toggled after next charge transfer cycle, requiring 7 charge cycles for the minimum time of a decision to be made. 5 IQS128 only available in Boost Power Mode. Minimum Detection and Release times = 7 x tCHARGE Copyright © Azoteq (Pty) Ltd 2017 All rights reserved IQS128 Datasheet v3.2 Check for latest datasheet Page 18 of 23 August 2017 IQ Switch® ProxSense® Series 11 Packaging and Part-number Information 11.1 TSOT23-6 C A B D E F J G I H Figure 11.1 TSOT23-6 Packaging 6 Table 11.1 TSOT23-6 Dimensions A B C D E F G H I J 6 Dimension Min 2.80 mm typ 1.60 mm typ 2.90 mm typ 0.40 mm 0.95 mm typ 1.00mm 0.05 mm 0.40 mm 4° 0.127 mm typ Max Tolerance Basic Basic Basic ±0.10mm Basic Max ±0.05mm ±0.10mm ±4° +0.07/-0.007 Drawing not on Scale Copyright © Azoteq (Pty) Ltd 2017 All rights reserved IQS128 Datasheet v3.2 Check for latest datasheet Page 19 of 23 August 2017 IQ Switch® ProxSense® Series 11.2 TSOT23-6 Tape Figure 11.2 IQS128Tape Specification 11.3 Moisture Sensitivity Level (MSL) Moisture Sensitivity Level relates to the packaging and handling precautions for some semiconductors. The MSL is an electronic standard for the time period in which a moisture sensitive device can be exposed to ambient room conditions (approximately 30°C/60%RH). Increasingly, semiconductors have been manufactured in smaller sizes. Components such as thin fine-pitch devices and ball grid arrays could be damaged during SMT reflow when moisture trapped inside the component expands. The expansion of trapped moisture can result in internal separation (delamination) of the plastic from the die or lead-frame, wire bond damage, die damage, and internal cracks. Most of this damage is not visible on the component surface. In extreme cases, cracks will extend to the component surface. In the most severe cases, the component will bulge and pop. IQS128 Packaging MSL Information Package TSOT23-6 Copyright © Azoteq (Pty) Ltd 2017 All rights reserved Level (duration) MSL1 (unlimited at ≤30 °C/85% RH) IQS128 Datasheet v3.2 Check for latest datasheet Page 20 of 23 August 2017 IQ Switch® ProxSense® Series 11.4 Device Packaging Convention 11.4.1 Top 128XX IC NAME BATCH 11.4.2 Bottom Some batches IQS128 will not have any bottom markings. These devices are configured after marking, and may have variations in configuration – please refer to the reel label. Other batches will display the configuration set on the chip on the bottom marking. zzzzz CONFIGURATION 11.5 Ordering Information Only full reels can be ordered and orders will be subject to a MOQ (Minimum Order Quantity) of a full reel. Contact the official distributor for sample quantities. A list of the distributors can be found under the “Distributors” section of www.azoteq.com. For large orders, Azoteq can provide pre-configured devices. The Part-number can be generated by using USBProg.exe or the Interactive Part Number generator on the website. IQS128 zzzzz ppb IC NAME BULK PACKAGING CONFIGURATION PACKAGE TYPE IC NAME IQS128 = IQS128 CONFIGURATION zzzzz = IC Configuration (hexadecimal) PACKAGE TYPE TS = TSOT23-6 BULK PACKAGING R = Reel (3000pcs/reel) MOQ = 1 reel. Mass production orders shipped as full reels. Copyright © Azoteq (Pty) Ltd 2017 All rights reserved IQS128 Datasheet v3.2 Check for latest datasheet Page 21 of 23 August 2017 IQ Switch® ProxSense® Series 12 Datasheet Revision History Version 1.10 Preliminary release Version 2.0 Added IQS128L and its functional differences Added ATI BASE description Added ND feature description for IQS128 Version 2.1 Updated aesthetics Version 2.2 Changed QFN to DFN Changed Power Mode names Version 2.3 Updated maximum operating voltage to 5.5 throughout document Updated absolute maximum specification: Supply voltage to 6.5V. (Only intended for OTP programming!) Version 2.4 Updated POR and BOR table Updated packaging and part-number information Changed Current Sample references to Counts (CS) Changed Antenna references to Electrode Changed Auto-ATI references to ATI Changed Device Markings Added Tape/Reel Specification Moved Section On Packaging Information to Section 12 Made Revision History a section on its own Added Tape Specification Added Errata to accommodate previous packaging Version 2.5 Improve images on front page Add bottom marking description Update contact information Version 2.6 Remove IQS128L information – This device has been made EOL. Version 2.7 Updated patent numbers and contact information Version 2.8 Added SAR configuration recommendations Added level shifting application recommendations Errata to prevent output failure with large RPU 1-Wire streaming reference changed to AZD040 Version 2.9 Output pin characteristics updated Version 3.0 External pull-down required on CTRL input pin. Document updated to include reference design. Section 6.1 updated and section 9.2 added. Version 3.1 Figure 2.2 & Table 2.2 updated to specify reference design capacitive load Version 3.2 Remove noise detection bit form OTP options. Copyright © Azoteq (Pty) Ltd 2017 All rights reserved IQS128 Datasheet v3.2 Check for latest datasheet Page 22 of 23 August 2017 IQ Switch® ProxSense® Series Azoteq USA Asia South Africa Physical Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC 1 Bergsig Avenue Paarl 7646 South Africa Postal Address 11940 Jollyville Suite 120-S Austin TX 78750 USA Room 501A, Block A, T-Share International Centre, Taoyuan Road, Nanshan District, Shenzhen, Guangdong, PRC PO Box 3534 Paarl 7620 South Africa Tel +1 512 538 1995 +86 755 8303 5294 ext 808 +27 21 863 0033 Email info@azoteq.com info@azoteq.com info@azoteq.com Visit www.azoteq.com for a list of distributors and worldwide representation. Patents as listed on www.azoteq.com/patents-trademarks/ may relate to the device or usage of the device. Azoteq®, Crystal Driver , IQ Switch®, ProxSense®, ProxFusion®, LightSense™, SwipeSwitch™, and the logo are trademarks of Azoteq. The information in this Datasheet is believed to be accurate at the time of publication. Azoteq uses reasonable effort to maintain the information up-to-date and accurate, but does not warrant the accuracy, completeness or reliability of the information contained herein. All content and information are provided on an “as is” basis only, without any representations or warranties, express or implied, of any kind, including representations about the suitability of these products or informat ion for any purpose. Azoteq disclaims all warranties and conditions with regard to these products and information, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property rights. Azoteq assumes no liability for any damages or injury arising from any use of the information or the product o r caused by, without limitation, failure of performance, error, omission, interruption, defect, delay in operation or transmiss ion, even if Azoteq has been advised of the possibility of such damages. The applications mentioned herein are used solely for the purpose of illustration and Azoteq makes no warranty or representation that such applications will be suitable without further modification, nor recommends the use of its products for application that may present a risk to human life due to malfunction o r otherwise. Azoteq products are not authorized for use as critical components in life support devices or systems. No licenses to patents are granted, implicitly, express or implied, by estoppel or otherwise, under any intellectual property rights. In the event that any of the abovementioned limitations or exclusions does not apply , it is agreed that Azoteq’s total liability for all losses, damages and causes of action (in contract, tort (including without limitation, negligence) or otherwise) will not exceed the amount already paid by the customer for the products. Azoteq reserves the right to alter its products, to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and information, its products, programs and services at any time or to move or discontinue any contents, products, programs or services without pr ior notification. For the most up-to-date information and binding Terms and Conditions please refer to www.azoteq.com. Copyright © Azoteq (Pty) Ltd 2019. All Rights Reserved. info@azoteq.com IQS5xx-B000 Datasheet Revision 2.1 Page 1 of 1 March 2021
IQS128-00000-TSR 价格&库存
很抱歉,暂时无法提供与“IQS128-00000-TSR”相匹配的价格&库存,您可以联系我们找货
