IR603/3
IR603/3
    SGXSENSORTECH
    IR SENSOR HEAD FOR 0-5%/100% BRO
IR603/3 数据手册
SGX Europe Sp. z o.o. Building 11 Ligocka St. 103, 40-568 Katowice, Poland T: +48 (0) 32 438 4778 E: sales.is@sgxsensortech.com www.sgxsensortech.com IR600 Datasheet Infrared Gas Sensor for Hazardous Areas (Fixed Systems) The IR600 Series gas sensors are designed to detect and monitor the presence of CO2, hydrocarbons and acetylene using the same non-dispersive infrared (NDIR) principle as used in the SGX Sensortech range of miniature infrared gas sensors. Dual detector channels are used with a reference for background compensation. A temperature sensor is mounted for temperature compensation. IR600 sensors are designed to be integrated with fixed gas detection systems. Their construction is a stainless steel flameproof enclosure with an integral stainless steel sinter for the safe entry of the gases being tested. Three types of mounting thread are available to allow easy fixing to the junction box of the fixed system. On the front face there is an external M46 thread for attaching optional accessories for use in different applications. The IR600 Series incorporates an inbuilt and sealed preamplifier/buffer and require connection to suitable transmitter systems for their power supply, operation and signal processing. The IR600 lead in/out terminates in an 8-pin connector. FEATURES • • • • • • • • • • • • • • • • • For detection of the following gases: o Carbon Dioxide (IR601), o Hydrocarbons (IR602, IR603) o Acetylene (IR604) Diffused gas sampling via sinter Low power Reference channel for self-compensation Special gold plated optical/gas cavity for stable signal levels Operational in varying temperature, pressure and humidity Fast response Rugged stainless steel construction No moving parts Resistance to corrosion Immunity from ‘poisoning’ Reliable fail-safe operation Low maintenance Sealed preamplifier/buffer electronics Accessories available for field applications ATEX certified CSA certified (Canada and US) OPERATING PRINCIPLE SGX Sensortech manufactures a range of Infrared (IR) Gas Sensors for a variety of gases and vapours in different applications. These are compact and robust gas diffusion type sensors based on an SGX Sensortech patented optical design. They run on low power and use well proven NonDispersive Infrared (NDIR) detection methods. The sensor operates using the natural ability of the target gases to absorb radiation in the infrared portion of the electromagnetic spectrum. Using an infrared source, detector and selective optical filters the SGX infrared sensors can be used to detect a range of target gases. More information on the NDIR sensors can be found in the SGX Sensortech Application Notes. TECHNICAL SPECIFICATION Mechanical Dimensions Body material Weight See Outline on Page 5 Stainless Steel 435g Environmental Ambient temperature range for operation (ATEX): for operation (CSA): storage: Operational pressure range Humidity range for operation and storage Gases Detected -20°C to +60°C -20°C to +65°C -20°C to +60°C 700kPa to 1300kPa 0 to 95% RH (Non-condensing) Carbon Dioxide, hydrocarbons Electrical DC supply to detectors Typical power Lamp Supply See Outline on Page 5 180mW / 5V +5V, 60mA (Recommended) (Square Wave at 4Hz, 50% duty cycle) ___________________________________________________________________________________________ Whilst SGX has taken care to ensure the accuracy of the information contained herein it accepts no responsibility for the consequences of any use thereof and also reserves the right to change the specification of goods without notice. SGX accepts no liability beyond the set out in its standard conditions of sale in respect of infringement of third party patents arising from the use of SGX products in accordance with information contained herein. In case of modification of the product, SGX disclaims all liability. SGX Europe sp .z o.o. Poland REGON: 362332227 DS-0239, Issue 1, 13-May-2016, Page 1 SGX Europe Sp. Z o.o. Building 11 Ligocka St. 103, 40-568 Katowice, Poland T: +48 (0) 32 438 4778 E: sales.is@sgxsensortech.com www.sgxsensortech.com PERFORMANCE For test purposes, all data taken using the following conditions: - SGX linearisation and temperature compensation algorithms; see Infrared Sensor Application Notes. - Lamp modulation 0.4 - 5.0 V, square wave, at 4 Hz and 50% duty cycle. - Ambient temperature (20°C) and pressure (103 kPa). - All gases diluted in dry nitrogen. Sensor type IR601 Gas IR602 Carbon Dioxide Sensing range IR603 Hydrocarbons IR604 Acetylene 0 - 100% LEL and 0 - 100% vol. 0 - 5.0%vol. (same sensor is suitable for both ranges) Maximum response time (T90)
IR603/3 价格&库存
很抱歉,暂时无法提供与“IR603/3”相匹配的价格&库存,您可以联系我们找货
